Hot smell towing up hill?
Discussion in 'Towing & Hauling' started by LJOHNS, Jun 16, 2020.
  1. Jun 16, 2020 at 4:59 AM
    LJOHNS
    LJOHNS [OP] New Member
    I just picked up a new to me 2018 crewmax with 20k miles on it. When towing up a steep grade I smell a hot or burnt smell - only towing up hill. Trailer weighs 4300lbs. This truck has never towed anything before I bought it. Anyone else have this issue?
  2. Jun 16, 2020 at 5:20 AM
    Welcome from NY.
    I've never smelled anything.
    I would definitely go back to the dealer.
  3. Jun 16, 2020 at 5:45 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    How do you know this for a fact? Bought from a friend, family member? Sounds like transmission overheating to me buddy.
  4. Jun 16, 2020 at 5:48 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Cam tower leak? That is how I found out I had it. Oil was dripping on the exhaust shield
    Tundraman479 and ColoradoTJ like this.
  5. Jun 16, 2020 at 5:57 AM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Could be... pressure under load causing oil to leak. That’d be the first thing to check. Well first thing is to check fluids but then check Cam towers.
  6. Jun 16, 2020 at 7:15 AM
    LJOHNS
    I only smell it pulling a grade. If it was a cam tower leak wouldn’t I smell it all the time? I checked all around the heads and see no oil anywhere...
  7. Jun 16, 2020 at 7:28 AM
    LJOHNS
    You first smelled it when towing?
    Lake.Life24[QUOTED] likes this.
  8. Jun 16, 2020 at 7:28 AM
    I would see if it continues to smell “hot” after a few more times towing.
    Like you said, the previous owner never towed with it and probably never got the exhaust/other drivetrain components really hot.
    P-Factor and T-Rex266 like this.
  9. Jun 16, 2020 at 7:32 AM
    LJOHNS
    I thought about that. I doubt it has ever worked that hard before. Just don’t want to get stranded out on the road with the rv...
  10. Jun 16, 2020 at 8:44 AM
    Lake.Life24
    Shawn
    Upstate, NY
    I smelled after going up hills. I don't tow much, but I live in a very hilly area and when I would park I would smell it every time. I had 11K miles the first time I smelled it. Drove around for another 10K miles then had it fixed. Zero issues since the fix. Still will smell burning from time to time but it is just the rubber from the tires because all of my hills are gravel.
  11. Jun 16, 2020 at 5:20 PM
    LJOHNS
    So I crawled under the truck this evening and the drivers side cam tower area is wet with oil. Not a lot but wet on the surface. Not sure if that is the the cause of the burning/hot smell or not but it might be. Looks like it’s going to the stealership to see if I can get it repaired. My old 2007 never had a single issue....
    Lake.Life24 and ColoradoTJ like this.
  12. Jul 25, 2020 at 5:09 PM
    LJOHNS
    Update from the OP: towed this week over the mountains near Cumberland, MD. Zero hot smell. I think the source of my issue was that the truck was just detailed and they sprayed the engine compartment down with degreaser and then the shiny stuff. I think that stuff was burning off with the first tow that weekend I bought the truck.
    Towed very well this week all loaded up. Very happy.
