2005 Toyota tundra 4.7 V8 Rack and pinion!
Discussion in 'General Tundra Discussion' started by akhero, Jul 15, 2020.
  1. Jul 15, 2020 at 6:43 PM
    akhero
    akhero [OP] New Member
    2005 Toyota Tundra
    I need to have my Power steering rack replaced one shop gave my an estimate of $900 parts and labor for an aftermarket one.
    I can order a genuine Toyota for about $900 is it worth getting an OEM or should i just go with the aftermarket?
    Also need lower and upper ball joint are aftermarket ones good or should i go for OEM?
  2. Jul 15, 2020 at 6:48 PM
    A few people have gone with aftermarket racks from eBay. They have a lifetime warranty. Have you considered doing it yourself? They say it's not a horrible job.
    https://www.ebay.com/itm/153283894390
    As for lower ball joints, you must stick with OEM. Toyota Of Cool Springs has great prices and they offer a forum discount on shipping. You can find info here.
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
  3. Jul 15, 2020 at 8:32 PM
    akhero
    2005 Toyota Tundra
    Thank you!
  4. Jul 15, 2020 at 9:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oem rack is brand new never installed. Most aftermarkets will be reman. Both will work. The Toyota may last longer but you practically have no warranty. Ultimately it’s your choice with what to do for the rack.
    Oem only on the ball joints as state above (known issues with aftermarkets and worn oems ending up with wheels destroying fenders)
    The rack is easy on these trucks. But you will need an alignment afterwards. And the lower ball joints are super easy. Just 4 bolts (USE A TORQUE WRENCH) and the castle nut
  5. Jul 15, 2020 at 10:25 PM
    akhero
    2005 Toyota Tundra
    Yeah i will do it myself it should be easy!
  6. Jul 16, 2020 at 6:11 AM
    Another option for our trucks is a rebuilt factory rack from the Rack Doctor. Between the two, I might go with the first one I linked above from Detroit Axle.
    @Casper421 , didn't you go with this one(ebay, Detroit Axle)? How's yours holding up?
  7. Jul 16, 2020 at 7:10 AM
    Casper421
    In the woods
    06 DC
    Yeah, I regret going with Rack Doctor. Splines and hard lines were beat and bent to shit when it arrived. Tried contacting RD for a month with absolutely no response. The seals are already leaking after 6 months, stay away from Rack Doctor! Plus the rack didn’t look anything like my oem rack. Looks cheap and shouldn’t have installed it but it’s all I had. Gonna find a local shop to rebuild my stock rack.
  8. Jul 16, 2020 at 7:13 AM
    Well damn. That's disappointing. I'm glad I asked. Another member here bought a Rack Doctor unit for his 2nd gen and it failed after ~12 months. I chalked it up to bad luck.
  9. Jul 16, 2020 at 7:15 AM
    Casper421
    In the woods
    06 DC
    No, just a shitty company.
  10. Jul 16, 2020 at 7:59 PM
    empty_lord
    05 rollover special
    The only non factory racks I’ve had any luck with were ones from Napa
  11. Jul 16, 2020 at 9:18 PM
    akhero
    2005 Toyota Tundra
    I might try a cheap one and if it fails i'll go with OE Are there better bushings than the rubber one?
  12. Jul 16, 2020 at 9:21 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I used an eBay Detroit Axle Rack without issues. Also when you use rack bushings get the hard black rubber ones
    the red poly squishy ones flex too much and cause the steering not to be as tight
    texasrho83 likes this.
  13. Jul 16, 2020 at 9:36 PM
    akhero
    2005 Toyota Tundra
    Where do i get those? What about the polyurethane?
  14. Jul 16, 2020 at 9:44 PM
    empty_lord
    05 rollover special
    Energy suspension makes a kit for bushings
  15. Jul 17, 2020 at 7:19 AM
    SouthWestGA
  16. Jul 17, 2020 at 7:57 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    FirstGenVol likes this.
  17. Jul 17, 2020 at 9:12 AM
    Professional Hand Model
    Fred
    Hand Protectors
  18. Jul 17, 2020 at 6:33 PM
    akhero
    2005 Toyota Tundra
  19. Jul 17, 2020 at 6:33 PM
    akhero
    2005 Toyota Tundra
    It says this doesn't work on my 2005 tundra v8
