Largest TRD Pro tire size on stock suspension?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by gregm76, Jul 6, 2020.
  1. Jul 6, 2020 at 3:31 PM
    gregm76
    gregm76 [OP] New Member
    Greg
    2020 Tundra TRD Pro
    I just purchased a 2020 TRD Pro in Super white. I have seen several threads where they say its all stock. Then say there is a shim or wheel spacers added. I want to go with the Nitto Trail Grappler 295/70/18 on stock wheels.
    So what is truly the largest size i can run without modifications other than removing the front mud flap.
    Gotyour6 likes this.
  2. Jul 6, 2020 at 3:40 PM
    Blueknights75
    Ron
    Clayton, NC
    D9936DBB-D91B-4F26-BBF3-9E5395F7C21D.jpg 295 70 18 is the largest you can go without modifications.
    Just leveled mine with the stance of a PRO and just installed 295 70 18 Ridge Grapplers.
  3. Jul 6, 2020 at 4:01 PM
    Welcome from NY.
    This may help....
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    jewsNbrews and Bob like this.
  4. Jul 6, 2020 at 5:20 PM
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Yep, 295/70/18 fits perfectly!
  5. Jul 6, 2020 at 6:05 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I was wondering about that too. Probably do a shim, guessing the shim goes on top of the strut if I go that route.
  6. Jul 6, 2020 at 7:19 PM
    Blueknights75
    Ron
    Clayton, NC
    If you don’t have a PRO like me you will have to trim a little of the skid plate. PRO skid plates are narrower than the normal Tundra skid...
    glowblue likes this.
  7. Jul 7, 2020 at 2:34 PM
    ncomeau35
    ncomeau35 New Member
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I went with the nitto ridge grappler 285/75/18 on my 19' Pro only had to remove the spat. These tires are about 3/4 of an inch taller (35.08" tall) but 1/2 (11.26" wide) an inch narrower than the 295/70/18's (34.29 tall, 11.77" wide)
  8. Jul 7, 2020 at 2:38 PM
    sta_f0u
    sta_f0u New Member
    Jon
    Nevada
    2017 White Tundra Limited 4x4
  9. Jul 7, 2020 at 2:41 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Can we get some pics of your setup and room available?
  10. Jul 7, 2020 at 2:45 PM
    ncomeau35
    I'll get you some tomorrow, it's in the shop getting the sunroof replaced. Someone decided it's be fun to smash it the other night....
  11. Jul 7, 2020 at 2:46 PM
    ncomeau35
    That's just a pic I took the other day, before the vandals struck...no pun intended
    jewsNbrews likes this.
  12. Jul 7, 2020 at 3:07 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That sucks! :mad:
    Truck looks great with that tire size.
  13. Jul 9, 2020 at 2:58 AM
    ncomeau35
  14. Jul 11, 2020 at 6:24 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Let me ask a silly question....what is the part you removed?
  15. Jul 11, 2020 at 6:39 AM
    Blueknights75
    Ron
    Clayton, NC
    The small mud flap looking plastic piece in front of the front tires.
    jewsNbrews and Kbar691 like this.
  16. Jul 13, 2020 at 5:35 AM
    jfisher256
    jfisher256 New Member
    Huntsville, AL
    2019 Super White Tundra TRD Pro
    Like others have said, there are a few 295s that can work with the stock setup. Just for reference and another option, here is my Pro with 275/70/18 BFG KO2s
  17. Jul 13, 2020 at 6:23 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    295/70/18 fallen wildpeak fit
    Lucress likes this.
  18. Jul 13, 2020 at 9:00 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Any rubbing or modifications made to fit this tires?
    I been watching this thread for a few days now because the clock is ticking for my tires, I have to replace them soon later this year and this is the perfect time to get rid of this minivan stock tires
    :popcorn:
    I like the 295s but I don’t want to mess with underbody extreme modifications just want to keep all stock if possible.
    Y0TA PR0 likes this.
  19. Jul 14, 2020 at 5:54 AM
    gregm76
    Greg
    2020 Tundra TRD Pro
    Same here. I want to go as big as possible without any trimming. I dont mind removing the front flaps but thats all I want to do.
    Tundra1078 and iHacker[QUOTED] like this.
  20. Jul 14, 2020 at 6:49 AM
    glowblue
    glowblue From time to time
    VA
    I went with Falken Wildpeak AT3 275/70R18 and had to trim skid plate (non-Pro version). They were $178/tire (saw them for $158 earlier this summer!). The 295s were spendy!
    AircareTundra likes this.
  21. Jul 14, 2020 at 6:54 AM
    Omizzy84
    Omizzy84 Stay strapped or get clapped
    Omar
    New Haven, CT
    2017 White Tundra TRD PRO
    Factory Pro suspension running BFGoodrich KO2's 35x12.5. Only thing I did was remove the front small mud flaps.
    iskoba2, Jman245, GarTX526 and 2 others like this.
  22. Jul 14, 2020 at 7:00 AM
    Blueknights75
    Ron
    Clayton, NC
    You want 295 70 18 then.
  23. Jul 14, 2020 at 7:03 AM
    gregm76
    Greg
    2020 Tundra TRD Pro
    Well you talked me into it. Told my friend that owns the tire shop to have them in by the 30th so i can have them put on the day after i get home from work.
  24. Jul 14, 2020 at 7:50 AM
    Blueknights75
    Ron
    Clayton, NC
    Can’t wait to see it!
  25. Jul 14, 2020 at 8:10 AM
    jfisher256
    Huntsville, AL
    No modifications at all for the 275 KO2s. I had the same mindset in parting ways with the stock Michelins. I was hesitant to go with the 275s over the 295s, but I really like the way they turned. Ride is fantastic.
    iHacker[QUOTED] likes this.
  26. Jul 14, 2020 at 8:47 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    Thanks for the input :thumbsup:
  27. Jul 14, 2020 at 12:22 PM
    glowblue
    VA
    What’s the cost for a set of 295s ?
  28. Jul 16, 2020 at 12:18 PM
    gregm76
    Greg
    2020 Tundra TRD Pro
    I have a friend that owns a tire shop and he told me $1300 OTD on the 295/70/18 Trail Grapplers for me.
    On a side note what was everyone getting for their take off Michelins? Mine will have maybe 1200 miles on them when i take them off.
  29. Jul 18, 2020 at 3:41 AM
    ncomeau35
    I off loaded mine cheap. If I remember correctly like $400 for the set, only had 300 miles on them.
  30. Jul 18, 2020 at 9:53 AM
    Flytrap50
    Flytrap50 New Member
    2019 Toyota Tundra TRD PRO Voodoo Blue
    I know you don't want to trim, but I did BMC and some trimming for $300. I was able to fit 315/70/R17 on it. 35" tires.
    Highly recommend.
    And the trimming was all on the inside. You can't tell from the outside.
    iHacker, Elduder and jewsNbrews like this.
