  1. Jul 13, 2020 at 2:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Guys like you, and me are always tinkering, and improving. It will be consumed.
  2. Jul 13, 2020 at 2:57 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I am not a wheel expert, but believe my Patrick Star Fish OEM Model Wheels are the 4.5 backspace 16” and I have 285/75/r16 Michelins. They do rub very slightly on the inside. I’ve been on 285’s for about 16 years. They fit the well nicely and no need for trimming or removing stuff to fit a tire in place.
    Some people report the 285/75/r16 in ‘off road’ tires are too big and rub too much due to the extra side well tread. Michelin Defenders LTX are my 3rd set and are highly recco’d. Quiet. Do well in snow/sand/street/wet. Last long time.
    robabeatle and NUDRAT like this.
  3. Jul 13, 2020 at 3:58 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    man, it’s weird hearing Tacoma noises coming from a Tundra.
  4. Jul 13, 2020 at 4:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :D:thumbsup::rofl:
  5. Jul 13, 2020 at 8:35 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    I use to do that all the time. After driving cross country on i70, I gotta say that smart tap was bliss with all the passing needed.
  6. Jul 13, 2020 at 8:40 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Nice. I need some more red hose!
  7. Jul 13, 2020 at 9:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naw. Everyone with a tundra has red. TRD approved color scheme.
    I like to be just a hair or two different.
    theblurry1 likes this.
  8. Jul 14, 2020 at 4:23 AM
    Fred
    Hand Protectors
    I need one of these.
    NUDRAT and theblurry1 like this.
  9. Jul 14, 2020 at 11:03 AM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Reason I say the sweet spot is I've heard less that 4.5 can cause the wheels to rub the fender/pinch weld, and wears out your LBJs, CVs and other components faster. Larger than 4.5 causes rubbing and most OEM wheels are more than 4.5 except the Patrick Stars PHM has.
    I guess since the big favorites in the toyota community for aftermarket/off road wheels (SCS and FN Wheels) are both offered in 4.5 or less, I think we would heard more negative information if they still had lots of rub or caused accelerated component wear? Tough to pull the trigger on that much money and it turns out you still need spacers or have to live with rub.
  10. Jul 14, 2020 at 11:12 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Ditto
  11. Jul 14, 2020 at 11:13 AM
    notlikejohnny
    In other news, I did the rear diff and T-Case fluids yesterday. Also, both the rear diff and T-case gear oil was bright green. Threw me for a loop when I saw it. Had to look it up. Guess it was a SAE 90 gear oil. Looked great, not burnt (although I dont know exactly how it looked going in), but smell was negligible. Rear diff breather is completely clean, but I'll be installing the extension soon.
    Now for the front diff. Man, what a bear. Ended up stripping the hex drain plug with my 10mm allen socket. As soon as I felt movement I looked and could tell it was deforming. Great. Left it, and a quick search showed that its a common issue. Called my guy and he said to drop it off tonight and he'll have it out by tomorrow morning. And while its in there he said he would take off the broken sway bar link i've been trying to ignore. Extended Suspension Maxx's will go in after that.
    abcinv, shifty` and bmf4069 like this.
  12. Jul 14, 2020 at 11:31 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Without knowing the wheel width there is no such thing as a sweet spot.
    On an 8" wide wheel 4"bs is the goal for 285 tires. You'll have minimal rubbing, if any, on your body or frame. You will rub, but only slightly. You can do mild trimming to stop the rubbing.
    On a 9" wide wheel I would aim between 4 and 4.5", but accept that 4.5" will hit frame with a 285 tire, not bad but it will hit. You will also hit body, you can pull back the fender liner and beat the pinch weld inward to make room. Front bumper you can trim the very corner off of, front mud flaps you can remove or let your tires remove them over time.
    10" wheel or wider, you're on your own.
    NUDRAT and notlikejohnny like this.
