Turn signal problem that's driving me nuts
Discussion in '2.5 Gen Tundras (2014-2021)' started by jstyle, Nov 5, 2018.
  1. Nov 5, 2018 at 5:46 AM
    jstyle
    jstyle [OP] New Member
    Josh
    2016 Magnetic Gray Offroad CrewMax
    So my first post in the Tundra world, I'm a long time Taco driver just needed something bigger and stronger... that out of the way... Hey everyone :)
    So I just pick up a 2016 Tundra OR crewcab last week. Since I bought it the turn signal bulb went out. I changed it out yesterday and I swear it was working for a few hours, I drove my son to daycare this morning and it's out again? Any ideas or quick things I can check to see what's going on?
  2. Nov 5, 2018 at 5:50 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would say either a short somewhere or just a bad connection.
    Short will be difficult to find, so I would troubleshoot bad connection first. See if the terminals where the light bulb hook in are clean, and if the back side where the wires come in are secure. I have had a lose wire on a previous vehicle before that would do that - sometimes the light would work and going through a few potholes or something the wire just moved enough to not make contact anymore.
    Also check to make sure that there is not moisture in the housing that can cause corrosion on the contact points.
    15whtrd likes this.
  3. Nov 5, 2018 at 6:14 AM
    15whtrd
    15whtrd Mr. Blonde
    Also check for any aftermarket wiring. Maybe someone tapped into the wires for some extra lights or maybe they installed LEDs at one point and took them out. Check the harness from underneath the truck.
    Tundyfundy likes this.
  4. Nov 5, 2018 at 6:20 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Check to make sure that the new bulb is clicked fully into the socket. One of my front signal/DRLs went out a few months back. I changed it out and everything was fine--for a few hours. I checked and realized that I hadn't gotten the lamp fully seated. All's well now.
    Tundraman1000 likes this.
  5. Nov 5, 2018 at 6:21 AM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    could be the wrong bulb or a faulty bulb. i've seen that happen lots where you think you have the right one then it burns out quickly.
  6. Nov 5, 2018 at 6:23 AM
    Rica25
    Ricardo
    Tulare
    I had same issue with a brake light bulb and was not fitting right so I went and bought one from dealer and never burned out again
  7. Nov 5, 2018 at 7:21 AM
    jstyle
    Josh
    Yeah so I had to rig it up for the time being, the problem is that's it's just a little loose. Looks like I'm going to Toyota soon.
  8. Jun 28, 2019 at 7:18 PM
    Malfunction light
    Malfunction light New Member
    2015 Toyota Tundra
    So I just started having the same turning light problem on front drivers side on 2015 Toyota Tundra! The light replaced worked a few hours then stopped agin! It isn’t burned out but looks like it may be getting a little hot on the metal part. Tried some electrical connection protection jelly to make it contact, at auto parts store for $1.50 Reinstalled bulb and agin started working for like 1/2 hr. Then quit agin. Going to try a little bit more and see if it does the trick. Let me know if you find out what’s causing it!
  9. Feb 25, 2020 at 1:10 PM
    Brandondsfla
    Brandondsfla New Member
    2013 White SR5 w/mods
    Afe throttle body spacer, k&n Cai, 3" lift, 33" Nitto'$
    I also have this issue with my tundra, upon some more research, I discovered that the inside of the socket itself melts, and causes the bulbs to short out. You can order the socket on Amazon for our trucks for less than $10 each.
    plumber802 likes this.
  10. Mar 2, 2020 at 3:38 PM
    jp_over
    jp_over New Member
    Joe
    East TX
    2017 CrewMax SR5 4x4, white
    Is this still a problem with the 2017 (SR5) models? I just had a front signal light go out and am going to replace the light and socket to be safe but if this is a design problem/flaw I'm going to check out LEDs for a longer term fix.
    Update - just checked, both my sockets show darkening from overheating. I'm going to either go LED or disable the DRL.
  11. May 28, 2020 at 12:15 PM
    riverbank70
    riverbank70 New Member
    Al
    2015 Limited CM
    None
    Thanks! I thought I was going crazy.....anyone known the part number?
  12. May 28, 2020 at 12:51 PM
    jp_over
    jp_over New Member
    Joe
    East TX
    The OEM socket part # is 90075-60060.
    I replaced both sockets and bulbs and also disabled the DRL. So far no issues but both original sockets did show signs of overheating.
    HailstorminMT likes this.
  13. Jun 26, 2020 at 3:01 PM
    HailstorminMT
    HailstorminMT New Member
    Hailey
    Montana
    '14 Tundra and '04 4runner v8
    lift and lights
    I've been having the same problem on my '14. THANK YOU for posting the part number! I'll probably switch over to the LED system also. I've been looking at headlight revolutions kit. Anyone have any thoughts on that?
    jp_over[QUOTED] likes this.
