  1. Jul 23, 2020 at 6:41 PM
    #3691
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    You could just put a plow on the tundra and save you both some time.
    jewsNbrews and Outbound[QUOTED] like this.
  2. Jul 23, 2020 at 6:46 PM
    #3692
    Tundras.com ranch
  3. Jul 23, 2020 at 7:03 PM
    #3693
    Yes it is.:thumbsup:
    1UPPER[QUOTED] likes this.
  4. Jul 23, 2020 at 7:23 PM
    #3694
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Buy a used one. Toro, Honda, Ariens there's not really a whole lot that can go wrong with them and they typically aren't used enough to have major problems.
  5. Jul 23, 2020 at 7:43 PM
    #3695
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    Finally built a sturdy firewood holder
  6. Jul 23, 2020 at 7:54 PM
    #3696
    Outbound
    Aaron
    Northern Alberta
    There's an idea. 2 passes and the driveway woudld be done. LOL
    Honda is #1 on my list. I just need to make sure I don't buy anything that will end up underpowered. The HS621 units pop up now and then, so that's on my radar.
    Boosted4runner likes this.
  7. Jul 23, 2020 at 8:03 PM
    #3697
    atrinh15
    atrinh15 [OP] New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
  8. Jul 24, 2020 at 4:26 AM
    #3698
    Festerw
    Festerw New Member
    04 Tundra DC
    I had an old 1985 model HS55 that I sold last year, it would go through snow over the auger housing in low gear.
    I plowed snow for about 10 years they're nice but also come with their own share of issues mechanically and logistically. You need to plan ahead on where the snow is going to end up, legally it shouldn't leave your property and can't be plowed across streets. If you don't have a lot of room to the side of the driveway your going to end up with a large pile in the front yard and you're going to tear up the grass guaranteed.
  9. Jul 24, 2020 at 5:06 AM
    #3699
    Outbound
    Aaron
    Northern Alberta
    Good to know, thanks! Any particular mechanical issues to look out for?
  10. Jul 24, 2020 at 7:28 AM
    #3700
    Festerw
    Festerw New Member
    04 Tundra DC
    On the plows? If you're buying new not so much but used ones are a crap shoot. Truck side mounts and wiring are stupid expensive if you don't find used specifically for your truck, leaking ram packings if it wasn't used much, water in the hydraulic fluid, damaged wiring/connectors, bent a frames, seized pivot pins.
    On the blowers, not much more than a mower. Belts, oil, and bent auger parts are about it.
    Outbound[QUOTED] likes this.
  11. Jul 24, 2020 at 8:01 AM
    #3701
    Outbound
    Aaron
    Northern Alberta
    Perfect. I'm just gonna go with a blower. No point in a full plow for my city driveway.
  12. Jul 24, 2020 at 10:05 PM
    #3702
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    What....The....F!!!!!
    Complete fail today. Spent all afternoon working on this Fing water feature!!
    Mistake #1- not realizing the bottom of the biggest tall stone, was NOT flat. Makes setting the thing, impossible - the way the water fountain sales place told us to (on pavers).
    Mistake #2 - believing the stone salesman, that the stone weighs 800 lbs, and not 1100 lbs.
    Mistake #3 - thinking that the Kubota that can pick up a 1400 lb pallet, can pick up a 1100 lb rock - 8ft from the bucket. Center of mass.
    Mistake #4 - thinking that a 10ft stick of .180 wall 3x4 DOM tube could hold a 1100 lb rock at the 8ft mark.
    Mistake #5 - thinking I could make a home-made boom with a Kubota.
    Mistake #6 - using 20K lb ratchet straps as boulder-holders - rigging. Had the 1100 lb rock pop off the boom, thankfully I got out of the way. Busted out the 50K lb tow rope, which worked much better.
    At this point tonight, we moved a few yards of sand, we moved thousands of pounds of boulders to the area, laid the felt, laid the liner, and took on the biggest challenge, the center 1100 lb feature rock - and failed.
    I know, I know. The right tool for the right job. I was also taught, make due with what you have. This was a tough one.
    Not sure what tomorrow holds. I need an excavator. The neighbor has one I might borrow.
  13. Jul 25, 2020 at 10:50 AM
    #3703
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Was weed wacking this morning and hit a fresh puppy turd that was in the weeds. Good lord that should never happen again!
    Kung, GODZILLA, scpete24 and 11 others like this.
  14. Jul 25, 2020 at 3:16 PM
    #3704
    Boosted4runner
    WA
    LOL!!!! Disgusting!!
    It’s like stepping in a turd bare foot.
    Been there, done that. o_O
  15. Jul 25, 2020 at 3:21 PM
    #3705
    Boosted4runner
    WA
    Absolutely can not BELIEVE we got what we got done today!!
