OEM Camera to Alpine
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by DeepTRD, Jun 18, 2020.
  1. Jun 18, 2020 at 8:07 PM
    DeepTRD
    DeepTRD [OP] New Member
    2017 White TRD PRO
    So, almost at the end of the line trying to get the Toyota camera to work with my aftermarket head unit... Stereo works, steering wheel controls work - looking for camera pins...
    I have a 2017 TRD
    What pins ( colors ) am I looking for
    There are 3 sets of wires that are covered in blue jackets..
    I have a 28 Pin harness and a 24 Pin harness
    Any help would be appreciated...
  2. Jun 18, 2020 at 9:48 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't understand why you are asking about 'pins'.
    Which Alpine HU do you have?
    Page 205 of this PDF has an Alpine wiring diagram.
    https://pdf.crutchfieldonline.com/ImageBank/v20200318225600/Manuals/500/500INEW970.PDF
    I've had Kenwood and Pioneer HUs in my 2014 and had no problems connecting the rear view camera.
    The Rear View Camera directly into plugged into the HU.
    The Kenwood had an RCA for the Rear View Camera.
    Pioneer had the same..
    Even this Alpine had the RCA jack for the stock rear view camera.
    It would be the shorter single yellow RCA.
    Does your HU not have that?
    https://www.crutchfield.com/p_500INEW970/Alpine-INE-W970HD.html?tp=20217#&gid=1&pid=11
  3. Jun 19, 2020 at 5:15 AM
    DeepTRD
    2017 White TRD PRO
    Hello, Thank you for the reply.. I have more info today ( took the tailgate cover off to goto camera connector )
    I have the Alpine's iLX-W650
    I have a jack for the rear camera on the Alpine HU. When I placed the order with Crutchfield I was told I can either keep my steering wheel controls or the camera... I chose the steering wheel figuring they were harder to manipulate into the HU.
    System works, but now I'd like to integrate the factory camera.... I've pulled the pins from the Toyota side of the harness ( I have a sheet labeling where the pins were on the harness )
    I've searched and searched for the wiring diagram and found the 2015 tundra one which shows the following.
    Crutchfield sent me to TOYCAM2-6V which has a connector not found on my truck's HU so I can't cross reference the pins... BUT I can remove the pins from that harness and use the RCA Jack to connect to V+ ( pin 12 ) and V- ( pin 24 ) , I'm assuming the black is my 6V ( pin 11 ) and the Common Ground is ground ( pin 24 )
    not working... unit shows grid lines when put into reverse, but no image....
    Opened up and looked at the camera connection and got this... a 6 pin connecter with 5 being used.
    Just wanted to know if I was doing something wrong.. Need to know what pins need what signal.
    Thank you in advance.
  4. Jun 19, 2020 at 5:28 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    That doesn’t seem right. There shouldn’t be any issue with the camera using the adapter. I would call crutchfield and double check.
    it should all be plug and play. I haven’t seen a recent vehicle that makes you choose one or the other.
  5. Jun 19, 2020 at 5:47 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    B+=Camera+ power
    BGND=Camera Ground
    V+= Camera Video
    V-=Camera Video -
    So there are really only 2 pairs used for camera I am sure,Power and Video
    Where are you getting the 6 volt from,the adapter?
    And are you sure the camera is a 6 volt unit?
  6. Oct 3, 2020 at 12:36 PM
    Jdub78
    Jdub78 New Member
    PA
    2018 Black Tundra SR5 Crew Max
    4” Tuff Country lift Bushwhacker OEM flares S&B CAI MBRP Stainless Exhaust Fuel Offroad wheels 20x9 35x12.50r20 Toyos Nfab steps 2019 Pro LED headlights LED’s all around Alpine ilx 650 Maestro RR2 Rockford Fosgate P1000x5 amp Kickers in all 4 doors 2 Rockford Fosgate P3SD4-10 Subs
    Maestro rr2 will solve all your problems
