  1. Jun 28, 2020 at 2:20 PM
    Professional Hand Model
    Fred
    Hand Protectors
    @FrenchToasty
    theblurry1[QUOTED] and NUDRAT like this.
  2. Jun 28, 2020 at 2:33 PM
    Fred
    Hand Protectors
    Greased up the rear shaft zerks and warshed the Interior windows. I’ve noticed having to clean the interior windows less since fixing all my gasket leaks (rear slider window, suicide door back corner upper gasket button hole, and the famous blower hole tab at the cowl). She smells better, too. :D
    Blower motor resistor is coming in this week. Looking forward to doing Ohms testing on it versus the old one. :yes:
    theblurry1 and NUDRAT like this.
  3. Jun 28, 2020 at 2:34 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I would think your windows would build up faster - no venting. Perhaps at this age they've off-gassed most all they're going to?
  4. Jun 28, 2020 at 2:42 PM
    Fred
    Hand Protectors
    The water leaks prior were allowing steam inside the cab. No leaks now. Dry, but running AC in the summer always leaves a film.
  5. Jun 28, 2020 at 2:43 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The compressor won't run if one of the high/low switches is bad either. FSM would be the the next step for diagnostics before replacing the compressor.
  6. Jun 28, 2020 at 2:55 PM
    Yeah I’m not to sure what the blinking AC light means, but checking the low pressure and HP switch would be the next step.
    When you replace the compressor, you will need to add oil per spec, I think they are dry shipped, a new filter dyer, and possible the expansion valve while your in there(not sure where the expansion valve is)
  7. Jun 28, 2020 at 3:04 PM
    Also check this video, he says we don’t have a AC relay only a fuse and then some sort of pressure transducer. But it kinda sounds like your clutch has shit the bed
    https://www.youtube.com/watch?v=zHZy7ZwzgRk
  8. Jun 28, 2020 at 5:01 PM
    Fred
    Hand Protectors
    Yeah boys. Took her out on some rough roads under construction nearby for the door clatter test. Even hit a familiar parking with speed bumps and the doors shims are working perfectly. No clatter at the bottom jamb and sill when hitting decent bumps like before. HIGHLY RECCO for Access Cabs!! cheap!
    I added a little of the Gorilla Double Sided Tape for some padding on the sill side of the shim and left the peel n stick plastic on. Fully dialed.
    theblurry1, bassman417 and NUDRAT like this.
  9. Jun 28, 2020 at 6:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Does this count?
  10. Jun 28, 2020 at 6:15 PM
    getwiser88
    getwiser88 New Member
    2020 TRD Pro
    Just gave Dolores a 6 hour spa session. Thanks to the ChemicalGuys YouTube training videos! I even got her show off the Fathers 1st gen Tundra and my brother Tacoma.
    bassman417 and Filthyphil like this.
  11. Jun 28, 2020 at 6:18 PM
  12. Jun 28, 2020 at 7:22 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Ahh!!! I completely forgot to check!
  13. Jun 28, 2020 at 7:29 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Got a bunch done on the old girl today.
    A Rust-free door is on the truck. Pulled the old one off myself, Got the glass out, 30% tint on the glass, new door hung (with some help from the wife), lock cylinder replaced, and that’s where I call it quits for the night. Pretty happy with the progress considering i only worked on it for 3 hours or so.
    E6FC2D33-CA73-4A0E-A55B-35B7064D9042.jpg 007F48DA-14E3-4532-BBE2-F67B67AADC4B.jpg 58D0D816-BF04-4324-828B-7D10CB2C3144.jpg
    Now I just discovered something. The power door lock plugs are different. The bigger one is from the parts truck. I assume this has to do with the dealer-installed security system?
    @empty_lord
    B0FE8E84-2944-46DF-A354-7A01BA53CD74.jpg C77A10A1-26F1-4FE1-9007-CB1ECE309AF5.jpg AB510AA4-C1B0-42EB-91C5-906BE1921A26.jpg 10C09E05-459B-4B52-9637-D5E29973E28C.jpg
    Edit: GG forum for rotating every single photo to a different weird angle except for one. :facepalm::frusty:
  14. Jun 28, 2020 at 7:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    uh.... it shouldnt be different... id think... what is your truck? a sr5? the parts truck a limited? maybe extra wires for heated mirrors? my truck has the larger plug..
  15. Jun 28, 2020 at 7:32 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Both limited, my truck is a 00, the parts truck is an 01. 00 had a smaller plug. The only noticeable difference I see is that the 01 has factory security... they even both have cloth seats.
  16. Jun 28, 2020 at 7:33 PM
    empty_lord
    05 rollover special
    Security doesn’t add anything wire wise.. it just uses the same power locks yours does.. check and see if you old mirrors had heat. That’s all that should be different
  17. Jun 28, 2020 at 7:38 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Mirrors are the exact same. They even have the same part number.
