Was my Leer cap installed correctly?
Discussion in 'Tonneau Covers, Caps and Shells' started by Highsierraguy, Feb 22, 2020.
  1. Feb 22, 2020 at 5:31 PM
    Highsierraguy
    Highsierraguy [OP] New Member
    Nor Cal
    Just got back from the truck shop and noticed a large gap between the bottom lip of my new Leer XR cap and the bed of the truck. They installed the cap on top of the plastic bed protectors. This shop does a ton of installs so I'm guessing it's correct but just wasn't expecting that much of a gap and wanted to make sure. Thanks!
  2. Feb 22, 2020 at 6:05 PM
    Midway
    Midway New Member
    I thought the same thing about my XQ, but was told it was properly installed. I haven't had any issues at all.
  3. Feb 22, 2020 at 6:35 PM
    Highsierraguy
    Nor Cal
    Thanks a lot
    Midway[QUOTED] likes this.
  4. Feb 22, 2020 at 6:56 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Does it leak when it rains because of the gap??
  5. Feb 22, 2020 at 7:31 PM
    Blue Thunder
    Washington
    I've had three canopies on previous trucks. They're not built to tight tolerances. I'd make sure the gaps are the same on either side. It's easy enough to loosen the clamps and shift it slightly. You can do the same front to back.
  6. Mar 18, 2020 at 2:24 PM
    Evader53
    Evader53 New Member
    I've got the same truck/topper (minus the color).... My gaps are exactly the same. You won't notice it after a while
  7. Jul 3, 2020 at 11:41 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    I ordered my 100XR for my 2020 DC today and the sales person said Leer recently changed the design to make the canopies about 1/8" wider earlier models were tighter and rubbing on the paint.
    6 weeks until I get mine. :(
  8. Jul 19, 2020 at 6:27 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sorry I didn't get around to checking sooner. The gap on mine is a bit smaller than yours. The only time I've really seen any water inside was after pressure washing the truck. Even after a torrential rain storm, I don't generally get any water inside the canopy. There's been a tiny bit near the back recently but I think that's because the glue on the seal on the door let go on one side, which I'm hoping the installer will fix under warranty in the next couple weeks. 20200719_174856.jpg
  9. Jul 19, 2020 at 6:31 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Retighten the hardware after a hundred miles.
  10. Jul 19, 2020 at 7:06 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Totally normal. Any tighter and any small shift would end up rubbing against your paint.
    :thumbsup:
  11. Jul 19, 2020 at 9:32 PM
    Highsierraguy
    Nor Cal
    It was no longer a problem after I tightened the bolts 3 months post install. I was surprised how many rotations I got until it was firmly tight, which lowered the gap a bit.
    Thanks
    Cpl_Punishment and YardBird like this.
