tundra trd Offroad wheel fittment
Discussion in 'Wheels & Tires' started by Seth, Jun 30, 2020.
  1. Jun 30, 2020 at 4:53 PM
    Seth
    Seth [OP] New Member
    2016 white tundra ted Offroad
    2.5"Bilstien lift
    I have a 2016 TRD Offroad,
    Is it possible to fit 17" wheels instead of the stock 18's? I know the regular SR5's come with 17"'s but does my truck have bigger brakes or something I should know about?
    The other thing Id like to know is what is the factory offset on this truck is? Where am I starting from? Are the stock wheels? already at +60mm ? ...
    TUNDRA STOCK WHEELS:
    2003-2006:
    • 16" wheels - Width: 7", Offset: +15mm, Backspacing: 4.5", Hub Bore Diameter = 106mm
    • 17" wheels - Width: 7.5", Offset: +18mm, Backspacing: 5", Hub Bore Diameter = 106mm
    2007-2013:
    • 17" wheels - Width: 8", Offset: +50mm, Backspacing: 6.5", Hub Bore Diameter = 110mm
    • 18" wheels - Width: 8", Offset: +60mm, Backspacing: 6.85", Hub Bore Diameter = 110mm
    • 20" wheels - Width: 8", Offset: +60mm, Backspacing: 6.85", Hub Bore Diameter = 110mm
    2014+
    • 18-in. styled steel wheels
    • 18-in. 5-spoke alloy wheels
    • 18-in. 5-spoke TRD Off-Road Package alloy wheels.......These are on my OEM wheels
    • 18-in. 5-spoke TRD Pro alloy wheels Offset: +60mm ****Does this apply to me?***
    • 20-in. Limited Grade wheels
    • 20-in. split 5-spoke machine-finished alloy wheels
    • 20-in. 6-spoke alloy wheels
    • 20-in. Platinum Grade wheels
    • 20-in. chrome-clad alloy wheels