  13. Jul 14, 2020 at 11:50 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    I want my wheels and tires to emulate the look in the picture. I dig this look, as you can tell I like 80’s looking AR style wheels and a wider or oversized width tire. How do I get this look on a Tundra?
    jImmegart likes this.
  14. Jul 14, 2020 at 11:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks like a 9" wide wheel with 3.5" backspacing, 305 or 315 width tires and a sawzall.
    :sawzall: start cutting up the truck. Unfortunately these trucks can't stuff much tire without cutting and possibly welding.
    theblurry1 and jImmegart like this.
  15. Jul 14, 2020 at 12:07 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Okay, what about this look? How can a Taco achieve more greatness than the Tundra? Maybe the Hand modeler’s wisdom and conservatism regarding possibilities with our trucks is sadly true? Albeit this reality is lame. :monocle:
    08TXTundra and theblurry1 like this.
  16. Jul 14, 2020 at 12:30 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'd have to write a long novel for that. Believe me I get sad when I see my neighbors '98 Ranger on 35s and I barely fit 33s.
    Here is what 285/75/16 with 8" wide wheels and 4.5 backspacing looks like. Maybe 2" of lift up front, maybe 1" of lift rear, I don't really know how tall my truck is compared to stock these days. It's almost dead level, I'm parked on an incline.Screenshot_20191012-222128_Gallery.jpg
    bmf4069, shifty`, jImmegart and 4 others like this.
  17. Jul 14, 2020 at 12:41 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Gimme your setup with “Tweener” tires and I can be satisfied! Nice looking rig. Though I will need 17’s to fit the 14W bigger brake upgrade?
    empty_lord and Darkness[QUOTED] like this.
  18. Jul 14, 2020 at 12:48 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thanks. Yeah you'll need 17s for those brakes. Width and backspace will be the same. You'll have more tire options, 285/70/17 or 285/75/17 or even 34x10.5x17, the second two will need a little more trimming but it's not anything hard to do.
    MNtundra[QUOTED] likes this.
  19. Jul 14, 2020 at 1:21 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I drove the pcar to Cinci and back on Saturday to help a pcarbro fix his car after letting the smoke out of some wiring, then didn't do a GD thing on Sunday. Drove the Tundra to work on Monday.
    Knock sensor wiring hasn't fixed itself yet.
    Going to have to put together some parts orders soon. Can't have the (41 year old) pcar be my most reliable form of transport.
    bmf4069 and Darkness like this.
  20. Jul 14, 2020 at 1:25 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    thanks! just ordered some!
  21. Jul 14, 2020 at 2:03 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Haha me too, mine just arrived in from Amazon on Saturday. I havent used it yet though
  22. Jul 14, 2020 at 4:26 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
  23. Jul 14, 2020 at 4:32 PM
    empty_lord
    05 rollover special
    You rebadge. I’m trying to find the right emblems to rebadge my tailgate! Lol. 2nd gen black emblems are all meh. Can’t get factory other than tundra and 4x4
    lsaami likes this.
  24. Jul 14, 2020 at 5:50 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    nice, except you put your license plate on backwards :rofl:
    NUDRAT and Darkness like this.
  25. Jul 14, 2020 at 6:08 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Now that I am due for an alignment and the tires on my truck (Ohtsu st5000) dont have too much life left, I also consider the black wheels. Its either go that direction or stay stock. I like your trucks look.
    Darkness[QUOTED] likes this.
  26. Jul 14, 2020 at 6:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thanks. I'd prefer bronze myself but these wheels were free.
  27. Jul 14, 2020 at 6:23 PM
    Are you sick?!
  28. Jul 14, 2020 at 6:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Really, really, really, dark bronze.
  29. Jul 14, 2020 at 6:27 PM
    Looks good. Can I please buy you a bottle of Meguair's Ultimate Black for that trim? :D
    NUDRAT and MNtundra[QUOTED] like this.
  30. Jul 14, 2020 at 6:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Slap a Tacoma badge on there just to mess with people.
    lsaami, NUDRAT, bmf4069 and 2 others like this.
