  1. Jun 23, 2020 at 5:31 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Don't pull an @Pucks18 and leave the washer out. Messed up everything:rofl:
    And mark your entire drive line before taking it apart so it can go back together the same way.
  2. Jun 23, 2020 at 6:30 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Plastidip is great stuff. If you're intending on a long term hold, a can of that clear coat glossifier is definitely worth it. It keeps the rubber soft, which holds up better to rocks and bugs while also preserving the deeper black of the plastic rather than allowing it to fade to an eventual grey that begins peeling or even cracking.
  3. Jun 23, 2020 at 6:34 AM
    Thrussn
    Gabe
    NM
    I had the same issue with mine. It's amazing how fast the rotors warp on my 05. I eventually slapped some big gurrl drilled and slotted rotors on and they haven't warped since. I absolutely recommend them if your Napa ones warp as fast as mine did!
  4. Jun 23, 2020 at 7:44 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    These brakes are temporary. My lack of 17” wheels is what’s making me hold off from the 14wa big boi calipers
    Thrussn[QUOTED] and bmf4069 like this.
  5. Jun 23, 2020 at 8:03 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Thanks but I feel like there is too much black on the grill now. I thought about using the hot knife trick to peel of the middle piece, which is chrome, to see how that looks. Aftermarket, nearly OEM, replacements are only about $70 on ebay. I may just go that route. I kinda like the completely stock look.
    Thrussn[QUOTED] likes this.
  6. Jun 23, 2020 at 12:07 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Does anyone know which markings indicate which sides for the front springs? Haha someone want to go out and look at your truck? They are slightly different ratings and I didn't keep track of the new OEM ones' sides.
    One spring has white and purple markings, the other has white and red.
    I'm about to adjust my Bilsteins and install these correct springs today.
  7. Jun 23, 2020 at 12:43 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    3 02's done. That drivers side 1 closet to the manifold is being a bitch.
    Gotta work on the wiring for the headlights and light bar. I'm going to stop there, there is more to do but...
    This is not going to done today.
    bmf4069, Thrussn and Tundra2 like this.
  8. Jun 23, 2020 at 12:45 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    On my 06AC, I have green and purple dots on the driver's side. I couldn't see any dots on passenger's side. But I didn't crawl under there very far.
    theblurry1[QUOTED] likes this.
  9. Jun 23, 2020 at 12:56 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    On my 2002 4x2 AC the drivers side is yellow/white and the passenger side is blue/white. This is the way it was stock and the way I put it back when I installed my 5100's.
  10. Jun 23, 2020 at 1:04 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Received my rear 4.56 gear and T-handles. Installed the T-handles so I can lock them now!
    oscardog86, hammeron, NUDRAT and 7 others like this.
  11. Jun 23, 2020 at 1:26 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    that looks great!
  12. Jun 23, 2020 at 1:40 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    How much for the 4.56 gear ? Also will you install it yourself ?
  13. Jun 23, 2020 at 1:52 PM
    imDementeD
    The rear gear was $151 shipped. The front (on back-order) is $130ish. The gears aren't expensive but the rebuild kits are another $4-500 and then I have a front locker coming as well.
    For installation, absolutely not! I read some how-to's and from what I gather, it has to be exact or you can really damage stuff and my patience allows for about 85% perfection.
    oscardog86, speedtre, chrisb and 3 others like this.
  14. Jun 23, 2020 at 2:09 PM
    Hooptytrix
    Dirty South
    Gave up on that 1 02 sensor, get back to it later.
    Figured I should do something else in the meantime
    hammeron, chrisb, NUDRAT and 6 others like this.
  15. Jun 23, 2020 at 2:39 PM
    Professional Hand Model
    Fred
    Hand Protectors
    My 2002 SR5 ‘Off Road’ Package 4x4 has yellow/blue and yellow/green markings. Sorry bud or I’d send a pic. These springs on our trucks are quite varied.
