  1. Jul 10, 2020 at 7:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    jImmegart and empty_lord[QUOTED] like this.
  2. Jul 10, 2020 at 7:12 PM
    Most of us don’t bite......hard. And it’s all in good jest for the most part. I think I walked in at the tail end of marbles disputes.
    I feel like most of the 1sties are more hands on than other gens, so it’s a little easier to communicate, or jerk a chain now and then without getting all; my chicken coop is bigger and less poop filled than yours!!!!!(exactly; what?! Who cares?!)
    I’m not good at documenting or having clean hands, but I will always try to help out someone that’s going thru what I just did or whatever the case may be. Sometimes other people see things differently, you might have a different experience or view point and boom, problem solved!
  3. Jul 10, 2020 at 7:16 PM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    Turn out this year has been pretty low actually. I think it's the combination of a cruise instead of a walk and the fact that there's been a pretty significant increase of infections of this crap locally has really kept people at home
  4. Jul 10, 2020 at 8:01 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This! ^^^
    MNtundra, shifty`, jImmegart and 2 others like this.
  5. Jul 10, 2020 at 9:31 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Darkness and NUDRAT like this.
  6. Jul 10, 2020 at 11:10 PM
    I can't 100% tell, but I'm betting a 2p30A with #10 should be fine.
    Edit: don't listen to drunk Beau; he's dumb. Minimum 2p40, max 2p50, both with #8.
    I've noticed that too. Seems like in the past 6 months posts have picked up. But in the lunch box, what have you done, and post likes, it's just us OGs.
    Dude, my chicken coop is a broken down pos that barely contains the chickens. And the chickens need to be "burped". (I need to bleed my brakes).
    shifty`, CodyP, Tundra2 and 1 other person like this.
  7. Jul 11, 2020 at 4:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't know what the hell is wrong with my browser, or why it keeps showing the same "picture link."
    Anyone else having this problem, or know what to do?
    CodyP likes this.
  8. Jul 11, 2020 at 7:08 AM
    Professional Hand Model
    Fred
    Hand Protectors
  9. Jul 11, 2020 at 7:24 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Couldn't stand my jank city wheel well boxes in my camper conversion. I'd made them out of wood and MDF, they were uneven, falling apart, and too complicated, so I demoed them and finished the new solution yesterday.
    Adhered fancy boi sound deadening foam on top of the Noico while I was in there (and yes, I know typically full coverage = "diminishing returns").
    Reflectix and foil tape vapor barrier. So much easier with spray adhesive.
    Finally leftover vinyl flooring pieces with premium Loctite adhesive finished the covers off.
    It's not perfect, but it they will be inside storage compartments, so my OCD is quenched.
    As you can see from the photos, the furring strips (wood to attach walls/ceiling too) are coming along, albeit quite slowly due to meticulousness.
    oscardog86, hammeron, NUDRAT and 4 others like this.
  10. Jul 11, 2020 at 7:53 AM
    Is that laminate flooring? In a truck bed? That's awesome!
  11. Jul 11, 2020 at 7:55 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I think you are going to want a larger breaker than a 30. A(wire size)
    Says min circuit ampacity 33.
  12. Jul 11, 2020 at 7:57 AM
    That's what I was looking for, but the beer goggles were on. Thanks!
    So a 2p35A w/#8 is the minimum, but it's hard to find a 35, so I'd use a 40.
    TX-TRD1stGEN[QUOTED] likes this.
  13. Jul 11, 2020 at 8:06 AM
    Fred
    Hand Protectors
    @bmf4069 likes a little smoke and fire where he wires. :rofl:
    bmf4069, Tundra2, Darkness and 2 others like this.
  14. Jul 11, 2020 at 8:18 AM
    Fred
    Hand Protectors
    Pulled trigger on these speakers. I’ll be in these door panels one last time (for good I hope) after having them open at least 5-6 times in two years for various sound proofing and lighting projects.
    ‘Operation Turning Zzzzzttanese’ objectives:
    1) Perform front window rattle fix.
    2) Install new speakers.
    3) Dry fit and run wiring for sideview mirror turn signal strips.
  15. Jul 11, 2020 at 8:21 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    For you HVAC guys here, I know nothing about it all but I’m getting a new furnace and A/C unit Monday since my old house system is overdue. Assuming I won’t notice anything difference except maybe a little more efficient system...
    bmf4069 likes this.
  16. Jul 11, 2020 at 8:30 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    Something like that! It's called vinyl sheet flooring and comes in a roll. Underneath that is plywood and an inch of insulation. I'm converting the bed into a nice camper.
  17. Jul 11, 2020 at 9:16 AM
    Don't suppose you have something like this that shows all of the other grounding points for the '06? Thinking mostly about chassis grounds body-to-chassis and engine-to-chassis.
