Whoops. Do I need CCF and MLV?
Discussion in 'Audio & Video' started by robabeatle, Jun 19, 2020.
  1. Jun 19, 2020 at 9:15 PM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I am reading about sound damping and thought I was going to apply my dealers "MESA" sound damping all of the floor and under the rear window tomorrow. More to the doors when the speakers get installed.
    BUT, it seems that most threads are saying just use maybe 25% covered of this butyl / aluminum to stop vibrations, then CCF on top and finally MLV to actually block outside noise.
    Will this be the best route for the floor. I figure I should just do it right the first time.
  2. Jun 19, 2020 at 9:42 PM
    robabeatle
    AZ
    Pretty darn convinced of the argument of well lets say 50% coverage on floor with sound damping material. Then a CCF and MLV overtop. Oh boy, what have I got myself into.
  3. Jun 20, 2020 at 3:41 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    That sounds not only expensive, but a lot of overkill. When I gutted my OEM JBL system, I simply Noico matted the doors, back wall, and some of the floor (and the floor was probably overkill as well). This is what I have seen most of the other Tundra owners do when doing a major stereo makeover. The biggest improvement, however was on the doors. Increased bass since all of the large ports were now covered.
    robabeatle[OP] likes this.
  4. Jun 20, 2020 at 4:41 AM
    robabeatle
    AZ
    I have concluded that to go with the full three layer is likely not going to even give the results that I'd be looking for. Well, hopefully a little sound treatment is better than none.
  5. Jun 20, 2020 at 4:50 PM
    robabeatle
    AZ
    Went to test out my new HU and sound damping. I do notice the sound damping a bit. It is more like it changes the noise rather than eliminates it. I expect a big improvement when the doors are done esp. with new speakers. And, if I want to go with the CCF and MLV, the first step is done. The new head unit is a big improvement over the stock, of course. I now have a Kenwood dmx 706s.
