Tundra towing mods
Discussion in 'Towing & Hauling' started by Eddie32, Jun 17, 2020.
  1. Jun 17, 2020 at 4:39 PM
    Eddie32
    Eddie32 [OP] New Member
    Just purchased a 28 foot travel trailer and plan to travel quite a bit. I was wondering what performance mods may help while towing? I have a 2020 Tundra Crewmax 4x4 TRD off road package. Has anyone added mods that specifically helped while towing? Thinking Bam muffler exhaust, DAP programming, extra fluid capacity diff cover, etc.....
    Any suggestions would be appreciated.
  2. Jun 17, 2020 at 5:31 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Transmission Cooler, you will need the lower transmission temps. Use search to read all that is written on transmission temps.
    Air bags to support the additional hitch weight
    on board air for air bags and keeping tires inflated to proper weight handling
    Wallygator likes this.
  3. Jun 17, 2020 at 5:49 PM
    I totally recommend a larger differential cover. (Look under your truck)
    Personally, I would just tow and see how it does. Check out the towing section. Lots of good information.
  4. Jun 17, 2020 at 6:17 PM
    How does a 2020 5.7 not have a tranny cooler? I think my 2013 4.6 even has one. :notsure:
    Wallygator and ColoradoTJ like this.
  5. Jun 17, 2020 at 6:38 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Check for the towing threads on this forum - short version is Toyota engineers did their tests with and without the cooler and didn't see enough of a difference so took it away for 2019. Pre-2019 all Tundras with a tow package had a transmission cooler.
    mrballcb, GODZILLA and Cpl_Punishment like this.
  6. Jun 17, 2020 at 6:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wut? LOL You don't remember that Toyotas don't have diff covers?
  7. Jun 17, 2020 at 6:41 PM
    Yeah....I was joking around. That’s why I asked him to look under his truck.
  8. Jun 17, 2020 at 6:42 PM
    I know right? It kind of surprised me as well.
  9. Jun 17, 2020 at 6:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Fair enough...:D
  10. Jun 17, 2020 at 6:59 PM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    I just bought a 2020 Crewmax 4x4 also and I towed a 20ft travel trailer it was about 3800 lbs I think maybe more. I didn't know that the 5.7L doesn't have a tow package... it comes with a brake controller which I used a couple times and really saved my ass. I am looking at buying a Imagine 22RBE or 22XLS travel trailer. When I do that I also want to put a 2-3" lift on it to fit 33s nicely and so far so I don't get the bro lean I am gonna have to raise the rear by adding leafs or replacing rear leaf pack and if it still sags then I would look at doing a airbag system to help truck ride level.
    Bigboitundra likes this.
  11. Jun 18, 2020 at 2:52 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    I recently purchased a 23" TT with dry weight around 4500lbs. The only mods I've done so far is invested in a weight distribution Hitch (as many folks on here recommend) a 28 footer will be quite a bit heavier but I will say I am impressed at how little it sagged. I also have a 2" lift in the back an running 34" tires.. But already used it an it towed well.. I'd like to possibly add bags or sumo spring eventually. But it's not really needed for me..IMG_20200613_131922.jpg
  12. Jun 18, 2020 at 7:21 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your trailer jack is down. :rolleyes:
    Branden, BravoDeltaRomeo and GODZILLA like this.
  13. Jun 18, 2020 at 7:31 AM
    Johnders2586
    Lol I was wondering if someone would catch that!! However I hadnt taken weight off the hitch yet becuase I wanted a quick snap with the weight on ... Good eye though..
  14. Jun 18, 2020 at 8:47 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    Post what you towed...
    twotrack, ColoradoTJ, Bigjack and 2 others like this.
  15. Jun 18, 2020 at 10:13 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    what kind of Coleman is that?
  16. Jun 18, 2020 at 10:27 AM
    Eddie32
    Thanks for all the replies and suggestions. I have the WD hitch and other than the transmission cooler any comments on performance tune, exhaust or CAI that may help mountain driving and/or MPG’s?
  17. Jun 18, 2020 at 10:29 AM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    Don’t need CAI or exhaust. Just put it in Tow/Haul and put it in S4 and let it climb.
    WVI, GODZILLA, bdean38 and 1 other person like this.