  16. Jun 23, 2020 at 2:40 PM
    Fred
    Hand Protectors
    Man up and go full Gorilla Arm Technique on that Sensor!
    bmf4069 and Tundra2 like this.
  17. Jun 23, 2020 at 2:56 PM
    Thrussn
    Gabe
    NM
    That's why I strayed back to the factory grille on mine. It looked really weird at first, but it really grew on me. The mesh grille was a lot going on.
  18. Jun 23, 2020 at 3:17 PM
    Fred
    Hand Protectors
    Been towing and hauling and doing lots of idling in the Island Heat. Towed and Hauled a mega load yesterday on some back roads doing less than 20mph. She is doing it well!
    chrisb, NUDRAT, bmf4069 and 2 others like this.
  19. Jun 23, 2020 at 3:29 PM
    Outbound
    Aaron
    Northern Alberta
    Nice wheels. :thumbsup:
  20. Jun 23, 2020 at 8:26 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    Hey thanks to you and the others anyway. I figured out that measuring the springs revealed one was a quarter inch taller, and I assumed that was the driver's side to compensate for the fuel tank, battery, and driver being on that side. Got everything installed and all buttoned up. She will ride great after an alignment tomorrow, although it will be awkward when the shop that quoted me $700 sees I just did the work myself!
  21. Jun 23, 2020 at 8:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naw, if you can do it. Do it. Some things are worth contracting out, and some aren't. Good decision.
  22. Jun 23, 2020 at 9:38 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Swapped out my headlights and reverse lights for LED'S!!!. What a difference. Interior LED'S arrive friday. ttl Cost $80 on Amazon. Pretty easy so far. Not sure about the interior world.
    20200623_211643.jpg 20200623_211008.jpg 20200623_205030.jpg 20200623_204343.jpg 20200623_201430.jpg
  23. Jun 24, 2020 at 5:15 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Pure Gold there, pure gold!
    Tundra2 likes this.
  24. Jun 24, 2020 at 8:56 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    Anyone with diff drops notice any difference or recommend them?
    I figure the concept of getting some of the angle out of the CV axles from the lift makes sense, so just ordered mine from Supreme Suspensions on sale, then I can close out front end stuff and finally get my skid plate out of the yard ;)
    bmf4069 likes this.
  25. Jun 24, 2020 at 11:11 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Can you compare the sound to a traditional subwoofer? I have a basic JL in a subzero box and absolutely love the sound, but my kids hate it being in the way.
    theblurry1 likes this.
  26. Jun 24, 2020 at 11:32 AM
    I agree with you. Your truck looks a lot better with the factory grill. I don't like that mesh grill at all.
    Thrussn[QUOTED] and jImmegart like this.
  27. Jun 24, 2020 at 12:41 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I like the Darrell waltrip mesh grill but that ones mesh sticks out to far for my taste. Maybe if the mesh was recessed more.
  28. Jun 24, 2020 at 7:15 PM
    robabeatle
    AZ
    I just put in a Kenwood powered 8 inch that is very similar in look and fits under the passenger seat, completely hidden. The sound is pretty impressive for such a small enclosure. It would not impress a teenager likely but it really brings in the lower octaves and even thumps just a bit. I highly recommend as it was $250 versus my original idea of external amp plus box that would take up the rear passenger compartment plus sub ~$1100.
    Hooptytrix likes this.
  29. Jun 24, 2020 at 7:39 PM
    Lil Steve
    Gilbert, AZ
    It's a step above a good early 2000's premium factory system, but has nothing on anything from JL. It's a decent sub $200 powered subwoofer (see what I did there? :)) that will add some thump to any stock-ish 4 speaker stereo. It's adjustment range is nice to be able to match the sound to your taste, but if you're running amplified door speakers I think this will come up short.
    bmf4069 likes this.
  30. Jun 25, 2020 at 6:08 AM
    Fred
    Hand Protectors
    Ordered up 3 more nuts just in case I need to go Spyder Andersen on these things to get them off.
    bmf4069, theblurry1 and Thrussn like this.
