Air flow thru vents
Discussion in 'General Tundra Discussion' started by TCR, Jul 4, 2020.
  1. Jul 4, 2020 at 11:58 AM
    TCR
    TCR [OP] New Member
    08 Toyota Tundra
    Have 2008 Toyota Tundra air flow thru vents was never very strong ( has dial knob) . Last night after I was at idle air flow was getting lower then higher then low again almost shut down then blasted the best it ever has ( only owned for a year appox. Then it went back to the was it was. On high it seems like it on number 2 if I had four speeds.
  2. Jul 4, 2020 at 12:03 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Have you checked the cabin filter?
    frichco228 likes this.
  3. Jul 4, 2020 at 12:14 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    ditto. that thing may be crusty!
    Rex Kramer[QUOTED] likes this.
  4. Jul 4, 2020 at 12:26 PM
    TCR
    TCR [OP] New Member
    08 Toyota Tundra
    New something is going on with flow can hear fan work well then slows down almost shut off
  5. Jul 4, 2020 at 1:04 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If it were an old Toyota, I would say that sounds like a failing blower motor resistor to me. Back in the day, you would start losing speeds one after another until your blower motor didn't run anymore. The late model Toyotas have electronic boxes that set fan speed, but you could still have a box that's headed south. You need access to a 2008 Repair Manual, or maybe @Roman can help you out.
    Roman likes this.
