2018 with Leaking Rear Main Seal
Discussion in '2.5 Gen Tundras (2014-2021)' started by HTGreen, Jul 6, 2020.
  1. Jul 6, 2020 at 10:14 AM
    HTGreen
    HTGreen [OP] New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Was under the truck today, 5.7 non FFV, to lube front drive shaft, noticed oil on bell housing at weep hole, smells and feels like engine oil. Anyone else seen this issue on a 2018. Have 31,000 miles, with some towing.
  2. Jul 7, 2020 at 3:37 AM
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    On a side note, I didn't think the 18's had grease-able drive shafts. I know mine doesn't.
  3. Jul 7, 2020 at 3:40 AM
    HTGreen
    Halsey
    Central Virginia
    Mine has them on front shaft
  4. Jul 7, 2020 at 4:20 AM
    TTund16
    TTund16 New Member
  5. Jul 7, 2020 at 4:29 AM
    HTGreen
    Halsey
    Central Virginia
    I looked all over after discovering the oil on the bell housing, no oil appears on oil pan or from the cam towers. Got appointment today with Toyota, I suspect they will add leak detecting fluid and have me come back for them to check. It feels and smells like engine oil.
  6. Jul 7, 2020 at 4:47 AM
    timsp8
    NY
    My 2010 had the rear main seal replaced twice. Don’t remember the mileage, but one was under factory warranty and other under extended warranty. So I feel you. It does happen with this drive train.
  7. Jul 7, 2020 at 5:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  8. Jul 7, 2020 at 6:16 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That stuff is not a good idea. The product works by swelling the seal for a tighter fit but the seal is compromised and will eventually fail again. The issue is that the chemical has the same result on every other seal in the motor.
  9. Jul 7, 2020 at 6:25 AM
    Rex Kramer
    Georgia
    I've never read anything about it swelling rubber seals, do you have a link to any documentation?
  10. Jul 7, 2020 at 6:28 AM
    Cthulhu
    And also, looks like OP’s ride is still under warranty...let the dealership fix it.
  11. Jul 7, 2020 at 6:52 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How do you think it repairs the seal, magic. Google it.
  12. Jul 7, 2020 at 6:54 AM
    Rex Kramer
    Georgia
    Lol, that's a non-answer.
    My searches reveal no problems.
    That being said, a warranty repair at the dealer is what is required here.
  13. Jul 7, 2020 at 8:27 AM
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    My rear main was leaking on my 2017. Toyota found the problem was the second oil pan. It was deformed from the factory and leaking down to that location. Had to pull the motor to get to it. But they replaced it and I haven’t had any problems since.
  14. Jul 7, 2020 at 9:00 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Second oil pan?!
  15. Jul 7, 2020 at 9:08 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    There is an upper and lower oil pan. I assume he meant that the upper was leaking.
    JohnLakeman likes this.
  16. Jul 7, 2020 at 10:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty sure my rear main is leaking too :mad:
  17. Jul 7, 2020 at 10:48 AM
    HTGreen
    Halsey
    Central Virginia
    They kept my truck, they said definitely there is a leak, put me in a 2019 Tacoma TRD on their nickel, why they free up a master tech to pull the transmission/transfer. No bull shit about adding tracer fluid and having me bring it back.
    GODZILLA likes this.
  18. Jul 7, 2020 at 10:50 AM
    havasuTRD
    Brett
    Yes the upper. Toyota said they have a lot of imperfections with the molds. They ordered 2 and one was worse than the leaky one!!!
  19. Jul 10, 2020 at 12:40 AM
    HTGreen
    Halsey
    Central Virginia
    They ae telling me I won't get my truck back until the middle of next week, I guess their master techs are not working overtime, or there is more non-warranty work to keep them busy. I'll just keep driving their loaner Tacoma's wheels off.
  20. Jul 10, 2020 at 5:17 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There was a problem on certain years of Tuundra that had a problems with couple of locating dowels that are used to position the rear main seal housing. The supplier of the dowels had made them slightly to long and they prevented the rear main housing from sitting flush with the block and would cause the leak. Make sure you mention that to them when they remove the tranny because if they just just change the rear seal you could still have the leak.
    jtwags, blanchard7684, rodm1 and 4 others like this.
  21. Jul 10, 2020 at 5:36 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Dang, that's good info @Ruggybuggy. Only way to find that out is to be in the bizness. :thumbsup:
    TTund16 and Ruggybuggy[QUOTED] like this.
  22. Jul 10, 2020 at 5:38 AM
    JohnLakeman
    Yes, but is it covered by warranty, or will you find out later you have a very expensive Taco rental? :D
  23. Jul 10, 2020 at 9:54 AM
    HTGreen
    Halsey
    Central Virginia
    It's warranty, truck is 2018 with 31,000.
  24. Jul 10, 2020 at 12:08 PM
    JohnLakeman
    Ah, yeah, I had yours confused with a concurrent thread with leaking rear main @ 98K+. For that, Toyota is going to need to accept the blame.
    Congrats. Great news, and good service (Taco loaner). :thumbsup:
  25. Jul 10, 2020 at 4:03 PM
    TTund16
    TTund16 New Member
    very good info!
  26. Jul 10, 2020 at 4:19 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Great Info in this thread.
  27. Jul 12, 2020 at 4:20 AM
    HTGreen
    Halsey
    Central Virginia
    I got my truck back on Saturday, they said the rear seal retainer plate was leaking, not the seal itself, they resealed it. Time will tell, I'll watch the bell housing for a leak.
    Vr0ck likes this.
  28. Jul 12, 2020 at 6:33 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did they replace the dowels? That's exactly what happens when the defective dowels are installed. I would have had them replace the rear main seal as well. Might as well start with a new seal even if I had to pay for the part.
  29. Jul 13, 2020 at 5:59 AM
    blanchard7684
    blanchard7684 New Member
    High quality information here...thank you very much.
    Do you know what years were primarily affected?
  30. Jul 13, 2020 at 6:27 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm sorry I dont recall but thought it was 2018. I remember a customer had bought a new Tundra and after she drove it for a couple of months the truck was dripping oil on the driveway. When it came in we verified the leak and Toyota confirmed a problem with the dowel locating pins manufactured slightly too long. New pins were sent and the problem was fixed but the customer still didn't want the truck back and insisted on a new one. We had a few after that but Toyota corrected the problem quickly.
    TTund16 likes this.
