Apple Car Play issue
Discussion in 'Audio & Video' started by Pinehurst177, May 27, 2020.
  1. May 27, 2020 at 12:25 PM
    Pinehurst177
    Pinehurst177 [OP] New Member
    2020 White Tundra Limited
    I just traded in my 2016 Tacoma Trd Off-Road for a 2020 Tundra Limited. If I am not mistaken,this is the first year of Apple/Android Car Play for the Tundra. My phone is synced and everything works but when I try to make a call from the steering wheel I get a message which tells me to connect a device even though my phone is connected. Any thoughts or suggestions would be greatly appreciated.
  2. May 27, 2020 at 12:45 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Are you connected via CarPlay or via bluetooth? I don't make many calls from my truck but the few that I have I've made with bluetooth and haven't noticed any issues. I also haven't tried Android Auto so no idea what issues it may have, if any.
  3. May 27, 2020 at 12:53 PM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    The Apple Carplay in my 2020 has worked flawlessly so far. Are you using Apple or Android?
  4. May 27, 2020 at 12:54 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Connected wired or wireless?
  5. Jun 22, 2020 at 1:04 PM
    Trebz
    Trebz New Member
    Trebz
    2015 4Runner but looking for 2020 Tundra
    There has been at least one fix for CarPlay from Toyota. I was having issues with the screen locking up after making a couple of calls and the screen was garbled. After the update, it is much more reliable and usable, but not perfect. The screen still gets a little funky sometimes, but unplugging and replugging it fixes it. I am at the dealer for my first oil change right now, and I asked them to see if there is another update.
  6. Jun 22, 2020 at 1:08 PM
    ekinnee
    ekinnee New Member
    North Central Texas
    2020 Tundra Quicksand SR5 TSS
    Carplay in my 2020 has worked just fine when using an Apple lightning cable in the left most socket.
    If using cp there's no reason to even be paired via bt.
  7. Jun 22, 2020 at 1:10 PM
    Kung
    KG, VA
    What ekinnee said; I use it with the plug to the left.
  8. Jun 22, 2020 at 3:41 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The only issue I've had is when I'm already on a call and I start the truck. The bluetooth in the truck steals the connection and there are a few seconds where I can't hear anything and the person on the other end can't hear me. Annoying.
  9. Jun 22, 2020 at 4:32 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm pretty sure that happens on every vehicle.
  10. Jun 22, 2020 at 4:52 PM
    PROTaRD
    PROTaRD New Member
    Reston Virginia
    2005 Tundra AC
    none yet -just starting out
    I’ve had a problem for about a week now - ever since the latest Apple iOS update. It worked fine before that but now I get the message “this accessory is not supported by this devise” and it boots me off of calls.
  11. Jun 23, 2020 at 12:50 PM
    Trebz
    Trebz New Member
    Trebz
    At the dealer yesterday, other than the update I received in May, there are no new updates yet. That being said, next time you are in the dealer, you should ask them to check to versions.
    I am on an off calls and apps for work all the time, and sometimes things still get a little funky, but unplugging and replugging it in seems to be a quick temporary fix.
    Before the update in May, the entire head unit would lock up until it crashed and rebooted.
    I am using a brand new iPhone cable from Apple and I still get the occasional glitch. Much less problematic than before, but not perfect. As for Bluetooth, as others have said, you don’t really need it if you have CarPlay. The Entune apps are underwhelming, so I unpaired my phone via Bluetooth.
  12. Jun 23, 2020 at 12:52 PM
    ekinnee
    ekinnee New Member
    North Central Texas
    What version are you on? And, is it an Apple cable or an aftermarket?
  13. Jun 23, 2020 at 12:54 PM
    ekinnee
    ekinnee New Member
    North Central Texas
    And what would be great is for Toyota to integrate their app with Carplay so that it will display vehicle info. Preferably useful stuff like temps and what not.
    Bakershack likes this.
