Which lift to put on my TRD Punisher??
Discussion in 'Suspension' started by 040Tundra, Feb 21, 2017.
  1. Feb 21, 2017 at 6:05 PM
    040Tundra
    040Tundra [OP] Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I'm having a hard time trying to decide which kit to put on my truck. At first I wanted the Toytec 3/1-½" (shackles on the rear) but now I've come across a Tough Country 4" in front w/ 2" blocks in the rear with new nitro shocks (rear only). The Tuff Country also comes with UCA's.
    First question: in your experience of off roading, at what point is too high too much? (I don't want to jeopardize safety at the cost be being high if 4" is even too much).
    2) I need to use my stock wheels and tires for a while so I have to throw on Spidertrax 1-¼" wheel spacers in order that the wheels will fit on the truck if I go with the Tough Country. Is it bad to off road with wheel spacers on?
    3) Do wheel spacers effect alignment, or put extra wear on the truck?
    Any help would be greatly appreciated!! Thank you!!
  2. Feb 21, 2017 at 6:09 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    For off-roading, any time you throw a block in you are sacrificing performance for looks.
    040Tundra[OP] likes this.
  3. Feb 21, 2017 at 6:14 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I'm no suspension expert, but I did stay @ a Holiday Inn last night. Im willing to bet that our (real experts) will not agree with that Tuff Country, especially with 2" blocks. Uh No. Just my .02. Glwp
  4. Feb 21, 2017 at 6:25 PM
    rons23
    Ron
    Kill Devil Hills
    Truckinit, the Boss Kit from Toytec seems to be the clear winner on this forum. Bilstein 6112/5160 is another route. Good luck
  5. Feb 21, 2017 at 7:02 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    1st question answer : It all depends on what you call off-roading. Are you going to fly across some whoops, or do a slower crawl over rough terrain. Nothing wrong with a taller lift if taken it slow. Get into some higher speed, and the lowest COG with largest tires works best. Question 2 answer : wheel spacers are fine when properly installed and are a good quality ( spidertrax ). I would be cautious of any high speeds offroad with wheel spacers. Question 3 answer : any wheels further out than stock will cause more wear and tear on components, but will not hurt alignment. Just my thoughts. Answer 4 : Go have fun and enjoy the ride !
  6. Feb 21, 2017 at 7:50 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for responding. When I off road I go slow over rough terrain (usually), not enter into the Baja 1000. So it sounds like I'll be ok with a 4" lift and a little off roading. Your comment about wheel spacers has me a little concerned about wearing out components if using spacers. I don't want to prematurely wear out my truck for a certain look, that's for sure. I hope others will chime in..... Thanks again for sharing your brain!!
  7. Feb 22, 2017 at 2:56 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Yep what rons23 said. :thumbsup: Not a fan of spacers or body lifts here.
    zcarpenter92 and Law323 like this.
  8. Feb 22, 2017 at 4:50 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Trust me, spacers suck!!
    BOSS is the way to go...ask me how I know :oldglory:
  9. Feb 22, 2017 at 6:25 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    By the way, when these guys are saying no to spacers they are talking about spacer lifts, not for your wheels.
    Many on here run Spyder or Bora 1 1/4 without any problems. Idk about serious offroading with them, but to use until you get some wheels with the right offset will be more than fine.
    Also I'm pretty sure one of the suspension gurus on here said that you have much more wheel travel with a 3/1 toytec kit as opposed to the Tough Country.
  10. Feb 22, 2017 at 7:34 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Hey @TruckinIt,
    So if you are going to be just doing slower off roading and daily driving then I would personally recommend going with the BOSS kit in your situation. Full ride height adjustments from 1-3'' of front end lift, and diff drop. For the rear end you have the choice of going with a block kit, AAL's, or adjustable shackles along with rear shocks and all the proper hardware to install! The shocks are a valved specific to the weight of the Tundra ultimately providing great ride quality for on and off road performance.
    The top mount spacers are a little tricky with their design, all its doing is shoving the factory coilover down giving you lift which could lead to premature Ball joint wear/ failure...
    If spacers are properly installed the spydertrax 1 1/4'' spacers will do just fine and they will not mess with your alignment at all.
    Feel free to PM me with any questions :thumbsup:
    -David
    T-Rex266, 040Tundra[OP] and Law323 like this.
