Bilstein 5100's to level
Discussion in 'Suspension' started by Laser145, Jul 15, 2020.
  1. Jul 15, 2020 at 8:12 AM
    Laser145
    Laser145 [OP] New Member
    Taylor
    2020 Tundra TRD Off Road
    None
    So I've read all the threads on level kits, spacers, coil overs, etc.
    If I want to pick up some Bilstein 5100's, middle setting, to raise my front end just a bit, is that all I need to buy? Stock springs still work, correct?
    Alignment still needed after install I assume?
    thanks
    Boerseun and JimboSlice413 like this.
  2. Jul 15, 2020 at 8:30 AM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Yes. Reuse stock spring and get alignment
    Thats all thats needed.
  3. Jul 15, 2020 at 8:35 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    That's it. Good luck and post some pics when you're done
    Laser145[QUOTED][OP] likes this.
  4. Jul 15, 2020 at 8:59 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    You got it all figured out! Good luck.
    Laser145[OP] likes this.
  5. Jul 15, 2020 at 9:08 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I went 5100's all the way around. Fronts on mid setting. Used existing truck springs and got an alignment when done. Love it and no regrets.
    BigSkyTaco and JimboSlice413 like this.
  6. Jul 15, 2020 at 9:13 AM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    Does top setting (2.5”) require anything else besides alignment?
  7. Jul 15, 2020 at 9:16 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    That is what I did on a new set I think they put raised the front 2.5 and the rear 1. I still have the factory tires and decided to not align..
  8. Jul 15, 2020 at 9:21 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    BigSkyTaco and Dorks68 like this.
  9. Jul 15, 2020 at 1:43 PM
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Yup...same. Leveled out perfectly and zero issues with rubbing.
    JimboSlice413 likes this.
  10. Jul 15, 2020 at 1:52 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Not really
    Possibly UCa’s but most likely stock will work.
    you will probably need to raise the rear though or you will be a little high in the front
    Dorks68[QUOTED] likes this.
  11. Jul 15, 2020 at 8:15 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I did this all the way up and RC 1” block In the rear and couldn’t be happier with it. Although my toe keeps wondering outwards and I’m getting uneven ware. So getting some iCon UCA’s pretty soon.
    Dorks68 likes this.
  12. Jul 20, 2020 at 12:59 PM
    RedOakStyle
    RedOakStyle New Member
    Terry
    Waxahachie, Tx
    2020 Tundra Crewmax TSS Off-road
    2017 TRD Pro Grill w Jomax Customs Radar relocation Bracket Bakflip MX4 Bed Cover Bilstein 5100 on all 4 corners, w/ front Struts @ Top Notch ( sits level)
    A26CC6CC-47B9-4233-B3AA-4EE0404F7D12.jpg DB16B4B7-BBC4-4C62-BD4B-D5B6B0961224.jpg Installed Bilstein 5100 on all four corners the front struts are on the top notch which gave me pretty level set up, my rear fender wells sit 1/4 inch higher than front close enough for me. These are stock TSS rims and Tires in my 2020 CM
    bunz559 and Jsnake89 like this.
