  1. Jul 23, 2020 at 12:23 PM
    Professional Hand Model
    Fred
    Hand Protectors
    LED Strip Turn Signal Install
    Thrussn, abcinv, bmf4069 and 5 others like this.
  2. Jul 23, 2020 at 1:04 PM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I need to do rear brakes on my 06 DC, anyone have any recommendations on a kit to use? Would love all OEM, but don't have it in my budget right now.
  3. Jul 23, 2020 at 1:08 PM
    Fred
    Hand Protectors
    NAPA shoes for $20 a set.
  4. Jul 23, 2020 at 1:14 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Drums necessary? I have 214k on the truck so might be a good idea.
  5. Jul 23, 2020 at 1:22 PM
    Fred
    Hand Protectors
    Your call but might be able to turn them. OEM drums are best. Others experience problems with aftermarkets so you may be wasting your money if you do this. Also, the OEM have a balance weight on them and aftermarkets do not. Balance is good.
  6. Jul 23, 2020 at 3:43 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    All fixed now! There was a clog inside, preventing the system from holding a charge. Not sure if it was any of that stuff you said. Man, it is such a luxury to have AC during the summer.
    That was my last (hopefully) major repair. Next on the list is body mounts but I'll focus more on the camper conversion now.
  7. Jul 23, 2020 at 3:44 PM
    Fred
    Hand Protectors
    Excellent! Do you have any good reading links for the body mounts?
    theblurry1[QUOTED] and Tundra2 like this.
  8. Jul 23, 2020 at 5:03 PM
    This is more common than you think, and a critical mistake I made when I was retrofitting an old 60s pickup of mine with an LS1 like 15-something years ago. I didn't know it was necessary to vacuum the lines out before charging.
    Off the top of my head, a generic auto AC system works by expanding and compressing the coolant gas you inject into it. Picture compressing the hell out of a gaseous coolant then cramming it through a funnel with a pin-hole at the end of it - that's essentially what happens at the compressor, then at at the orifice tube if memory serves. The result of that process is hyper-cooling the gas, which then passes by tube to the evap coil in your dash, your blower motor blows air through the coil to cool you off. After exiting the coil, the gas passes through the drier valve, then to the the expansion valve, which lets the gas re-expand, at which time it generates shitloads of heat, and gets cooled by the AC radiator in front of the car, then back to the compressor for another round. That's the best I can explain and it's probably inaccurate. Just how I remember it.
    Anyway, long story short, back then I didn't understand how important it is vacuum the lines any time you replace a component so no debris gets in there, and how worthwhile it is to go ahead and replace the orifice tube (if used in your system) and the drier valve in some cases. If you can't vacuum your own lines, many shops will vacuum, test for leaks and recharge for nominal fee. Hopefully you didn't pay too much to have them check.
    I'm guessing they checked for pressure on the low pressure and high pressure sides and found things were out of whack, which led them to vacuum and recharge.
    theblurry1[QUOTED] likes this.
  9. Jul 23, 2020 at 5:46 PM
    Fred
    Hand Protectors
  10. Jul 23, 2020 at 6:08 PM
    Aye, she's wet mate.
  11. Jul 23, 2020 at 6:16 PM
    Fred
    Hand Protectors
    Yeah. Its Himalayan Monsoon Season. Perfect time to climb Mt. Everest.
    Worked on this driver side for 4 hours today. Success achieved on:
    1) Window Rattle Looseness. She is snug now! Greased up the gears and the drivers window beats the passenger by .0345 seconds now. Fairly easy.
    2) Speaker install. Easy.
    3) LED Strip install. It fought me on every angle of attack. Tested the Hand Skills at Black Belt Levels! Glad I broke this one up into 3 Phases. Way too much work, but I’m stoked on it.
    bmf4069 and Tundra2 like this.
  12. Jul 23, 2020 at 6:49 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Well I'm kaput, Bigg day! Steering rack, steering pump, high pressure line, tie rods, sway bushings, sway end links, spidertrax spacers, bleed and test drive....steering wheel is a little crooked and need an alignment. Also need to get wheels re balanced as the shop I had install is filled with kids.
    Anyone ever had a shudder or jumble in the wheel (when lifted off the ground) after rack install. I bled 5 quarts through it to get air out and will probably run synthetic through it after a few days of driving to clear any left over gunk. I put in a in line filter too for good measure.
    NUDRAT, bmf4069 and imDementeD like this.
  13. Jul 24, 2020 at 7:29 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Picked these up for the work golf tournament.
