Ticking noise 4.7L question Not Manifolds
Discussion in '1st Gen Tundras (2000-2006)' started by Dfabeaton, Jun 12, 2020.
  1. Jun 12, 2020 at 11:51 AM
    Dfabeaton
    Dfabeaton [OP] New Member
    Devin
    2002 SR5 Tundra 4.7
    Hello I'm new here, been doing a lot of reading but have never actually posted. I recently purchased a 2002 Tundra 4.7l. Im starting to worry that it has been abused by it's previous owner. Just Had the timing belt/tensioner/water pump/thermostat/serpentine belt done when I first purchased it about 2500 miles ago. But it's also got two leaking manifolds, CV axles with torn boots, I have to change out a shitty spacer lift, there's some power steering fluid leaking, and the brake fluid is dirty/need new rotors/pads soon. All that was borderline okay, I could deal with it.
    But now just a couple days ago the truck started making a new tick, seems to be coming from the driver side top end. I'm sure alot of you would say it's probably the manifolds, but I already knew those were leaking and this happened suddenly and unexpectedly the other day. When I first start the truck the noise is not there, then it comes and stays untill I shut off the truck. If I kill the truck then immediately start it back up the noise takes a minute or two to gradually come back regardless of the temperature of the motor. The motor seems to idle smoothly as indicated by rpms, but there are some slight intermittent shudders that can be felt in the floor. The speed of the tick does increase with rpms. And I'm almost convinced it goes away when I really step on it, but it could just be the droan from the aftermarket exhaust making it inaudible. I have video/sound of the noise I can try to post soon.
    Thanks for any help!
    Hooptytrix and Pinay like this.
  2. Jun 12, 2020 at 11:57 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal
    Dfabeaton[OP] likes this.
  3. Jun 12, 2020 at 11:59 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Devin, I moved your thread to the 1st gen section. Lots of great helpful members there who will hopefully help ya out!
  4. Jun 12, 2020 at 12:11 PM
    Welcome. First things first. You may not have a leak. I've been living with what I thought was an exhaust leak for 4 years. Recently I decided to replace my steering shaft seal and I'll be damned if the noise didn't go away. The noise I was hearing was because that seal was ripped. It would only enter the cab at certain times.
    As far as the tick, that might be normal too. It's hard to say without hearing it. But I know a ticking noise is normal for the 4.7L as it's been explained here before.
    You should pull back your carpet and see if your seal is ripped. Here is a thread that explains it.
    https://www.tundras.com/threads/diy-steering-shaft-seal.48664/#post-1754577
    bmf4069, Pinay and Hooptytrix like this.
  5. Jun 12, 2020 at 12:16 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Welcome from the Dirty South.
    Ticking is normal for most modern engines, something to do with the high pressure fuel system. Your tick is unknown till we hear it. Post up that video
    Edit; don't listen to the fool that tells you white is the fastest color. He knows nothing
    Pinay likes this.
  6. Jun 12, 2020 at 12:30 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
  7. Jun 12, 2020 at 12:33 PM
    Hooptytrix
    Dirty South
    That sounds like a leak to me
  8. Jun 12, 2020 at 12:37 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
    @FirstGenVol
    Thanks for your feedback. I know I have a leaking manifold or gasket on each side because I recently pressurized the exhaust system with a leaf blower and sprayed soapy water on the manifolds. Both are leaking from the same place in the front. As for the tick I don't believe it is normal as I've put about 2500 miles on the truck in a little over a month and this ticking is definitely new and obvious. That seal is something I should check anyways but the tick is even more noticable outside the vehicle, so I don't think it's that.
  9. Jun 12, 2020 at 12:40 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
    @Hooptytrix I agree it sounds like a leak, but then why would it have suddenly come on when I already knew what the existing leak sounds like, and why would it disappear for a minute if I turn off and turn back on the truck. It also sounds louder when sticking my ear near the top of the motor vs getting it close the the manifolds by sticking my head in the wheel wells.
  10. Jun 12, 2020 at 12:40 PM
    Gotcha. Sounds like an excuse to throw headers on the truck. As for the tick, maybe you can post a video from your phone? Someone here might have some advice.
    Pinay likes this.
  11. Jun 12, 2020 at 12:42 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
    @FirstGenVol posted the audio video above. Definitely an excuse to do headers.
    Pinay likes this.
  12. Jun 12, 2020 at 12:43 PM
    Hmm. That is interesting. @empty_lord does that sound normal to you?
    Pinay likes this.
  13. Jun 12, 2020 at 12:45 PM
    Hooptytrix
    Dirty South
    A valve tap would sounds more like a ping, metal tapping metal (kinda) that sounds like a vac leak. If it sounds like it's coming from the top, poke around and see if anything came loose. If not, pull the valve cover, it's not difficult
    Pinay and Dfabeaton[QUOTED][OP] like this.
  14. Jun 12, 2020 at 12:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sounds like the purge valve vsv working
    Pinay and Dfabeaton[OP] like this.
  15. Jun 12, 2020 at 12:50 PM
    Hooptytrix
    Dirty South
    The purge thingy mentioned here is located on the right side of where the video angle. It's a black box with hoses. Take a poke around
    Pinay likes this.
  16. Jun 12, 2020 at 1:00 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
    @empty_lord @Hooptytrix
    Thanks for the help, I found a hose that was disconnected right in front of my face . I'll be driving the truck in a couple hours and will let you know if that stopped the noise . Probably got knocked out of place from driving on loose rocks with this friggin spacer lift.
    bmf4069, empty_lord, Pinay and 2 others like this.
  17. Jun 12, 2020 at 1:04 PM
    Hooptytrix
    Dirty South
    Sounds like another Homer Simpson moment
    I have a few of these everyday and I'm not proud to admit it :anonymous:
    Pinay likes this.
  18. Jun 12, 2020 at 1:16 PM
    Hooptytrix
    Dirty South
    Looking forward to your results after you drive it
  19. Jun 12, 2020 at 3:37 PM
    Dfabeaton
    Devin
    2002 SR5 Tundra 4.7
    @Hooptytrix this seems to have fixed my issue. Thanks for walking me through that Homer moment .
    TX-TRD1stGEN, bmf4069, Pinay and 2 others like this.
  20. Jun 12, 2020 at 3:50 PM
    Hooptytrix
    Dirty South
    We get lucky every so often :thumbsup:
    Pinay likes this.
  21. Jun 17, 2020 at 10:59 AM
    We had a 1st gen outta place? You need to keep an eye on those turd gen members posting in our humble abode! I keep having to shoo em outta here! :D
