FrontRearAnytimeCamera
Discussion in 'General Tundra Discussion' started by kwebre, Jul 18, 2020.
  1. Jul 18, 2020 at 5:42 AM
    kwebre
    kwebre [OP] New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    Due to Toyota deciding not to put 360 view on trucks I am looking for input. Trying to decide between FRACV2.com or anytimebackup.com. If anyone has any experience using these products I am interested in what u think.
  2. Jul 18, 2020 at 5:57 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    FRAC was really easy to install and works as it should. No experience with the other.
  3. Jul 18, 2020 at 6:01 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have the first version, haven't had any issue with them. They work great for me.
  4. Jul 18, 2020 at 6:16 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    3 things to consider, in my slightly biased opinion:)
    The FRAC harness provides two functions. There’s the obvious camera features but it also Provides access to the VIM function. Controlling VIM allows you to utilize all inputs on your head unit at any time. Without this, some HU functions are disabled while driving.
    I’m not an expert on the other system, but the FRAC Harness will maintain full OEM functionality. So whenever you shift into Reverse, you will always get the rear cam display, regardless of the camera select switch position.
    And finally, I work very hard to support FRAC Harness customers after the sale. If you ever have any issues with your installation, I am only an e-mail or phone call away.
  5. Jul 18, 2020 at 6:22 AM
    kwebre
    2020 Blck Tundra
    Are 2 switches still required for the FRACV2 system. Which camera does the forum use
  6. Jul 18, 2020 at 6:31 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The camera selection is performed with one of the switches and the VIM function is controlled with a second switch. However, if you don’t want the VIM function, you can eliminate the second switch.
    Most guys here are using the Natika front/rear camera. Great image quality, versatile mounting options, and a warranty with great product support.
