295/70r18 on Stock SR5 w/TRD Pro Rims
Discussion in 'Wheels & Tires' started by RussellVaughan, Jul 21, 2020.
  1. Jul 21, 2020 at 10:12 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Yesterday I had 295/70r18 nitto terra grappler G2 tires installed on 2019 trd pro rims (+60 offset). the tires are 34.3" diameter and 11.6" wide. no spacers and no trimming...literally no modifications. no rubbing. Comes super close to the front sway bar at full turn, but no rub. just in case anyone else is considering this...I had read numerous places this works on the TRD Pro truck, but couldn't find anyone putting them on stock SR5.
    Btw, I'm doing a 2" fox 2.0 lift in the front and a 1" leaf block in the back, so should look even better. But here are some pics with the stock setup. Last pic is a comparison with the TSS rims with 275/55r20 michielin defender tires (32" diameter and 10.8" wide)
    EDIT: I do have the RCI skid plate.
    Luckydog, EN2TUNDRA, tbutler and 12 others like this.
  2. Jul 21, 2020 at 10:22 AM
    Blueknights75
    Ron
    Clayton, NC
    Not sure how you managed that without modifying at least the skid plate and forward little mud flap. From experience there is no way my 295 70 18 RGs would fit without modifying those two things minus the Billstein level I put on the front.
    Dc2015 and yodanadane like this.
  3. Jul 21, 2020 at 10:50 AM
    RussellVaughan
    Houston
    Good point...I did replace the stock skid plate with the RCI plate. I didn't consider that may be a limiting factor on a stock tundra. But the front mud flap is not an issue. At least 5 mm clearance
    Pic of clearance with front mud flap at closest point:
    EN2TUNDRA, Big J, panicman and 2 others like this.
  4. Jul 21, 2020 at 12:40 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Oh shit this is some good scientific work
    here man.
    This will ruffle some feathers!
  5. Jul 21, 2020 at 1:01 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    With no lift that actually fills it out nicely. Good to know stock suspension can work without a lift. Might just be my next set of tires :thumbsup:
    panicman likes this.
  6. Jul 22, 2020 at 8:19 AM
    ptat
    ptat New Member
    Hmm I wonder if I can do this with my stock TRD OR wheels. They are the same size as the Pro.
    Rdh1223, biebs96 and panicman like this.
  7. Jul 22, 2020 at 8:45 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Please let me know! Especially about the TRD wheels. This is likely the next considerable expense for my mod addiction.
    looks great!
    biebs96 and ItsNickROFL like this.
  8. Jul 22, 2020 at 9:07 AM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    I've been looking at these tires with great interest. This size does look good on the Tundra. What rating are yours, C or E? Have you decided on what PSI you're going to run? When are you installing the Fox 2.0s?
  9. Jul 22, 2020 at 9:08 AM
    RussellVaughan
    Houston
    Probably depends on what the offset is on the trd rims. If it’s same or close to the trd pro Rims then you should be fine.
  10. Jul 22, 2020 at 9:10 AM
    RussellVaughan
    Houston
    i got the e rated tires. They weigh a lot more than the 4 ply so keep that in mind. I’m running them at 44 which is what the ko2s that came with the truck from the factory were at.
    danno266[QUOTED] likes this.
  11. Jul 22, 2020 at 9:25 AM
    ptat
    ptat New Member
    Just out of curiosity. How did you test the suspension to check that there really is no rub?
    yodanadane likes this.
  12. Jul 22, 2020 at 9:44 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    They are the same 8" wide +60mm offset for TRD off road wheels. So it should fit the same. ;)
    TelemarkTumalo and panicman like this.
  13. Jul 22, 2020 at 9:46 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    How did the E rated tires ride? I saw the G2's come in an SL rated that is only 50lbs. Wondering if that will ride nice or be to floaty. :confused:
  14. Jul 22, 2020 at 9:55 AM
    RussellVaughan
    Houston
    Good question. I’ve been driving the truck for a few days now. Done a few full turn uturns. Turned into a few steep driveways. No issues
    ptat[QUOTED] likes this.
  15. Jul 22, 2020 at 9:58 AM
    RussellVaughan
    Houston
    I like them. Def more road noise but I have to listen for it. That’s compared to my Michelin defenders. I like these much much better than the ko2s I used to have before the defenders.
