  1. Jul 14, 2020 at 5:45 AM
    #5641
    Do you have after market coil overs?
    That’s one reason I don’t like the Spc arms; they don’t have a grease zerk on the pivot arms.
    I had a coil making contact w the shock body, but it took a while to track down, sounded like an old squeaky mattress
  2. Jul 14, 2020 at 6:05 AM
    #5642
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Loongie one, formerly known as tranquility base.
    This is where I do all my truck work. A not so rare shot.
    NUDRAT[OP] likes this.
  3. Jul 14, 2020 at 6:06 AM
    #5643
    Yeah I'm running ICON 2.5's up front. Do other control arms have 2 zerk fittings? Didn't realize that. Maybe I can spray the bushings with some silicone lube?
  4. Jul 14, 2020 at 6:14 AM
    #5644
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @bmf4069
    First gen? Best gen.
    Reason one.
  5. Jul 14, 2020 at 6:18 AM
    #5645
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @empty_lord have you been busy, and not told anyone?
  6. Jul 14, 2020 at 6:58 AM
    #5646
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea right.
    I lack the fab skills to sas.
  7. Jul 14, 2020 at 7:05 AM
    #5647
    Yeah if you think that’s where it’s coming from, maybe sway bar bushings too; that are mounted to the frame, maybe even the end links. Total chaos makes a uniball that has zerks to grease the thru bolt bushings. We have them on the 4runner, for the most part they are always quite until the uniballs need some triflow
  8. Jul 14, 2020 at 7:20 AM
    #5648
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Is that a stamped concrete driveway? :ohsnap:
    I want one. More pics of the driveway
  9. Jul 14, 2020 at 3:33 PM
    #5649
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. I did a Hand Model Job for a concrete company. My Hand was the client signing his life away on the contract buying the stamped drive. Got a 50% discount and still overpaid. :rofl:
    I was one of the first in my area to have one when they first came out. Always had people driving by and oooing for the first few years. Its been a nice driveway and cleans up well due to the sealant I put on it every 4 years.
  10. Jul 14, 2020 at 5:14 PM
    #5650
    D9007B09-2CFF-4450-96F5-522D54CD5DCD.jpg Stupid low pressure switch on that ice machine i was working on the other night, shit the bed. Seems to be common on these units, but then it also takes out the contactor(coil) because it just sits there chattering because the LP control won’t make or break properly. Didn’t loose any freon which is good, and didn’t have to open the system to put on another!
  11. Jul 14, 2020 at 5:16 PM
    #5651
    empty_lord
    05 rollover special
    Our backyard is all stamped concrete... looks amazing.
    [​IMG] [​IMG]
  12. Jul 14, 2020 at 5:17 PM
    #5652
    empty_lord
    05 rollover special
    And yes. Those are steel I beams for the deck. The whole deck is steel floor joists. Just like the house.
    Darkness likes this.
  13. Jul 14, 2020 at 5:27 PM
    #5653
    That plastic wouldn't last 1 hour on those chairs if it were my house. I'd be outside every evening.
    CodyP and FrenchToasty like this.
  14. Jul 14, 2020 at 5:30 PM
    #5654
    Azblue
    The Dirty T ( ^_^)_且
    Very nice, but where the hell is the backyard yard wall/fence? Don't they do that out there, how do you pee in the backyard without being seen?
    NUDRAT[OP] and bmf4069 like this.
  15. Jul 14, 2020 at 5:40 PM
    #5655
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    How often should they be changed? Is there a list of preventative maintenance items and how often they should be changed based on mileage? Obviously the manufacturer will recommend sooner than reality so they can sell more parts! I would think iridium plugs last 400k miles and the coils?
  16. Jul 14, 2020 at 6:02 PM
    #5656
    Fred
    Hand Protectors
    Not sure exactly when they should be changed, but I had one go bad so I replaced all of them. Half were all cracked longitudinally which leads to a condition of the spark crossing via the spark plug tube and messing with ignition.
    There is a resistance test you can perform via the FSM.