    During our morning “Speed and Agility” workout - I recruited 2 x 6’6” beasts that helped with the rocks! (One of them is my landscape design buddy).
    I re-rigged the Kubota, and we got to work! Was able to get not only the 1100 lb rock up and stable, but all other 4 fountain rocks, and 4,000 lbs more of other boulders. Soooo incredibly happy and thankful for my buddies helping out. I wouldn’t have ever been able to do this solo. It’s starting to take shape.
    Ran out of the water line tube, so headed to water fountain store and will start installing pump and lines tomorrow.
    For now:
  16. Jul 25, 2020 at 3:25 PM
    #3706
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I'd rather step in one barefoot than with shoes on. Barefoot you can just rinse it off with a hose. Shoes, you have to clean the treads. Yeah, my wife thinks I'm an idiot too.
    GODZILLA, 1UPPER, Baja Mike and 4 others like this.
  17. Jul 25, 2020 at 3:27 PM
    #3707
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    :eek: :puke:
    GODZILLA, 1UPPER, jewsNbrews and 2 others like this.
  18. Jul 25, 2020 at 4:06 PM
    #3708
    Boosted4runner
    WA
    LMFAO!!!!!
    Riiiiight!?!? :rofl:
    GODZILLA likes this.
  19. Jul 25, 2020 at 4:37 PM
    #3709
    JMB
    Chesapeake, VA
    Trust me. With three dogs it happens a lot. I can spend 30 seconds with a hose or 30 minutes with a brush. That's not to say I like it. Lesser of two evils is what it is.
  20. Jul 25, 2020 at 5:36 PM
    #3710
    Man, wtf. Had it wired up but remote light wouldn’t function. It would only work via wall switch
    I tied red and black together opposed to red and blue (light) instructions were crappy and almost texted @1UPPER SOS
    Guest room fan is now done. The other two I installed were not wired the same.
  21. Jul 25, 2020 at 5:36 PM
    #3711
    The fan has led. It’s more white than ugly yellow. It’s just the casing on it
  22. Jul 25, 2020 at 6:44 PM
    #3712
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Went to Home Depot and Lowe’s. Got some soil and sod for my backyard. The stuff I put in a few weeks ago didn’t die, so I decided I could get some more to cover the dirt.
    06804C11-7A73-43D3-A1DE-AD01228EE541.jpg FFE363CD-F90B-4044-ABB4-AAD6427360C3.jpg 75EE2BBF-D9E9-45FF-96FA-3E80E55249A9.jpg
    I might got back tomorrow and get some more to square off the odd corners.
  23. Jul 25, 2020 at 7:04 PM
    #3713
    I need to get 2 rolls of sod. Easy to remove old one or do I need a sod cutter?
  24. Jul 25, 2020 at 7:32 PM
    #3714
    Baja Mike
    South Bay, Ca.
    I think a flat blade shovel and elbow grease would be your cheapest bet.
  25. Jul 25, 2020 at 7:34 PM
    #3715
    Festerw
    Festerw New Member
    04 Tundra DC
    You need a pair of yard shoes. Then you just leave them outside until the next time.
    JMB[QUOTED] and Boosted4runner like this.
  26. Jul 25, 2020 at 7:55 PM
    #3716
    Boosted4runner
    WA
    Yep!! I use some cheap POS things (ironically, that my dog has chewed up) and leave them outside.
    They’re made of rubber.
    Or the muck boots. But normally if I’m not working the crap rubber ones go on.
    JMB and NewImprovedRon like this.
  27. Jul 25, 2020 at 11:04 PM
    #3717
    Boosted4runner
    WA
    I’m missing 30” of tube damnit.
    Wanted to fire this sucker up tonight.
    Oh well. Tomorrow is the day.
    :fingerscrossed:
  28. Jul 26, 2020 at 8:08 AM
    #3718
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    My rubber troweled flooring is installed on my 20 stall horse barn project. It’s amazing how much quieter it is inside the barn now! My flooring installers will start to clean and seal the flooring today and tomorrow. Getting closer to the completion date on this one. My clients are very excited!
    8D2DCBA9-EE57-493E-9AEE-68A83209586D.jpg 5E29438F-F98C-490C-8413-5948477BB4C2.jpg
    Shark Bait, JH5370, Skippy and 15 others like this.
  29. Jul 26, 2020 at 8:24 AM
    #3719
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Took me 8 hours to wrap 4 pho-beam’s yesterday. 4 to go (2 on rear of house). I’ll post some more updates once I get some more features finished. We’re stoked on the outcome so far.
  30. Jul 26, 2020 at 8:34 AM
    #3720
    1UPPER
    TEXAS
    Flux capacitor!
    Looks great! Mind if I make a few suggestion for your window planter boxes?
    Mountun Goat[QUOTED] likes this.
