Do I have a problem with my Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Nov 29, 2016.
  1. Jan 11, 2017 at 8:40 PM
    #61
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Been a month now. Inquiring minds want to know. What did they find?
    Cat3ILS likes this.
  2. Jan 12, 2017 at 3:47 PM
    #62
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    They put dye in the oil and checked it after 2 weeks and said it was not leaking. I don't believe it, because I still smell burning oil occasionally (a lot less than before). I will have them check it again in a couple of weeks.
    Hughjanice and NewImprovedRon like this.
  3. Jan 12, 2017 at 5:39 PM
    #63
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    The nose always knows...
    Motor71, Crewmax Chris and Abrams65 like this.
  4. Jan 12, 2017 at 10:04 PM
    #64
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Thanks for the update. Let us know...
    NewImprovedRon likes this.
  5. Jan 13, 2017 at 6:36 PM
    #65
    Hughjanice
    Hughjanice New Member
    Hieu
    2015 Toyota Tundra CM 4x4
    Two single led light bars behind grille, bak revolverx2, fn 18" wheels, bfg ko2. 46gal transfer flow tank.
    Interested in how they take care of it this time around. Just noticed mine leaking during my 30k service interval. Appointment set for Tuesday to see how they approach this one. Mine has absolutely no oil near the valve cover, only oil on the RTV.
  6. Feb 16, 2017 at 4:55 PM
    #66
    gdiep
    Syracuse, New York
    Update for everyone...just got my truck back after the dealership had it for 2 days. This is the fourth time I've brought it there for the oil issue. The first time, they replaced the valve cover gasket. The second time they put dye in the oil. The third time they said they could not see any oil leak even with the black light and dye. The fourth time, they acknowledged that it was leaking from the cam tower on the right side. They replaced the cam seals.
    Just got it back today and only time will tell if they did it correctly or not. The only positive side is that I was due for an oil change and they did it as part of the repair.
    The dealership has been cordial every time and given me a loaner while they tried to figure out what was going on. However, from day one, I asked them to check for a cam tower leak. It took them 4 times to finally diagnose and fix this. Hopefully, I can close the book on this saga. Crossing my fingers.
    I bought my truck with an extended toyota warranty up to 6 yrs/75k miles so luckily i've got plenty of warranty left.
  7. Feb 17, 2017 at 5:44 AM
    #67
    Sixpack
    Sixpack New Member
    Central Florida
    Glad they finally figured it out. Should have listened to you the first time....
  8. Feb 17, 2017 at 5:55 AM
    #68
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'll cross my fingers for you too
  9. Feb 17, 2017 at 11:51 PM
    #69
    Cat3ILS
    Thanks for posting the update. Appreciated.
  10. Feb 24, 2017 at 1:55 PM
    #70
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I shouldn't of looked under my truck behind the wheel well :(.
  11. Feb 24, 2017 at 1:56 PM
    #71
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Can this get worse is I just drive it like that. Truck is only two years old :(
  12. Feb 24, 2017 at 7:43 PM
    #72
    gdiep
    Syracuse, New York
    I'm not a mechanic, so maybe someone else can chime in, but I drove with the leak for about 4 months before it was finally fixed (hopefully fixed). Make sure you tell them to check for leaking at the cam tower seal. The first time they tried to fix mine, they replaced the valve cover gasket which was not where the leak was coming from.
    Y0TA PR0 likes this.
  13. Feb 24, 2017 at 8:24 PM
    #73
    Get that fixed and documented. I can't remember the cost when it is out of warranty, but it is over 2k dollars.
    And yes, it can get worse.
    4x4_Angel and NewImprovedRon like this.