    Iridium Plugs last 100k miles per Denso. I have two sets of the Manual Spec basic copper core plugs from NGK. I swap them out with each other about 4-5k miles just to keep an eye on the engine health. I’ve also noted the plugs like to loosen over time but maybe because I don’t have a torque wrench although I do follow the Hand Model Sign Language on the side of the plug box. Swapping them and cleaning them gives me something to do.
    MNtundra[QUOTED] likes this.
  17. Jul 14, 2020 at 7:03 PM
    #5657
    Toying with the thought of getting those GX460 calipers from that guy. Someone talk me out of it. They aren't cheap.
    The only downside I can come up with is that I'll have to reactive my Facebook to order them.
    jImmegart likes this.
  18. Jul 14, 2020 at 7:06 PM
    #5658
    Casper421
    In the woods
    06 DC
    Is that the only way to contact him? I sent him a pm on here but he hasn’t been around for months.
  19. Jul 14, 2020 at 7:07 PM
    #5659
    Fred
    Hand Protectors
    Do not do it. Do WL13 and roll the extra money into something else like rebuilding your rear drums (cheap) and some other extras you can figure as you go.
  20. Jul 14, 2020 at 7:08 PM
    #5660
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    What He said. Plus you don't really want to reactivate FB anyway.
  21. Jul 14, 2020 at 7:12 PM
    #5661
    Yeah even when he was on he didn't really respond. Facebook seems to be the only way. You not happy with your powerstop kit?
    The last time I looked that kit was almost as expensive as the GX460 deal so I thought I may as well go all out.
  22. Jul 14, 2020 at 7:22 PM
    #5662
    Fred
    Hand Protectors
    Got off there 7 years ago and never looked back.
    WL13 Front and Rear brakes with about 2 days of work less than $500 total with all new brake lines.
    Last I remember those Big Boy Calipers and all the extras were $1000-1500? Needs New Booster and Cylinder? Cool if you can afford it and want it, but @ FirstGenVol still doesn’t have Big Gurrl Prime because he is too cheap to pay the extra . :rofl:
    Tundra2 likes this.
  23. Jul 14, 2020 at 7:28 PM
    #5663
    It's $350 plus shipping for the calipers. Rotors and pads I would have to buy regardless. No need to replace booster or master cylinder. Maybe you're thinking of something else?
    I steal my Mom's Prime account like a typical Millenial. She still does my laundry too.
  24. Jul 14, 2020 at 7:40 PM
    #5664
    empty_lord
    05 rollover special
    We have no shame out here
  25. Jul 14, 2020 at 7:41 PM
    #5665
    empty_lord
    05 rollover special
    That was the day they were delivered
  26. Jul 14, 2020 at 7:45 PM
    #5666
    Casper421
    In the woods
    06 DC
    The power stop kit was fine but that was before the armor, tires and rack/tent. Last trail run on the long technical downhill, my front brakes were overheating. I only plan to add more weight so the bigger brakes will definitely help. Will probably stick with the oem rotors too.
  27. Jul 14, 2020 at 7:46 PM
    #5667
    empty_lord
    05 rollover special
    I may screw it and try 2nd gen tacoma wilwood brakes eventually.
  28. Jul 14, 2020 at 7:49 PM
    #5668
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Now that I'm on break at work...
    @FirstGenVol
    @FrenchToasty
    @Darkness
    @empty_lord
    Let's back up a minute here and discuss this "squeaky" SPC UCA.
    If that is in fact the culprit of the squeak what are all of your thoughts on having a machine shop drill, and tap to add 2 grease zerks on the pivot point for UCA bolt?
    I have plans for spc/mevotech ucas in the future.
  29. Jul 14, 2020 at 7:51 PM
    #5669
    Casper421
    In the woods
    06 DC
    Damn!! :spending:
  30. Jul 14, 2020 at 7:54 PM
    #5670
    empty_lord
    05 rollover special
    id have to see how the SPC bushings are made. the cambergs have fittings there. to grease the bushings you loosen the upper control arm bolt, grease, then retorque NEVER do it with the bolt torqued or your bushings will be fried.
    FrenchToasty and Tundra2[QUOTED] like this.
