Crux Wireless Radio Infacing harness and Wi-Fi Connectivity
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by TundraTXTSS, Jul 10, 2020.
Thread Status:
Not open for further replies.
  1. Jul 10, 2020 at 12:20 AM
    TundraTXTSS
    TundraTXTSS [OP] New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Wireless Radio Infacing harness and Wi-Fi Connectivity, mirror your cell phone Apple or Android to your Toyota Radio or use it to connect a front camera, Compatable with with the following below. I had this is my 2018 and pulled it out prior to trading it in on a 2020 Tundra.
    3 plugs in harness are used to connect through radio and then connect power to WiFi connenectivty, pleanty of videos and manuals on how to hook this up.All plug and play.
    https://www.cruxinterfacing.com/listings/wvity-01/#1581465524676-db29deb2-ed4f
    https://www.youtube.com/watch?v=1qt4P0SwV28
    VEHICLE COMPATIBILITY
    Toyota
    2012 – 2015 4Runner
    2012 – 2015 Avalon
    2012 – 2017 Camry
    2014 – 2016 Corolla
    2012 – 2014 FJ Cruiser
    2012 – 2017 Highlander
    2012 – 2015 Land Cruiser
    2012 – 2013 Matrix
    2013 – 2016 Prius
    2012 – 2015 RAV4
    2012 – 2016 Sequoia
    2012 – 2017 Sienna
    2012 – 2018 Tacoma
    2012 – 2018 Tundra
    2012 – 2015 Venza
    2012 – 2015 Yaris
    Scion
    2014 – 2015 iQ
    2014 – 2015 tC
    2014 – 2015 xD
    Billytx likes this.
  2. Jul 10, 2020 at 5:51 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Did you have a front camera on this?
  3. Jul 10, 2020 at 7:00 AM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    GLWS. I recently pulled mine out due to an audio upgrade and android head unit...no longer needed. However, it seemed not many folks knew much about these. My experience was awesome. I loved being able to use the stock head unit as video player etc. I had contemplated listing it on here. I'll see how you make out.
  4. Jul 10, 2020 at 7:47 AM
    Billytx
    Billytx New Member
    AnhKiet
    2016 tundra 1794
    Send u pm
  5. Jul 10, 2020 at 12:11 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    I have a front camera but keeping that and was able to view it on the radio screen, I just needed to get a switch to power between the wireless connection for cell phone mirroring and the camera. But yes it worked great when I just plugged the camera into the yellow video input.
  6. Jul 20, 2020 at 4:17 PM
    Drivermcgyver
    Drivermcgyver New Member
    Kevin
    Portsmouth, NH
    14' Tundra DC
    Does someone need a different head unit other than a stock one to use this? or does it basically just make the stock unit work like it has android auto? If so im reallly interested in getting this.
  7. Jul 20, 2020 at 4:20 PM
    buckrub71
    2016 Bronze 1794 CM
    It allows you to mirror your phone onto the head unit...even when moving. You will just need to long press a button on your steering wheel to bypass the "locked while in motion" feature.
    Drivermcgyver likes this.
  8. Jul 20, 2020 at 4:22 PM
    Drivermcgyver
    Kevin
    Portsmouth, NH
    14' Tundra DC
    So I can use the Nav from my phone and it would go right to the head unit? Do you lose bluetooth or is it all stay the same except for the mirroring? If i can get one of these to enable android auto whilst not having to get a new head unit, ill start shopping for one of these.
  9. Jul 20, 2020 at 4:25 PM
    buckrub71
    2016 Bronze 1794 CM
    Correct, you can use your phone navi. What you see on your phone, you see on your head unit. Keep in mind, you'll need to turn your phone to landscape to fill the screen on your head unit. Bluetooth stays connected.
  10. Jul 20, 2020 at 4:28 PM
    Drivermcgyver
    Kevin
    Portsmouth, NH
    14' Tundra DC
    That is some handy information. Thanks a ton, ill be in the market for one of these setups! Beats dropping a few hundred dollars on a new setup when this will do the trick!!!
  11. Jul 20, 2020 at 4:32 PM
    Drivermcgyver
    Kevin
    Portsmouth, NH
    14' Tundra DC
    So anyways, OP, id be really interested in buying this if its still available. Send a cut to BuckRub for all the awesome info!
  12. Jul 20, 2020 at 4:51 PM
    buckrub71
    2016 Bronze 1794 CM
    Dang...was just going to offer you mine. Nothing wrong at all, I just did a complete audio gut and install. Posted my install on this forum. Mine also comes with the toyota specific harness. $75 shipped. The only thing is that I cannot locate my install manual but it's online and VERY simple.
  13. Jul 20, 2020 at 7:01 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Still for for sale, it has the wireless feature.
Thread Status:
