Towing TT - Nebie widsom needed
Discussion in 'Towing & Hauling' started by TomyTun, May 29, 2020.
  1. Jun 7, 2020 at 9:04 AM
    Just make sure it’s fun, not expensive. :D
    DM 2018 Tundra likes this.
  2. Jun 7, 2020 at 9:07 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    We will make it fun and take our time learning and enjoying the new camper. We are planning the next few months and plan to get out more often than not.
  3. Jun 7, 2020 at 9:13 AM
    Do you have a generator?
    If you do, electric heaters can be a life saver. Definitely learn the purge procedure for the heater. I like to test the heater out before needed. ;)
  4. Jun 7, 2020 at 9:50 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    No Generator at this time. I'm curious to see if the solar and dual battery setup with the 1000w inverter will be enough. I doubt it would be enough if we want to run the AC etc most of the day. Figured we would try it out and buy a generator when or if needed. I have not heard about Purging the heater. Just looking it up now.
  5. Jun 7, 2020 at 10:08 AM
    You will need a generator to run the AC.
    The point of a generator/electric heaters is if your heater fails, and it will, your family can stay at least comfortable.
    JC303[QUOTED] and Backslider like this.
  6. Jun 9, 2020 at 10:43 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Do you think a surge protector and water pressure regulator are good ideas or not necessary?
    I keep think about the WDH. My TT is 3,513 lbs and payload is 942. Total - 4,455. Hitch weight is 455. Manual says a WDH is not needed until over 5,000 lbs. Do you think it's a good idea? Opinions on reversing with a WDH? Thanks
  7. Jun 9, 2020 at 11:19 AM
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
    Why would the heater fail? I’ve owned several TT’s and MH’s and never had the heater fail as long as I had propane.
  8. Jun 9, 2020 at 12:02 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Make sure the other person on the other end knows their job. You both need to agree on a language.
    Your spotter needs to focus on the trailer, you need to look out for your truck. Get out and look around before backing up.
    If you're not aware of your surroundings when cutting a sharp turn you can easily clip a post, tree or rock with your truck because you were hyper-focused on the trailer. Trust them to do their job.
    For my and my wife, we agreed on left or right as looking from the back of the trailer forward. She would tell me "left", which meant the ass end of the trailer needed to go left. If you keep your hand on the bottom of the steering wheel, the direction the trailer needs to move translates to the same direction you need to turn the steering wheel.
    As for tow mirrors, check your laws. My state requires them.
    Other advice:
    Know where your jack points are. Pack appropriate jacks, lug wrenches, etc..... your stabilizer jacks aren't meant to lift the trailer.
    Bring along a drill or impact for your stabilizer jacks.
    If you're at a park with full hookups, don't hook your sewer line up with your dump valve open or you'll learn about something called "pyramiding", where your poop stacks and dries on itself.
    Also check to make sure your dump valve is closed before opening the drain. Always assume there's a little sewage between the valve and cap.
    Drain your black water first, then gray. The gray water will kind of clean the hose out.
  9. Jun 9, 2020 at 12:07 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Thanks for your advice and time! These are all great tips.
  10. Jun 9, 2020 at 2:58 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    JC, I would use a WDH with sway control on travel trailers over 15 ft. I lost control of my 16 ft Nomad trailer 25 yrs ago going down some steep mountain turns. I wasn't using a WDH with sway control.
    Also if your planning to dry camp in the spring or fall, you can kill your two trailer batteries in two cold nights even with 100w solar panels. I found having a honda 2200eu generator is good insurance.
    JC303 and Cpl_Punishment like this.
  11. Jun 9, 2020 at 4:24 PM
    You are under the recommendation from Toyota. I would be lying my ass off to you if I said every time towing 5k or more I had a WDH in use.
    I would see how you like it without one. Could be just fine. In a pinch, you could come borrow mine and set it to the lightest setting while waiting on yours to arrive.
    JC303[QUOTED] likes this.
  12. Jun 9, 2020 at 4:33 PM
    I have had one fail and never figured out why. We went to a remote location in northern NM, towed 17 miles back on bumpy roads. For the life of me, I spent hours trying to get the heater to work. Never fixed it or changed anything, heater worked 2 days later and every time since. Just my experience.
    Another time, when I was homeless and living in my camper for 3 weeks, one of the pigtails on my propane tank had a leak. I was already on my second tank (first one went a little faster than normal, and found out why) and the second drained even faster. It snowed that night. Lucky for us, we learned from the New Mexico trip and had two electric heaters. The camper stayed a brisk 65*, but it was better than the 38* we woke up to in NM.
    Just my experiences. Others may vary.
    Sp33dNut[QUOTED] and JC303 like this.
  13. Jun 9, 2020 at 4:35 PM
    I took you for a remote camper, but if you plan on visiting state parks, not a bad idea. I have a whole house surge protector, and it would make sense to have one on the camper.
    A lot of people have water pressure regulators and filters. I just always filled my tank and never hooked up to the site system.
  14. Jun 9, 2020 at 5:00 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    If you go to a park with full hookups, then a water pressure regulator is cheap insurance and a filter is worth it since you don’t know the quality of the water. I don’t use a surge protector, never had. I’m sure it will catch up to me someday.
    I have no issues backing up with a WDH. I would recommend using one because I don’t like the sag in the rear or the feeling of loose steering in the front when loaded up.
    I don’t have a generator, but it’s because I usually camp at a place with electric hookups.
    Get some Andersen levelers or the equivalent camco ones. They make leveling side to side so much easier.
    DM 2018 Tundra, JC303 and Sp33dNut like this.
  15. Jun 9, 2020 at 7:11 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Mostly remote camping. We like getting away and not having many neighbors. Planning a trip once a year with the in laws and they go to parks with hook ups. Also will take a few road trips and may stop somewhere with hook ups once in a while. Might as well get one to avoid the potential headache.
  16. Jun 9, 2020 at 7:15 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Thanks for the advice. Water regulators are cheaper than having a bigger problem. The wife likes the filter idea. I have added it to the cart.
  17. Jun 9, 2020 at 8:06 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Apparently, you should carry a spare socket/bit with your impact drill (for your support jacks), as I found out today. Basically, if you're anything like me, if it's inexpensive buy two of all things. Because even if you don't break "it", you'll spend half your damn trip looking for "it".
    Also don't put your camper keys in the outside shower lock, while washing off your waiters, and forget the keys are still in there. Your wife won't let you forget that you "lost" your keys (even if she forgot her set at the house 8 hours away).
    Lots of good info on here already from what I've read. Before you set out, always make a list of items that need packed a day or two before then add to it.
    Lastly, remember when camping to stay in the mindset of: (if something goes wrong) it could be worse...you could be in a tent.
    @ColoradoTJ agree, especially with the crapper info on post 29.
    @19TurdPro very good info, except I don't trust anyone to back me up. Mostly because I'd rather blame myself for the damage than harbor a grudge, but I guarantee with my method I get in and out of my truck more while backing than you do!
    Cpl_Punishment and JC303 like this.
  18. Jun 16, 2020 at 1:37 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Thanks again for everyone's input. We have spent 3 nights in the camper so far with many trips planned. Drove over 550 miles to pick it up. Sunday night on Lake McConaughy we survived winds over 50 mph. Friends had their tents destroyed and we took 4 kids in the camper. Already have fun stories to tell and I feel more comfortable and confident with the info I have read and videos I have watched.
