  1. Jun 26, 2020 at 10:46 AM
    No. He's just extremely anal. :D
  2. Jun 26, 2020 at 11:10 AM
    Heres my best PHM impression:
    Didn't do much today. Took out the engine to clean the carbon off the under side of the pistons and polish the crank shaft journals a bit. I also numbered all the nuts and bolts individually throughout the truck after giving them a thorough cleaning.
  3. Jun 26, 2020 at 11:31 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If Felix Unger owned a FGT.... ;-)
  4. Jun 26, 2020 at 11:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not a lot on the DC, maybe 2 inches right at the bottom.
    bmf4069[QUOTED] likes this.
  5. Jun 26, 2020 at 11:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not sure on DC. They have a very different back seat than AC.
    For AC the tricky parts are the giant atmospheric vents that you can't get rid of, and the space you have isn't on the ground but about 6" off the ground. There are a few threaded inserts that can be used to mount an amp though.
  6. Jun 26, 2020 at 12:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Jun 26, 2020 at 12:01 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Then he eats some tacos
  8. Jun 26, 2020 at 12:05 PM
    In other news, I've not had a chance to really inspect it but the bumper looks great
    at first glance. It would have looked better with the TRD cutout... :annoyed:
  9. Jun 26, 2020 at 12:20 PM
    Better pic. This thing is going to be impossible to mount alone. My wife about died helping me unload it just now.
  10. Jun 26, 2020 at 12:28 PM
    Should I mount the Baja Designs lights on the inner or outer holes?
  11. Jun 26, 2020 at 12:43 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Spots or flood beam?
  12. Jun 26, 2020 at 12:47 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Best way to go might be here
    oscardog86, NUDRAT and theblurry1 like this.
  13. Jun 26, 2020 at 12:50 PM
    Here is what they say, "Driving/Combo:  Maximum trail coverage in a single light.  The Driving/Combo pattern is equipped with both Driving (42°) and spot (9°) optics to provide you with a smooth blend of light for both near field applications and distance (Lighting Zone 3)"
    @imDementeD has the same set.
  14. Jun 26, 2020 at 12:51 PM
    Yeah I've watched that video at least 5 times now :D. I'll just get some buddies to come over and help me hold it. I'm sure we'll figure it out.
  15. Jun 26, 2020 at 1:44 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd do the outer set then.
  16. Jun 26, 2020 at 1:51 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Oilless Axle Seal Change out. Removed rear sway link and jacked that side up to save the recently changed Diff Oil and build carbon credits for WurrldPeas.
    The Old Axle Seal did not have the little coil spring on the backside like the New Toyota one has. It also looked wallowed when overlaid with the new one which is tighter in diameter. Think the bearing looks rust and musty from some of the change outs you guys have done, but its not making noise currently so its staying until it does so. It has slightly play when wiggling the Axle, but when its mounted its solid. No play at the wheel.
    No oil was in rear brake assy which means I caught it in time. :yes:
    The Driver side Stealer repair is confirmed not leaking. Chapter closes on that side. I’ll recheck this Pass side repair in about 1k miles.
    Job took about 2.5 hours total.
  17. Jun 26, 2020 at 1:58 PM
    Fred
    Hand Protectors
    @Rex Kramer
    I haven’t changed any hoses. All are still original. I did cut one vacuum hose end tips off and made it happen. All hoses seem good to go on my truck. You should put in a new PCV Valve regardless. Cheap and easy now that the hard work of the grommet is done. That thing was a bear even with the Valve Cover off.
    theblurry1 and Rex Kramer like this.
  18. Jun 26, 2020 at 2:02 PM
    Fred
    Hand Protectors
    Not that I know of. I saw this in the FSM next to the o2 Sensor Tests Specs which I recently confirmed. Only reason I did this test was its easy and why not.
    Tundra2 and Lil Steve[QUOTED] like this.
  19. Jun 26, 2020 at 2:21 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I will investigate new hoses and post up my findings later on, I have already cut the cracked ends off a few hoses this year.
    Removing the old grommet required a small screwdriver, some needle nose pliers and a few choice words. The real challenge was keeping small parts of the grommet from falling inside as I pried & pulled it from it's location. I sprayed the new grommet with AT-205 before I installed it and the new valve, this should make it easier to service in the future.
  20. Jun 26, 2020 at 3:05 PM
    Fred
    Hand Protectors
    :rofl:Tonight the symmetry was perfect Oaxacan Style Tacos paired up with Pink Bubbles from d’Alsace. A Yin and Yang to celebrate Axle Seal success!
  21. Jun 26, 2020 at 3:23 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks amazing!
    Tundra2 likes this.
  22. Jun 26, 2020 at 3:34 PM
    Fred
    Hand Protectors
    Thanks. It was really good. I picked up a Skirt Steak on sale yesterday 1.5lbs for $2.38!
    Mz. PHM made up a Chimi Churri yesterday like @Hooptytrix suggested and had it marinate in a bag overnight. Still have 2 days of meat left over. :yes:
  23. Jun 26, 2020 at 3:35 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Hope you set some chimi to the side, dip the steak as you eat. What's the address?
  24. Jun 26, 2020 at 3:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can't top your meal, but I will share mine tonight. One BLT wid cheese.20200626_173353.jpg 20200626_173341.jpg
    I chipped a tooth earlier so I have to go with "chewy" bacon. Not my favorite "crunchy" bacon.
  25. Jun 26, 2020 at 3:41 PM
    Hooptytrix
    Dirty South
    You guys are making me hungry.
    I sanded the hell out of the lenses and I just can't get them to clear up. Killed 3 fully charged batteries. To hell with it, I will buy another set later on.
  26. Jun 26, 2020 at 3:49 PM
    Hooptytrix
    Dirty South
    I was searching for a 38" single row light bar but the price was double that of the 32" double row.
    32" it is for now.
    My next project after I recover from surgery will be eliminating the clutch fan and going dual electric.
    Darkness, theblurry1 and bmf4069 like this.
  27. Jun 26, 2020 at 3:58 PM
    Them look like street tacos. Very good.
  28. Jun 26, 2020 at 4:00 PM
    Fred
    Hand Protectors
    Tomorrow is Bed Bolts removal day. Remove and grease’em up one at a time. There will be a day this bed needs removal for the Fuel Pump replacement.
    Also, this scrubbing sound from my 2yo cheap Chyna Front CV Joints is bugging me. The boots look like they have tears in them already. :annoyed:
    Whats peoples thoughts? My mind says remove the boot closest to the wheel spindle and pack grease all in there (because thats where the sound was identified back when I did my front calipers). I could hear the noise inside that boot like rubber rubbing against smooth metal when I turned the Axle with the wheel and calipers off. It was a soft material scrub sound.
    My front bearings are original and I’ve had a bad Rear Bearing and know what that sounds like. Nothing else to do tomorrow except beat up on Turd Gen Oil Threads.
    TX-TRD1stGEN, Tundra2 and bmf4069 like this.
  29. Jun 26, 2020 at 4:02 PM
    Fred
    Hand Protectors
    Nice catch! Best Tacos are the Street ones when they carve the open flame roasted rotating meat right off the slab.
  30. Jun 26, 2020 at 4:02 PM
    Hooptytrix
    Dirty South
    @Professional Hand Model
    Which way did you make the Chimichurri? Threw everything together in blender which makes a green cream or did you go with parsley, garlic and oregano in blender and then hand mix the rest in, this gives you an oily mix?
