4lo being retarded
Discussion in '2.5 Gen Tundras (2014-2021)' started by Samoan Thor, Jun 18, 2020.
  1. Jun 18, 2020 at 6:34 AM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    4lo is having issues, 4hi works fine, put it in neutral and sometimes 4lo engages sometimes it doesn’t it just beeps. The times it does engage it doesn’t want to get out of 4lo, sometimes it works fine. But it happens more now when it used to work fine no problems, truck has 85,962 miles. Dealer wants $125 just to look into the problem. Do I just pay them that and see what they find or should I get an extended warranty first because I’m assuming 4wd issues will be expensive. What do y’all suggest or have any of you had similar problems and found a fix? Does warranty cover 4wd problems?
  2. Jun 18, 2020 at 6:44 AM
    How are you putting it into 4 low?
    Samoan Thor[OP] likes this.
  3. Jun 18, 2020 at 6:49 AM
    Samoan Thor
    @T-Rex266, I go to 4hi first then neutral then 4lo
  4. Jun 18, 2020 at 7:24 AM
    Are you stopped? There are instruction (or should be) in your visor. There are specific steps you must take
  5. Jun 18, 2020 at 7:26 AM
    Samoan Thor
    @T-Rex266, yes I stop, put it in neutral after 4hi then switch. I’m faithful in the 10 miles a month in 4wd recommendation in the owners manual so I use my 4wd a lot.