  14. Feb 25, 2017 at 7:47 AM
    #74
    Tony31
    Tony31 New Member
    I have the same symptoms as the OP. My 2015 dbl cab 5.7 went in for front/rear diff & trans case fluid change at 30K. I had frame corrosion treatment when I purchased the truck. I thought maybe it was overspray that was causing the smell. I told the Service Manager of the undercoat and described the smell. I also told them about this thread and I wanted them to check the entire engine. They found a small leak on the right hand (bank 2) cam housing that was dripping on the exhaust. Service Manager said he'd call me Monday to schedule the repair which is a warranty item. The truck will be there overnight, as suggested by one of the other members here. I'll get a free loaner vehicle. I've been very impressed with the way my dealer has handled this situation.
    Front/rear diff & trans case fluid change was $231.
    Sounds like they tear the motor apart for this. If this happened to you would you trade in for a new truck?
  15. Feb 25, 2017 at 11:09 AM
    #75
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Will do I take it in on Monday. Mine is leaking from both side. How does yours drive? Any difference in performance? Does it still feel solid?
  16. Feb 25, 2017 at 11:10 AM
    #76
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Ya your right will get it fixed.
  17. Feb 25, 2017 at 11:17 AM
    #77
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Well mine is leaking from both side! It really sucks. This is the first vehicle I buy brand new, and kinda get sick to my stomach to know they will have to tear the motor apart, will this effect it performance once it's fixed, will it be as reliable, how will it drive, will I be able to tow. So many questions go through my mind. I love this truck. Don't really want to trade it in cause I kinda made it my own, and what if I trade in and the next one has the same issue?
  18. Feb 25, 2017 at 5:02 PM
    #78
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    So this where I found the oil leak on both side, so I clean it up and I went out today and I let the truck idle while I went in the store, came home and nothing no leaks. So I dunno, does it take a while to start leaking again?
  19. Feb 25, 2017 at 10:22 PM
    #79
    gdiep
    Syracuse, New York
    I have not noticed any difference in the way the tundra drives. I think the leak has been fixed since i can no longer smell any burning oil or see any. I think these tend to be very small leaks, at least mine was. Mine was only on the passengers side.
  20. Feb 25, 2017 at 11:06 PM
    #80
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Subd
  21. Feb 26, 2017 at 4:45 AM
    #81
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Just read this thread and been searching others, has Toyota resolved this issue on 16-up tundras? Is it as common as it seems?
  22. Feb 26, 2017 at 9:30 AM
    #82
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Nope, there is some 16s that leaked too
  23. Feb 26, 2017 at 11:44 AM
    #83
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's what I was afraid of. Getting ready to pull the trigger on a 2017 and was hoping they had this ironed out. Toyota doesn't have many issues but boy when it dies happen they let it plague them for a long time.
  24. Feb 27, 2017 at 12:52 PM
    #84
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    So took my truck in this morning and I wasn't there 20min and the mechanic knew right away where it was leaking from, said cam housing was leaking both side. Is that same thing as cam tower?
  25. Feb 27, 2017 at 4:47 PM
    #85
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep.
  26. Feb 27, 2017 at 5:03 PM
    #86
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sweet thanks. Hopefully they get it fixed right the first time. At least they know where it's leaking from.
  27. Feb 27, 2017 at 8:00 PM
    #87
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Wow. Customer bings you a problem. Customer tells you exactly what is causing that problem, and it takes you 4 tries to figure it out. Now that's some first class diagnosis, right there.
    As cordial as they may be, I think I'd be looking for a different dealer. Some of the nicest people I know are completely incompetent. I don't let them work on my truck either.
    Masshole and NewImprovedRon like this.
  28. Feb 27, 2017 at 9:08 PM
    #88
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    wow this is scary if out of warranty. Is this an issue with all 5.7 Tundras? I wonder how many Tundras are affected by this.
    Glad you resolved yours under warranty OP
  29. Feb 27, 2017 at 9:13 PM
    #89
    TheBeast
    TheBeast The Beach
    newer gens I think.. starting 2014 or 2015..maybe a bad batch of supplier parts at the time.
    BlueBottle likes this.
  30. Feb 27, 2017 at 9:17 PM
    #90
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You would think they ironed out all the issues of a 10 year old motor instead of making it worst.... Things like this makes me want to purchase extended warranty...
