Pedal Commander and error code P2121
Discussion in 'Performance and Tuning' started by Dano8855, May 16, 2020.
  1. May 16, 2020 at 11:45 AM
    Dano8855
    Dano8855 [OP] New Member
    2018 Tundra Limited
    I'm having a weird issue with my pedal commander in my 2018 Tundra. it has worked fine for about four months, and now I'm getting blinking dash lights, tow brake error message, and the P2121 code.
    The P2121 code is an error with the accelerator pedal position sensor.
    I have disconnected the battery and it clears the code and all the blinking dash lights. I have also removed the pedal commander and everything is fine. I re-install the pedal commander and then randomly I get the error again.
    So, has anyone had issues with the pedal commander throwing a P2121 error code? Could I have a malfunctioning pedal commander?
    Appreciate the help.
  2. May 30, 2020 at 3:20 PM
    Bear_Murray
    Bear_Murray New Member
    Logan
    2016 SR5 Black Tundra
    NONE YET
    i got the code P2122 Throttle/pedal postion sendor/switch "D" Circuit Low Input on my 2016 SR5, waiting to hear what PC says about it. It turns my traction off and check engine light comes on for me.
  3. Jun 1, 2020 at 5:15 AM
    Dano8855
    2018 Tundra Limited
    Thanks for posting. Please share what PC tells you.
    Thanks,
  4. Jun 1, 2020 at 5:39 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    bulldog93 likes this.
  5. Jun 1, 2020 at 6:23 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Save some money and just use the tow/haul button.
  6. Jun 1, 2020 at 2:34 PM
    Bear_Murray
    Logan
    NONE YET
    Here is what I did, disconnected the PC, unpluged the battery cables for 10 mins to get rid of codes, and then re-installed it. just programmed it and no code is being shown. hope this helps.
  7. Jun 1, 2020 at 2:41 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Same exact conditions. Got stuck in limp mode 300 miles from home. Sent it to PC (still under warranty) and they said they reprogrammed it. Runs fine now for three months. Skeptical.
  8. Jun 1, 2020 at 3:14 PM
    Bear_Murray
    Logan
    NONE YET
    Very. if it codes again, its going back for good.
  9. Jun 1, 2020 at 3:52 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    man this is not what I want to see. I have a 2018 just installed PC a month or two ago. Long trip coming up in August right in time for it to screw up. Maybe I should just take it out before going...?
  10. Jun 1, 2020 at 4:24 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    Keep an eye on your warranty date.
  11. Jun 1, 2020 at 4:28 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    I bought a scan tool to eliminate the codes if it does it again. This past winter, I got stuck in the woods in Northern California while steelhead fishing with the P2121 code and the five-hour journey home took almost nine hours in limp mode.
    Lesson learned: Have a back-up plan.
    chugs likes this.
  12. Jun 1, 2020 at 5:09 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    that is awful. Fingers crossed no issue yet, I’ll keep running it until my trip but I will most likely disconnect just to be on the safe side. Will have wife and kids with me so that shit won’t fly.
  13. Jun 1, 2020 at 5:55 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    If it does cause codes, remove it, disconnect your battery for 10 mins to reset the codes (don't reinstall the PC), and you're back on your way. Don't let a tiny issue like that cancel your trip. I have had my PC for 4 months now with NO issues at all.
  14. Jun 1, 2020 at 7:18 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    I wish I had known this before. Thanks!
  15. Jun 29, 2020 at 4:33 AM
    BAZZMAZZA
    BAZZMAZZA New Member
    B-ROCK
    2017 TUNDRA Crewmax
    Did
    Still having issues with the pedal commander? How did PC handle your issue?
    Thanks in advance.
  16. Jun 29, 2020 at 6:40 AM
    Dano8855
    2018 Tundra Limited
    Any updates from PC regarding this?
  17. Jun 29, 2020 at 6:47 AM
    CaptainGrumpus
    Maine
    Get a Signal Booster and trash the PC. PC is a copy of the Signal Booster and does too much other shit that just complicates things more than they need to be.
    Im not sure if there is any merit to it but, I’ve read that people have better luck with the non-Bluetooth models of the PC if that’s worth anything.
  18. Jun 29, 2020 at 7:01 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I sent my PC unit in for diagnostics and they were very professional and courteous. I had the surge issue going on and it had a hard time connecting through BT when my phone had its WiFi enabled. Due to COVID-19 they took a while before allowing me to send it in but when I did they didn't take long getting it under the knife. Apparently there was a wire that had come loose (most likely from plugging and unplugging but I got this unit used so I don't know what was done to it before me).
    Anyway I'm highly pleased with how they handled the whole thing.
  19. Jun 29, 2020 at 2:32 PM
    bjohnson425
    bjohnson425 New Member
    Brandon
    I don’t think the PC is needed at all on the tundra. I traded in my 4 runner for a tundra and to my surprise they both used the same modem PC. Even in city 1 on the PC the throttle is FAR too touchy then if you go to Eco +4 which should be the next closest setting and it is super laggy. I took it out and am pretty happy with stock. I may keep it just for towing but will likely sell it here soon.
  20. Jun 29, 2020 at 3:19 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you're lifted with big tires I could see it making more of a difference.
    CaptainGrumpus likes this.
  21. Jul 3, 2020 at 2:52 PM
    Bear_Murray
    Logan
    NONE YET
    all i did was disconnect battery and made sure my key-fob was more than 30 feet away and re-installed the PC. Works like a dream now and have a ton of fun showing it off.
    texasrho83 likes this.
  22. Jul 3, 2020 at 3:20 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    what ?!! ive been running mines for a year on my 16 SR5 and its been running great was this a defected PC ?
  23. Jul 4, 2020 at 6:17 AM
    CaptainGrumpus
    Maine
    That’s pretty much what the Hypertech is made for
  24. Jul 4, 2020 at 6:33 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    From my understanding Hypertech merely adjusts your speedo to show the correct speed you're going.
  25. Jul 4, 2020 at 6:35 AM
    CaptainGrumpus
    Maine
    I just checked out their site. I stand corrected. The React model looks nice but $400???
  26. Jul 4, 2020 at 6:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If the various settings are good for the appropriate terrain I could see that being quite alluring for the offroad crowd. However most guys I know would say that all that comes with time and practice (knowing how to drive in mud, snow, on trails etc)