  18. Jun 18, 2020 at 10:33 AM
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    Which model Geo Pro is that? We are looking at the 20BHS.
  19. Jun 18, 2020 at 10:49 AM
    Johnders2586
    It's a 2021 Colman 1805RB
  20. Jun 18, 2020 at 12:44 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Have a way to monitor your transmission temperatures.
  21. Jul 22, 2020 at 10:02 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Has anyone mentioned a great mod is to upgrade to 10ply tires ?
    I upgraded and noticed a huge improvement in stability when towing
    The stock tires felt really floaty when towing
  22. Jul 22, 2020 at 3:47 PM
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    That is the 19FBS. As I have stated before it was nice and I liked it, however I would stick to a tandem axle. It rides smoother. The single axle on the geopro just tosses stuff around. Have you looked at the RPODs? They are nicer and the bed you can walk around it(which makes making bed easier) also if you drink you can get out of bed on your own side instead of crawling over someone to go to bathroom.
  23. Jul 22, 2020 at 5:21 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Towing performance mods for a gas engine: Dont put bigger tires on it.
    Shuffler, szabo101, D3Tundra and 5 others like this.
  24. Feb 7, 2021 at 12:52 PM
    amajack
    amajack New Member
    Will the 275/70/18 negatively affect the towing ability compared to 275/65/18?
    I'm planning on moving into an e rated for a 4000 dry trailer.
  25. Feb 7, 2021 at 1:17 PM
    jordoncloutier
    Jordon
    Alberta , Canada
    Any increase in tire size will decrease axle ratio . When towing you want the "lowest gear possible" which is the higher # . Tundras are 4.30 . All other half ton trucks are 3.92 max. Keep the tires stock sized imo .
    I changed to a E rated 275/65/18 . Made a huge difference in stability when towing my TT.
  26. Feb 7, 2021 at 1:46 PM
    Johnders2586
    I had 295/70-18 on my 17. I never towed with the stock tires. That being said I never felt that the truck was unstable. You will notice the truck shift more often an it's obviously more weight to move the bigger you go. I don't think a 275/70 is going to be a huge difference from stock...
  27. Feb 7, 2021 at 4:26 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your only pulling 4-5K you won't notice it too much.
  28. Mar 3, 2021 at 7:12 PM
    Tundraflyguy
    Tundraflyguy New Member
    Bow, NH
    2017 Tundra TRD Pro Barcelona Red
    BD GTX tuner, sumo springs, Spyder industries back rack and step bars, Rigid Industries fog lights, all LED lights, wireless phone charger in the armrest
    I have 10 ply 295’s. I tow a 8,200 pound 5th wheel. I guess it’s around 10,000 with all our stuff in it. Which is what it’s rated for. Hitch weight is 1,200. I have sumo springs (yellow) to keep the truck level. Upgraded brake rotors and pads to help stop that beast. And a Bully Dog GTX with a tow tune to help with the shifting points and firmness, and to monitor trans temp. My truck is a 17 TRD Pro double cab. I have the factory trans cooler. Problem with it is that it doesn’t have its own thermostat. So, if your engine coolant temp is below the threshold, your trans fluid isn’t getting cooled. I’ve had this happen to me a few times. I had to downshift to a lower gear so the engine revved up higher, thus heating the coolant and opening the thermostat and cooling the trans fluid. In the near future, I’ll be installing another in line trans cooler. The most important things I’ve noticed that negatively affect the way your trailer tows, is air pressure in all tires (truck and trailer) and weight being unevenly distributed in the trailer (I.e. too much tongue weight, too light in the tongue, or too much weight on one side of the trailer.) Rule of thumb, if the rig doesn’t look right or doesn’t feel right on the road, pull over and make some adjustments.
    WVI, Oldguy423, chickunfut and 4 others like this.
  29. Mar 3, 2021 at 7:19 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I found that Roadmaster Active Suspension is another solid upgrade if you are towing heavy. Give them a look if you ever want to upgrade from Sumo springs. I went this route instead of air bags because the install is way easier and would require me getting on board air.
    You are spot on with tire pressure. Makes a huge difference and your setup looks great!
  30. Mar 3, 2021 at 7:26 PM
    Tundraflyguy
    Bow, NH
    Are those the ones that get drilled into the lower spring and you can swing it away when you don’t need them?