    A86AF29E-88B4-4FBB-B325-06D712D008D2.jpg D3638A98-CBAE-42AF-BDE2-ECC837631021.jpg 05392E1D-E8F3-43F3-BFB0-E7CD15C679AB.jpg 9311A1AE-3283-4C67-A687-60C645C8276E.jpg
  18. Jun 28, 2020 at 7:40 PM
    empty_lord
    05 rollover special
    its just a year difference.. no idea why... no mention of why in the manual.. but yes its a different plug...
    lsaami[QUOTED] likes this.
  19. Jun 28, 2020 at 7:43 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Wonder if I can use the old door harness so I don’t need to repin the connectors...
  20. Jun 28, 2020 at 7:43 PM
    empty_lord
    05 rollover special
    seems to be changes in junction locations... just run the original harness from your doors.. their easy to swap
    FrenchToasty and lsaami like this.
  21. Jun 28, 2020 at 9:57 PM
    You posting turd gen stuff? In my dojo? No sir.
    1Silverback, MS22, CodyP and 5 others like this.
  22. Jun 29, 2020 at 11:24 AM
    Bye bye clear garBRAge. Hello starting paint correction - 1st pass, mild polish + DA + 6" hook/loop pad on single stage paint.
    Info on removal of those once-clear rock chip guard "bra" things seen on my fender flares is over HERE. Too bad with the clear bra removal on passenger side, got a little high on my angle with the plastic razor and *shloop* scalloped it a bit. I've got touch up, just haven't bothered. Naval jellied a couple of scratches and filled as well.
    DJenerated, MS22, bmf4069 and 7 others like this.
  23. Jun 29, 2020 at 11:55 AM
    Fred
    Hand Protectors
    1 for two today!
    Installed new Blower Resistor. Performed tests on old and new and they are identical. $23 experiment fail. :rofl:
    While on that side I removed my 1 year New(er) Wells Door Switch and tinkered with it. Dove into the old box of parts removed from truck since a few years ago and swapped in the old ‘good’ switch that I kept just in case. Door lights and locks work as they should. Glad I kept the one good one from last year. Success!
    Washed the truck today as yesterday was a rain out.
    PB Blast Penetrator Sprayed the entire under chassis. She is loving it. That Toyota factory recall film they sprayed on 2 years ago really soaks the PB in every time I spray it. I see these 5-10 year older sprayed frame pictures people put up on here and see how that factory spray is all cracked and flaking off. It needs oil juice on it to keep it gooey.
    bmf4069, Tundra2 and TX-TRD1stGEN like this.
  24. Jun 29, 2020 at 1:41 PM
    @Tundra2 drove 4.5 hours one way to get my old bumper and help install my new one. Can't tell you guys how appreciative I am that we have such great people on this forum.
    Looks like I lost maybe 1/2" up front. The build quality on the bumper is really good. Noah has more experience with welding and said it looked excellent. The only issue I had was that the holes on the skid row plate didn't quite line up but we got 2 out of 3 in. I just need to make the 3rd hole a little bigger that should take care of it.
    Voss, MDobb79, 1Silverback and 16 others like this.
  25. Jun 29, 2020 at 1:52 PM
    Fred
    Hand Protectors
  26. Jun 29, 2020 at 2:09 PM
    Fred
    Hand Protectors
    I’m jealous of his 6 hour spa session and he did mention 1st Gen in his sales pitch of that company. I might report you for being mean!
  27. Jun 29, 2020 at 2:22 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Looks fantastic!!
  28. Jun 29, 2020 at 4:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Before you say "No texting, and driving."
    Pulled off for petrol, and potty break.:D
    250 miles on 14-ish gallons. Minimum speed of 75 MPH. Not terrible. Keep in mind that at times this lil ole V6 truck was LITERALLY screaming to keep up with your INSANE traffic. :rofl:(At times I was doing 90-95 so I didn't get squashed by big rigs...)
    The drive was actually very enjoyable. Truck rides pretty nice. It was rough at times with the clusterfuck of road work in your neck of the woods. :rolleyes: Very scenic, and at times stressful. Nonetheless, good for my soul to be around positivity even if it was brief.
    Biggest take away for me is that I was able to help someone, not the bumper. I could have very easily just bought all the stuff, and not had an excellent day trip. I got out of the house. :thumbsup:
    Your new bumper is put together with HIGH quality Tig weld, dime stack technique. Something I could do with practice. I weld at maximum 45 minutes a year...
    Tig welding is an art form. You have your tungsten electrode in one hand, and your filler rod in the other. Dual hand technique.
    Very finicky for a newbie.
    oscardog86, speedtre, bmf4069 and 7 others like this.
  29. Jun 29, 2020 at 5:10 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Thanks guys. I suppose I'll look into replacing the high and low pressure switches... not sure if there's a lot of info out there on that, but I'll see what I can find. It sucks having no cool air in these hot Colorado summers! And it sucks that air conditioning stuff is not cheap! Most likely @FrenchToasty is right and I need a new compressor, filter dryer, and expansion valve.
  30. Jun 29, 2020 at 5:11 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    I approve! Can we have a night time picture?
