Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Jul 5, 2020 at 3:05 PM
    #2911
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    You will need a harness from iHacker
    PrestonS[QUOTED] likes this.
  2. Jul 5, 2020 at 3:24 PM
    #2912
    PrestonS
    PrestonS New Member
    2016 White Tundra Platinum
    Thanks! Pretty new and there's tons of pages to comb through, but what is the difference between these?
  3. Jul 5, 2020 at 3:30 PM
    #2913
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Aesthetics. I got the 2019’s. Read through Roman’s first post on this thread, if you haven’t already. There’s a link there to another thread of Roman’s that is specific to the TRD headlights. That’ll answer your questions on them.
  4. Jul 5, 2020 at 9:06 PM
    #2914
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Hello @Roman can you please provide the part number for the fully illuminated (white light color) for the power folding mirrors switch?
    Thanks in advance! :hattip:
  5. Jul 5, 2020 at 9:50 PM
    #2915
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    Are there OEM power folding tow mirrors that include the BSM light?
  6. Jul 5, 2020 at 9:58 PM
    #2916
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    @Roman Can I get a replacement adjustment screw and cannon plug on the TRD Pro Rigid fogs?
    838E01B9-CC2A-407B-B09D-20FFD1D031B3.jpg 27307CA0-D455-4B54-B2EA-57E120161424.jpg
  7. Jul 6, 2020 at 4:46 AM
    #2917
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Aftermarket, yes (most folks go with A1Auto, though the quality isn’t as good as OEM), OEM, no.
    You lose BSM if you install OEM tow mirrors, unless you do the BSM mod to redirect the light to the sail panel. I did it & it works great:
    https://www.tundras.com/threads/bsm-and-oem-tow-mirror-mod.39092/
  8. Jul 6, 2020 at 10:04 AM
    #2918
    PrestonS
    PrestonS New Member
    Hey @Roman, looking into replacing the grille on my '16.
    Can you tell me what else is needed, or if i need everything listed?
    Thanks!
    Platinum Grille - 040 Super White - Toyota (53101-0C040-A0)
    op access panel cover for 2018+ Tundra grille - Toyota (53113-0C010) (Is this required?)
    Emblem Sub-Assembly Rad - Toyota (75301-60020)
  9. Jul 6, 2020 at 10:51 AM
    #2919
    Brlowe
    Brlowe Tundra Owner
    Idaho
    Ok I can do that mod. I'm also going to have to add the wiring for the fold and the new switch.
    What are the correct part numbers for OEM Toyota power folding tow mirrors for a 2020 Tundra CrewMax?
    Uhhhh....[QUOTED] likes this.
  10. Jul 6, 2020 at 11:24 AM
    #2920
    BamaMan44
    Andre
    Tucson
    Roman has a link to them in the first post on this thread.
    GODZILLA and Uhhhh.... like this.
  11. Jul 6, 2020 at 11:28 AM
    #2921
    Brlowe
    Brlowe Tundra Owner
    Idaho
    I saw those links but said for 2010-2013 when I looked at them. I assume they are the same for 2020?
    BamaMan44[QUOTED] likes this.
  12. Jul 6, 2020 at 11:37 AM
    #2922
    BamaMan44
    Andre
    Tucson
    So far, all mirrors from 2007 on work on every model in the same year groups.
  13. Jul 6, 2020 at 11:56 AM
    #2923
    BamaMan44
    Andre
    Tucson
    @Roman i found this number on one of the lights. Not sure if that means anything.
    1190300000592
  14. Jul 6, 2020 at 2:10 PM
    #2924
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    For these here?
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-blade-sgtln-600-sla-85212yzz1ptm
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-blade-sgtln-650-sla-85212yzz1qtm
    They are a Toyota alternative to the OEM blades.
  15. Jul 6, 2020 at 2:15 PM
    #2925
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Parts ordered up!
  16. Jul 6, 2020 at 2:24 PM
    #2926
    Roman
    Roman
    Franklin, TN
    Unfortunately, those only come with the fog lights themselves.
  17. Jul 6, 2020 at 2:25 PM
    #2927
    Roman
    Roman
    Franklin, TN
    That's all you need. The 53113-0C010 is not required, but you'll have a square hole in the top of the grille where the hood closes on it.
  18. Jul 6, 2020 at 2:47 PM
    #2928
    Brlowe
    Brlowe Tundra Owner
    Idaho
  19. Jul 6, 2020 at 3:28 PM
    #2929
    BamaMan44
    Andre
    Tucson
    Copy that. That's what I figured. Thanks Roman!
    Roman[QUOTED][OP] likes this.
  20. Jul 7, 2020 at 7:10 AM
    #2930
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
  21. Jul 7, 2020 at 7:32 AM
    #2931
    Roman
    Roman
    Franklin, TN
    Yes, it is discontinued and has been updated to a new part number. 53101-0C031-J1 is the new part number for the Cavalry Blue TRD Sport grille, and requires a new emblem (90975-02159) and bolt for the new emblem (90167-50063).
    Also, all of the 2018+ Platinum and TRD Sport grilles will be receiving the same treatment. Once inventory is gone for them, they will switch to the new grille and require the new type of emblem.
  22. Jul 7, 2020 at 5:58 PM
    #2932
    18" TRD Off Road Wheels
    Curiosity here, does the new emblem and grille look any different?
  23. Jul 7, 2020 at 6:02 PM
    #2933
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    @paradizecityz is the only one I know of that could officially comment. He mentioned that his camera was not fitting in the original spot under the grille like it did on his stock one.
  24. Jul 8, 2020 at 12:58 PM
    #2934
    Roman
    Roman
    Franklin, TN
    Nope, no different at all. The only difference is how the emblem mounts.
    GODZILLA[QUOTED] likes this.
  25. Jul 9, 2020 at 7:47 PM
    #2935
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Roman, I would like to install the OEM power tailgate lock/unlock kit for my 2020 1794 (part# PK3B6-34JS0). I found the Toyota installation instructions and found this on the page with the link to the instructions: "Conflicts with Bed Lighting Kit"
    I have the LED bed lights as installed pre-purchase. Am I out of luck on the power tailgate lock? Is there a workaround? If no workaround, I would rather have the power lock than the lights but I would prefer to have both if possible.
  26. Jul 10, 2020 at 9:07 AM
    #2936
    Roman
    Roman
    Franklin, TN
    I've looked at both sets of instructions and I can't find where the conflict is. Both sets of instructions only say that each one conflicts with the other, but doesn't explain why. I'm sure there probably is a work around, but what that work around is, I do not know.
  27. Jul 10, 2020 at 9:21 AM
    #2937
    thomasbus337
    2020 TRD Sport DC
    I installed both at the same time. The conflict is with the rubber grommet in the floor. If you have enough slack left in the bed light wiring inside the truck, you can cut the wiring under the passenger side floor board, pull the wiring out underneath and then re run those wires through the new rubber boot in the tailgate lock harness and then re splice them. I probably made it sound more difficult than it really is
    Bakershack[QUOTED] and Roman[OP] like this.
  28. Jul 10, 2020 at 9:24 AM
    #2938
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I also went to the Toyota site and "built" a new truck with both options. It allowed me to do so without saying one was in conflict with the other. Strange! :monocle:
  29. Jul 10, 2020 at 9:26 AM
    #2939
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Understood. Thanks for your reply!
  30. Jul 10, 2020 at 10:30 AM
    #2940
    khaywood9
    khaywood9 New Member
    Do you happen to have a part number for the LED cargo lights that fit a platinum 2020 crewmax? All the ones I find say they don't fit my truck. Just ordered my tailgate lock from you!
