2006 Tundra 4.7 Low Fuel Pressure
Discussion in '1st Gen Tundras (2000-2006)' started by Flippinstick, Jun 29, 2020.
  1. Jun 29, 2020 at 12:44 PM
    Flippinstick
    Flippinstick [OP] New Member
    2006 Tundra 4.7, 2025 TRD Limited
    2007 Tundra 4.7 with 165,000 miles.
    I have been chasing a P0174 code and finally tested the fuel pressure. It is a constant 22 psi. Under acceleration the pressure doesnt move unless I back off quickly, then it will jumps to 28-30 psi. Unplugging or adding vacuum (mightyvac) to the pressure regulator makes no difference.
    Fuel trims are definitely high on LTFT 1 and 2. In the pictures one is idle and the other is at 2500 rpm.
    Im guessing it is the fuel pump. Has anyone been successful in cleaning the screen on the pump or is it something I need to replace. If replaced are there any good alternatives to Toyota? I see they start around $100 for the complete pump and assembly.
    Thanks and yes I did search the forum before posting and could not find what I was looking for.
    Filthyphil likes this.
  2. Jun 29, 2020 at 1:05 PM
    Professional Hand Model
    Fred
    Hand Protectors
    The search engine is not good on this site.
    I’ve never done an inside fuel tank sock filter change out, but from what I’ve seen if you are going to have to drop the tank to remove the sock then you should go ahead and do the pump as well. Not sure where to guide you other than using OEM Pump.
  3. Jun 29, 2020 at 3:07 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Where did you get this data from? My understanding is the 4.7 fuel pressure and only be measured mechanically from the fuel port at the front of the manifold.
  4. Jun 29, 2020 at 3:15 PM
    Flippinstick
    I removed the bolt in red and screwed in one with a Shrader on top, then connected the gauge.
  5. Jun 29, 2020 at 3:20 PM
    remington351
    2006 SR5 DoubleCab
    I guess you have the right reading then. The screen shots from your device are what threw me off. I was expecting to see a traditional dial gauge. Remember we have the 2 stage fuel pump. Voltage to the pump is run through the resistor, lowering the voltage and lowering the pressure. You may have an issue with the low pressure circuit.
    Hooptytrix likes this.
  6. Jun 29, 2020 at 4:13 PM
    Flippinstick
    I an not able to get any fuel pressure resdings from the OBD2. How would I diagnose the low pressure circuit?
  7. Jun 30, 2020 at 4:05 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
  8. Jul 1, 2020 at 8:41 AM
    Flippinstick
    My Fuel Resistor reads .6 ohms. Im not sure if that much difference or my meter.
  9. Jul 1, 2020 at 8:49 AM
    Fred
    Hand Protectors
    Might be losing some resistance. Once it nears zero there is nothing. Mine read .8 @ 90° Ambient and the Engine Bay Hot AF.
    The .70 - .76 is a tight range.
  10. Jul 1, 2020 at 9:13 AM
    Flippinstick
    I just jumped the connection to see if I get different readings. Fuel trim numbers are looking better.
  11. Jul 1, 2020 at 10:40 AM
    If you're under that range it means the fuel pump will be getting more voltage than it should, increasing flow. Not by much though. It's less than 10% off, but is still below spec so it may be bad.
  12. Jul 1, 2020 at 10:45 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I put a denso pump in my old T-100 and it worked great. Much cheaper than OEM. I had a leak in my tank so I was replacing the whole tank and did the pump since I was in there anyway. On the positive side, the fuel gauge was more accurate with the denso.
  13. Jul 1, 2020 at 10:50 AM
    Walboro is another brand I would use over OEM.
  14. Jul 1, 2020 at 2:37 PM
    Fred
    Hand Protectors
  15. Jul 1, 2020 at 2:38 PM
    Fred
    Hand Protectors
    Never mind I see 165k.
  16. Jul 1, 2020 at 2:40 PM
    Fred
    Hand Protectors
    You jumped the resistor connection?
  17. Jul 1, 2020 at 6:27 PM
    Flippinstick
  18. Jul 1, 2020 at 6:38 PM
    Fred
    Hand Protectors
  19. Jul 2, 2020 at 9:35 AM
    Hooptytrix
    Dirty South
    You know I saved that image also :rofl:
    Thank you sir :thumbsup:
  20. Jul 2, 2020 at 10:15 AM
    Fred
    Hand Protectors
    Thats why I put this stuff up so people can share it and use it for improvement.
    The FSM is a gold mine of info. The best repair manual for our trucks except I still do not see specifics on this Cam Seals Replacement other than providing 2 dots that I can probably connect eventually.
  21. Jul 2, 2020 at 11:03 AM
    Hooptytrix
    Dirty South
    If no one has said it before....
    Thank you for being such a valuable member, I truly am appreciative of your posts, knowledge and modeling skills
  22. Jul 2, 2020 at 11:46 AM
    remington351
    2006 SR5 DoubleCab
    Otramm did a nice cam seal video for the non VVt engines.
    https://www.youtube.com/watch?v=7gcM_-fN-44
  23. Jul 2, 2020 at 12:09 PM
    Fred
    Hand Protectors
  24. Jul 3, 2020 at 8:37 AM
    Flippinstick
    Thanks for everyones help. No check engine light and it passed inspection with the fuel pump resistor jumped.
  25. Jul 3, 2020 at 11:38 AM
    Fred
    Hand Protectors
    I remember reading someone here jumping their resistor and it eventually over time lead to a burned out fuel pump.
  26. Jul 3, 2020 at 4:43 PM
    Flippinstick
    I'm replacing the resistor for that reason. Jump was just for testing.
  27. Dec 11, 2020 at 3:24 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Any updates now? I just started getting the P0171 code, checked vacuum lines and replaced bank 1 O2 sensor and still getting it. Thinking I could have your issue. Resistor is reading .9 ohms at 68 degrees.
    Traveling06tundra likes this.
  28. Jun 8, 2021 at 8:21 PM
    Traveling06tundra
    Traveling06tundra New Member
    06 tundra TRD camper
    Filthyphill, hey man did you figure out you're issue, currently same issue getting the p0171 and the p0174 lean codes. Currently on the road so need to get trucked fixed asap. 210k
  29. Jun 8, 2021 at 8:24 PM
    Filthyphil
    Phil
    Yeah I had a intake gasket leak on the very back letting air get in and causing a lean condition. Also wiped out my passengers side O2 sensor. If you can spray some carb cleaner or brake clean around your intake manifold and you’ll hear/feel it stutter.
  30. Jun 8, 2021 at 8:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