  16. Jul 22, 2020 at 10:41 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Do those Pro wheels have a different offset than the TRD Off Road wheels? My stock setup was fairly close to the stock UCA so i threw on 1.25" spacers to clear it for 295's. That looks great, very surprised you didn't have to trim anything.
  17. Jul 22, 2020 at 11:51 AM
    RussellVaughan
    Houston
    @Big J says they're the same offset. see above a few comments
    Big J likes this.
  18. Jul 22, 2020 at 12:55 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Seems like stock 8 wide +60mm will fit without spacers. Probably very close is my guess. Maybe the OP can get some pics of how close to UCA
    Folks on here with TRD Pro trucks seem to just put 295's on as well without lift. (Pro does have about 2 inches lift over other tundra models though)
    But it seems from this post that 2 inch did not matter much if it fits on an SR5.
  19. Jul 22, 2020 at 6:52 PM
    panicman
    Eric
    RussellVaughan[OP] and Big J like this.
  20. Jul 22, 2020 at 7:06 PM
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Thank you for experimenting with this. Good to know.
  21. Jul 23, 2020 at 8:26 AM
    ptat
    ptat New Member
    How about reversing at full turn?
  22. Jul 23, 2020 at 9:03 AM
    RussellVaughan
    Houston
    i've done full turn reversing..pulling out of parking spots etc. no issues.
    Big J and ptat[QUOTED] like this.
  23. Aug 14, 2020 at 9:58 AM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    @RussellVaughan please post a picture with your lift after you get it installed. Your truck is looking great with the 295's. Thanks for sharing this info with us.
  24. Aug 14, 2020 at 3:57 PM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    I will tell you that running 295/70r18s on the stock wheels is tire specific as far as the rubbing goes. I have Cooper MTs and clipped the driver side sway bar at full right in reverse. Not bad but enough that I tossed spacers on. Nice looking truck!
  25. Feb 5, 2021 at 6:41 PM
    Jembalayah
    Jembalayah New Member
    2021 White SR5 CM
    Wow that’s great! I’ve been mulling over getting these exact size tires on a stock SR5. I don’t want a lift yet since it won’t fit in the garage otherwise (lots of theft in the area lately). Thanks for experimenting! Definitely gonna make the move now.
  26. Feb 5, 2021 at 11:26 PM
    yodanadane
    yodanadane New Member
    You may end up rubbing the sway bar when you lift it. I have a similar setup with OEM TRD-Pro wheels on Nitto Ridge Grappler 295-70-18 with Fox 2.5 Resi Coilovers set at 3 inch in front and 1 inch block in the rear.
    When you lift it depending on the height the steering stops will be higher, and will allow the steering to turn past the stop and the tires rubbed on the sway bar .
    I had Off road Wearhouse weld a small dime sized weld on on the stops which fixed that issue. 20210125_201250.jpg
  27. Feb 8, 2021 at 9:28 AM
    RussellVaughan
    Houston
    CONFIRMED TO BE TRUE. I've been meaning to post an update after I put the Fox 2.0s on. The tires DO IN FACT rub the sway bar when close to full-turn. I don't mind it...since I'm usually moving very slowly when I make turns tight enough to cause the rubbing.
    Side note, which is my bigger complaint. Apparently there is no way to correct the tire size in the computer...dealer says "its encrypted" and there's no way to do it. So I'm stuck with an odometer that reads short and speedometer that reads slow.
    Other than these two issues, I love the tires/rims and lift.
    EDIT: after learning that speedometer calibrators correct odometer too, I installed the rough country speedo calibrator and now my speed and odometer are correct (aside from the permanent difference of approx 700 miles between actual miles driven vs odometer reading caused by driving my truck about 12,000 miles before installing the calibrator.
    yodanadane[QUOTED] and Big J like this.
  28. Feb 8, 2021 at 9:36 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    So at factory height with no lift did you run the sway bars at all? Sounds like no.
    With the added lift is there any difference in distance from tire to UCA? Or did that remain the same?
  29. Feb 8, 2021 at 9:46 AM
    RussellVaughan
    Houston
    Correct, no rubbing on stock suspension.
    This I don't know the answer. But there is no rubbing on UCA.
    Big J[QUOTED] likes this.
  30. Feb 8, 2021 at 10:17 AM
    RussellVaughan
    Houston
    Pics after the lift