    I need to run around and re-check all of my grounds after I had a no-start after alternator replacement, and to confirm this voltage fluctuation with my gauge isn't related to grounding somehow.
  18. Jul 11, 2020 at 9:20 AM
    Also, a request: Your write-ups are great and pics are worth a thousand words, especially when written all over. Please take pics. Those are two items on my list: Fix rear slider window rattle and fix front door window rattles. I handled Noico install on the outer door during speaker installs many moons ago, but wasn't aware of the rattle fix at that time. I plan to Noico the rear cab wall later this year when my subs and amp install happen and may fix the rear slider rattle (if I find a fix) at the same time.
  19. Jul 11, 2020 at 9:53 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've got a copy of the FSM on my Google Drive. Here's the link for you, it'll be in the electrical diagrams.
    https://drive.google.com/file/d/1ig1nDAjgXtsqQ5nJTTR_aLAlJsCCwXg1/view?usp=drivesdk
  20. Jul 11, 2020 at 10:14 AM
    Awesome, I just yoinked a copy. This is super helpful. Obviously they're not nearly the same as a FSM, but I scored two Chilton's manuals at Goodwill last year, now I can't find them (we have a lot of books). Hoping they didn't get donated right back out. My "better 3/4" is a little OCD on cleaning, whereas I'm more utilitarian "neatly organized chaos" sort of guy.
    Festerw[QUOTED] likes this.
  21. Jul 11, 2020 at 11:14 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    No problem, my organized chaos lacks the neatly part so I spend far too long looking for anything.
    shifty`[QUOTED] likes this.
  22. Jul 11, 2020 at 11:58 AM
    Fred
    Hand Protectors
    NUDRAT and shifty`[QUOTED] like this.
  23. Jul 11, 2020 at 12:01 PM
    Fred
    Hand Protectors
  24. Jul 11, 2020 at 7:40 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I bought a new Kenwood Excelon DDX396 head unit, Kicker 46CSS674 component speakers for the front, Kicker 47KSC6704 speakers for the rear and a small Clarion XC2410 50 watt amp.
    Also got some Noico 80 mil sound deadening material along with some Noico Red 150 mil insulation.
    Finally got everything installed I put the 80 mil on the outer door skin then covered that with the 150 mil insulation. Next on the inner door skin I did the same thing. Also did the back wall. 2 boxes each did 4 doors and the back wall. I have about 8 square feet of each left over. I used a lot of product (over kill)
    The sound system sounds great and the doors have that solid (thud) sound.
    I am so pleased with it that I will be doing the roof and the floor. It's a lot of work, thanks to those of you that have done it, I got the courage to tackle the project.
    The only thing I would have done different would been going to 6.5 speakers instead of 6.75. Install would have been a little easier. I went thru Crutchfield, very happy.
    Darkness and robabeatle like this.
  25. Jul 11, 2020 at 7:52 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    The acoustic isolation work makes quite a difference to the sound quality. The further you dig into it, well it’s another rabbit hole. I finished my stereo install Thursday night and was jamming in the cab the next night. It sounds great. I went with the kenwood excelon dmx76s. Decent amount of tuning control from these units.
  26. Jul 11, 2020 at 7:53 PM
    robabeatle
    AZ
    It is posts like these that pulled me quickly out of lurk mode. Such a wealth of knowledge here and it does seem many do the work themselves which gives us noobs a chance to learn.
  27. Jul 11, 2020 at 8:39 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    I am new here and plan to post and lurk regularly. I have little mechanical experience working on vehicles, but no time like the present to learn! Huge Shout out to Pinay for posting the bulb chart under Best (1st) GEN Info Dump. I truly believe this vehicle could last a lifetime and is one of the most reliable overlanding pickups available. This is why I bought mine from CO with zero frame issues and immediately had it professionally coated. Anyways, today I started my light replacement. Going to work my way from rear to front. Tackled: License Plate, Brake and Turn Signals.
  28. Jul 12, 2020 at 5:30 AM
    Fred
    Hand Protectors
    The FSM is the key for diy. Wish I had it when I bought my truck originally. I like pictures and hard copies when doing the work. A few days prior to working I’ll print up the necessary papers and have them ready on the work bench.
  29. Jul 12, 2020 at 5:34 AM
    Fred
    Hand Protectors
    Did those Sylvania Amber Turns give you hyperflash?
    Never seen those ‘Flasher Stop Lamps’ before. How are those doing?
    I used the Sylvania's in my license assys and like them. Also, have them in the reverse and 3rd lights Cargos. I kept the turns and stop lamps incandescent for fear of hyper flash.
    I see your 3rd Light is not working?
    NUDRAT likes this.
  30. Jul 12, 2020 at 8:44 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I'm starting to see those flashing brake lights around town. I find them annoying, but they are attention getting in a distracted world.
    Along the same line, i dislike hyper flash - but it is attention getting, so perhaps it's actually not a bad thing?
