12 mm bumper bolt specs help!
Discussion in 'General Tundra Discussion' started by Peteway, Jul 5, 2020.
  1. Jul 5, 2020 at 7:09 PM
    Peteway
    Peteway [OP] New Member
    2019 5.7 CrewMax 4x4
    Long story short, a local shop sheared the bolt head off the 12 mm bolt in the pics. Does anyone know the specs of this bolt and where to get one? bonus points for tips on how to remove it.
    This is on a 2019 Crewmax 5.7
    Thanks in advance
    lg_fEYZ52oue2n2qOCmg3qlRimj7Emt7qWTsUQsq_243314c88c8a9bf5d2d67dc401bf9212a25f3a31.jpg
    _iXNxBNDpznJ3wntlYXrtm6Zb0y0szwo_eKI9oO4_5d5ccc2f629932644854f7e06a2a5666f4402a9d.jpg
    ACtC-3dPS2K8PEjfmRJLc71iE_zzwvTn1xCMVhac_877f4a260d708eddf9450cc81ddecc5001b41299.jpg
    one more just for fun....
    N8fM81ZgmIwLbj0n_Ed9MhihyN1I8fB_ROcft0po_6c6d9fc00f981b2b3dc72191ea47cf09e8e244bc.jpg
  2. Jul 5, 2020 at 7:20 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I’m curious to know too, I stripped one this weekend....
  3. Jul 5, 2020 at 7:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll offer some advice, but bear in mind I literally know nothing about 3rd gens.
    It seems to me that you can remove the other bolt (circled in blue) and peel back your wheel well liner? (In red.) That should at least let you investigate a potential through hole.
    If you see the "bolt stud" you should be able to get irwin vise grips on it (curved jaw) and lock them on. Turning the bolt out.
    After its out I would go to a local big box store (lowes, rural king, home depot.) Anywhere that has a decent hardware aisle with a bolt bin. They should have thread sizes there. If you can't figure it out there ask a staff member. That's what they are there for.
    BravoDeltaRomeo likes this.
  4. Jul 5, 2020 at 7:31 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You may have to jack your truck up, and remove your tire to have room to work.
    Be sure to use jack stands! Do NOT trust your LIFE on a 12 cent o-ring in a hydraulic jack!
    NewImprovedRon likes this.
  5. Jul 5, 2020 at 7:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just saw another bolt on the right.
  6. Jul 5, 2020 at 7:59 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  7. Jul 5, 2020 at 8:03 PM
    Blueknights75
    Ron
    Clayton, NC
    It’s the same spec as the other 12 mm that is next to it. Use a tap and dye to remove. @Roman can get you that screw....
  8. Jul 5, 2020 at 8:08 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    No need to jack truck up. I broke one too. They are easy to cross thread if not careful. I have not fixed it yet. Drill it out and retap is one option. I bought a u nut and bolt but not sure if it will work. I am going to pull the liner and try to back it out.
  9. Jul 23, 2020 at 3:27 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Sorry didn’t get to follow up on this, it I finally got around to get the bolt. I think it was 1.75 with tax for it. Attached is the info if your still looking it.
  10. Jul 23, 2020 at 3:43 PM
    TundraGuy68
    TundraGuy68 New Member
    Use an easy out. You can buy a set at your local auto parts store. Drill a small hole in the bolt, insert the easy out and use a wrench or socket to back the bolt out.
  11. Jul 23, 2020 at 3:46 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I just ordered them online and picked up at a dealer the next day for under 2 bucks each.
    Not complicated.
  12. Jul 23, 2020 at 4:09 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Mine is stripped and stuck in the nut by a few threads as far as i can tell.All it does is spin and i cant remove it unless i cut it and even then i cant replace it as it spins and spins like the nut inside is broke or something.Body shop did it not me.I found it after i got the truck back.I removed the other 1 on and the other 2 on pass side and applied anti seize and screwed them back in by hand then tightened them.I bought a few spares.Crap design by Toyota in my opinion.
  13. Jul 23, 2020 at 6:40 PM
    Peteway
    THANK YOU!!!!
  14. Jul 23, 2020 at 7:06 PM
    Claychiz
    Claychiz New Member
    Clayton
    2016 Crewmax Limited
    I took the whole front of my truck apart to get the chrome wrapped. Long story short, there are 4 of those pathetic 12mm bolts on the bottom and and 3 of them broke off. Drilled, heated, used chemicals and nothing. They are locked in there. Had to order 2 new bumper brackets to get it back together properly. Good luck!
  15. Apr 6, 2022 at 5:32 AM
    WhiteSmoke4x4
    WhiteSmoke4x4 New Member
    Phil
    2014 Double Cab SR5 Off-Road 4x4
    I did the exact same thing yesterday when I was taking my rear bumper off to fix a dent. First bolt I went for a cranked on it and the thing sheared right off. Apparently those bolts get pretty snug especially if you live in a rust prone environment. Rest of the bolts I proceeded with caution and a lot of wd40. I washed the bolts off with wd-40 and they looked almost new when I put them back on. As far as getting that bolt out a screw extractor your best bet. Hardest part is acquiring the oem 12mm bolts. They are not cheap.
