33" tires on stock tundra, with leveling kit.
Discussion in '1st Gen Tundras (2000-2006)' started by Ray122, Jun 17, 2020.
  1. Jun 24, 2020 at 1:54 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    1.5 would put you right in the sweet spot I think. After the spacers are installed, your wheels will have an offset of -8. I believe the Tacoma sport wheels you have are 17x7.5 +30 offset.
  2. Jun 24, 2020 at 1:57 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
  3. Jun 24, 2020 at 1:57 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. I don’t like spacers. Just a personal opinion since you asked about thoughts. I can’t believe nobody gave you the heads up on those wheels not going to fit. Are they 4Runner Wheels?
    I’d get another set of wheels that fit.
  4. Jun 24, 2020 at 2:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Were yours the older model? I have the newer model and mine are pretty good in snow.
  5. Jun 24, 2020 at 2:09 PM
    Fred
    Hand Protectors
    revtune[QUOTED] likes this.
  6. Jun 24, 2020 at 2:17 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2 options really; wheel spacers or new aftermarket wheels. If you go with spacers, check these out! Here’s a screen shot of some spacers that are built very well and they even come with the needed open end ET style lugs. It may not be the most “stylish” name but they are well made. (I’ve used them)
  7. Jun 24, 2020 at 2:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is there a 255 option maybe? 255/80/17?
  8. Jun 24, 2020 at 3:20 PM
    stevechumo
    stevechumo New Member
    Only use hub centric wheel spacers with thick center bore lips. I've been running 1.25" with no problem.
    revtune likes this.
  9. Jun 24, 2020 at 3:38 PM
    Ray122
    Ray122 [OP] New Member
    2005 toyota tundra
    I feel so stupid, I read his reply and completely over looked him telling me exactly what I needed. My bad. And shoutout to revtune, you've been a great source of knowledge on the subject and wish I would have read a little more carefully. It looks hub centric wheel spacer are the popular vote, the guy at the tire shop recommended bolt on, ill do some research real quick but anyone have a understanding of the difference.
  10. Jun 24, 2020 at 3:39 PM
    Ray122
    2005 toyota tundra
    Any picks of what your running?
  11. Jun 24, 2020 at 3:39 PM
    Ray122
    2005 toyota tundra
    I want the surface area of the tire for traction especially because its 2wd
  12. Jun 24, 2020 at 5:35 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You get the surface area from taller tires, width doesn't add as much surface as people think.
  13. Jun 24, 2020 at 6:11 PM
    stevechumo
  14. Jun 24, 2020 at 6:12 PM
    stevechumo
    I am running 275/70/17 with very little rubbing even with the spacers.
  15. Jun 25, 2020 at 11:14 AM
    arctictundra8577
    arctictundra8577 New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    I have the same wheels, I use 265/70R17 and I had to get 1.25 spacers (https://www.amazon.ca/Spidertrax-S2...t=&hvlocphy=9000651&hvtargid=pla-570343956605) these I found were the best cause there hub-centric so they won't fall off as long as you use thread locker (blue) and torque them correctly. Once the spacers were on I had to remove the mudflaps.
    Here's what they look like (sorry for the bad angle)
    revtune likes this.
  16. Jun 25, 2020 at 1:03 PM
    Silver Stomper
    Silver Stomper New Member
    2006 Tundra XSP Double Cab 2WD
    17"x8"FN Six Shooter Wheels, 265/70r17 Nitto Terran Grappler G2 Tires, Bilstein 5100's Leveling Kit and Rear Shocks, Morimoto Mini D2S 5.0 Bi-Xeon Projector Headlights, Blacked out head lamp lens, GTA Bluetooth Car Kit, Pioneer 6.5" Speakers
    I'm on 265/70r17 Nitto Terra Grappler G2 (31.6" dia) with aftermarket wheels; 17x8 with 4.5" backspace (0mm offset). No rubbing. I'm tempted to try the 285/70 r17 but not sure they'd fit. I have 30days to return/swap the tires.
    Here's the 265's:
    Here's the 285's. Not mounted of course because it didn't look like it would fit.
    revtune likes this.
  17. Jun 25, 2020 at 1:03 PM
    Ray122
    2005 toyota tundra
    I'm going with hubcentric spacers as well, I would like to run a slightly larger tire though. If its not to much trouble can you post a pick of how much room your tire has from the upper control arm?
  18. Jun 26, 2020 at 9:21 AM
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    Yea sure
  19. Jun 26, 2020 at 2:34 PM
    stevechumo
    Your suspension really needs a good cleaning. Lol.
  20. Jun 26, 2020 at 2:39 PM
    #50
    arctictundra8577
    Eric
    Ontario, Canada
    2005 tundra sr5
    yea the dirt really sticks to the oil