    Brown Bear, abcinv, Lil Steve and 3 others like this.
  14. Jul 24, 2020 at 7:32 AM
    Casper421
    In the woods
    06 DC
    That’s some chilled water right there!
  15. Jul 24, 2020 at 7:42 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    I will say when im on the golf course, the water beers are best for hydration and intoxication.
    bmf4069 and Casper421[QUOTED] like this.
  16. Jul 24, 2020 at 8:34 AM
    04DCTundraMan
    First of many trips whilst moving out. and i needed to return my keg, but had no room in the back, so i got the only thing i can count on, riding shotgun! Click it or Ticket boys!
    NUDRAT, Brown Bear, Festerw and 7 others like this.
  17. Jul 24, 2020 at 8:40 AM
    2 keg posts at the same time? Wow.
    In college I had a buddy go pick up a keg in his Durango. By the time he made it back to the party his back window was shattered out because he never strapped it down. :rofl:
    We were way more concerned about the beer though.
    lsaami, Tundra2, oscardog86 and 2 others like this.
  18. Jul 24, 2020 at 9:12 AM
    Fred
    Hand Protectors
    Operation Turning Zzzzztttanese complete. Success achieved. :yes:
    shifty` likes this.
  19. Jul 24, 2020 at 9:17 AM
    04DCTundraMan
    Lol wow! That’s my fear! I strap it down and hold it. Normally is strapped in the bed but no room. But we leave no soldier behind!
    bmf4069 likes this.
  20. Jul 24, 2020 at 10:40 AM
    Hi there new best friend! Where we meeting up at?
  21. Jul 24, 2020 at 11:03 AM
    Fred
    Hand Protectors
    Truck passed Inspection Today. Good to go for another year.
    Logged all my recent work performed in the Glove Box Log which is 7 pages long now. :D
    Finalizing my ‘To Buy List’ for the Timing Belt Job. Thinking I’ll Cherry Pick the Black Friday Sales in November and pull the purchase strings then.:evil:
    bmf4069 likes this.
  22. Jul 24, 2020 at 11:16 AM
    04DCTundraMan
    I would think mine passes inspection, but we dont have that here in GA. Just emissions once a year and that's county by county.
  23. Jul 24, 2020 at 11:19 AM
    oscardog86
    oscardog86 New Member
    Southern California
    So I have a possibly stupid question but its something ive been curious about.
    Would it be possible to convert a V8 Auto Trans Tundra to manual trans? It must not be feasible because Ive never heard of anyone doing that, but just thought id ask.
    Tundra2 and YardBird like this.
  24. Jul 24, 2020 at 11:28 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  25. Jul 24, 2020 at 11:33 AM
    oscardog86
    Southern California
    Wow that thing looks nice! Must be a fun truck having a V8 manual. Definitely one of a kind!
  26. Jul 24, 2020 at 11:36 AM
    Fred
    Hand Protectors
    Anything is possible with the right amount of...
  27. Jul 24, 2020 at 11:47 AM
    YardBird
    Jonesy
    2005 RCLB
    I have a handyman friend that takes on all kinds of upgrades for his clients.
    He is often quoted in saying;
    "We'll get you that new kitchen of your dreams if it takes all the money you have."
    Same would apply here as you alluded to with the conversion to manual transmission . . .
  28. Jul 24, 2020 at 3:17 PM
    Fred
    Hand Protectors
    Test drove on speed bumps in a parking lot that usually rattle the windows when half way down. They’ve passed the test with the track fix.
    A reminder of these sill jamb stops that keep the large door from jolting down on large bumps. Combo’d up both of these fixes keep the truck quiet when the going gets rough which is mainly on mall speed bumps. :rofl:
    Pictured is the proto-type test form duct taped in place for testing. Once they passed the test I removed the duct tape and added double sided Gorilla Tape for adhesion. Installed a second layer on the ‘bump contact’ side for padding and left it with the contact plastic on so it wouldn’t stick the door shut! The shim is a composite type from big box. Basically any hard plastic that fits will do.
    Tundra2 likes this.
  29. Jul 24, 2020 at 4:29 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I mean if you want to drive up to PA for a beer I'll buy the first round.
    bmf4069[QUOTED] and Tundra2 like this.
  30. Jul 24, 2020 at 7:41 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Finally Finished the rear LED bulb conversion! Attached pic of what I used. No Hyper Flash.
    NUDRAT, bmf4069, shifty` and 2 others like this.
