Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Jun 3, 2020 at 9:44 AM
    #391
    audibahn
    audibahn New Member
    Denver, CO
    2005 Tundra Limited Double Cab
    17x7 Toyota TRD Pro wheels with 255/80/17 Falken AT3W tires.
  2. Jun 3, 2020 at 10:35 AM
    #392
    speedtre
    speedtre New Member
    Inland Northwest
  3. Jun 3, 2020 at 9:59 PM
    #393
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Painted some aftermarket rims.
    Desrat likes this.
  4. Jun 4, 2020 at 6:57 AM
    #394
    fighthedude
    fighthedude New Member
    are those oem rim or aftermarket? Also what does your suspension work consist of? Thanks
  5. Jun 4, 2020 at 8:43 AM
    #395
    audibahn
    audibahn New Member
    Denver, CO
    These are OEM TRD rims from the new 4Runner. They have a 4mm offset. I'm running a 0.5" lift in the front using Bilstein 5100 on the 2nd notch. I had to remove my front mud flaps and I get slight rubbing on the frame at full turn. Rear is stock leafs with Bilstein 5100 shocks.
    HBTundra likes this.
  6. Jun 4, 2020 at 11:14 AM
    #396
    fighthedude
    Your Bilstein change your ride much? Ie the quality?
  7. Jun 4, 2020 at 11:32 AM
    #397
    ccheezy
    ccheezy New Member
    North Carolina
    2020 CrewMax Limited
    "What are you hauling there son?" "ass"
    Gen 1's are so cool. Like a 5/6th size and still rocking the V8.
    Outbound, MNtundra, MS22 and 4 others like this.
  8. Jun 10, 2020 at 2:28 AM
    #398
    fcgoulart26
    fcgoulart26 Ol’ Franky Boy
    Francis
    Denver, CO
    2002 SR5 Regular Cab
    None
    Just scored these for cheap! A major improvement over the steelies.
    Mountun Goat, BestGen, MS22 and 2 others like this.
  9. Jun 10, 2020 at 12:48 PM
    #399
    AncientTundra
    AncientTundra New Member
    2000 Tundra Limited
    4Runner "snowflake" rims. In desperate need of new tires. Will be installing a 3/1 lift and larger tires. Also unfortunately rocking the Gen 2 Tundra badge. Truck came with the badges.
    Mountun Goat, Pucks18, MS22 and 2 others like this.
  10. Jun 12, 2020 at 5:51 AM
    #400
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Ignore the missing hub cap
  11. Jun 12, 2020 at 10:35 AM
    #401
    I like it w/o them. Gives a more rowdy look.
  12. Jun 15, 2020 at 11:02 PM
    #402
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Got some snowflakes on the tundy. Really like the look
  13. Jun 16, 2020 at 11:01 AM
    #403
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    You must have been around my house once because Ive seen your truck. I pointed out that camper soft top to my friend because he asked if they made those for our trucks.
  14. Jun 16, 2020 at 5:56 PM
    #404
    AncientTundra
    2000 Tundra Limited
    What size tires on your snowflakes? And do you have a lift? I’m debating on whether to get a complete new wheel setup or stuff my snowflakes into a larger tire.
  15. Jun 16, 2020 at 6:07 PM
    #405
    Surf_spear_Mex
    Patrick
    05 tundra ac
    I'm running 265/70/17 right now but once I get the 5100 billies in the front (probably 3rd or 4th notch) and aal in the back I'll jump up to 285/70/17. I talked with quite a few guys that have run snowflakes with that size no problem. Spacers might be on order because the snowflakes do sit a little too far in for my taste.
  16. Jun 16, 2020 at 6:10 PM
    #406
    AncientTundra
    2000 Tundra Limited
    I have Billies arriving soon, so that is perfect info. Good to know that tire size works and fits. Much appreciated.
  17. Jun 17, 2020 at 6:28 AM
    #407
    m3ga_tundra
    m3ga_tundra New Member
    2004 Tundra SR5
    Hello! New here just wanted to post up how awesome these 4runner trail wheels look. Been searching for a good deal and finally found a takeoff set from 2019 for $450 complete. Ordered a set of black lug nuts on Amazon check it out
  18. Jun 17, 2020 at 6:34 AM
    #408
    Nice find. I've always liked that wheel.
  19. Jun 17, 2020 at 3:52 PM
    #409
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Nice first post!
    Welcome
  20. Jun 21, 2020 at 11:39 AM
    #410
    Tim57
    Tim57 New Member
    m3ga-tundra, Looks almost like my 05 Limited. Does anyone have these odd alloy wheels, dealer install. 275/55r18 ? It's time for 2nd set of tires, the michelin's always dry-rots before they wear out just turned 100k. I'd like to go smaller than 55s without the speedometer getting way off. Any good ideas that will fit these wide rim's?KIMG0177.jpg KIMG0178.jpg KIMG0180.jpg
  21. Jun 25, 2020 at 11:27 AM
    #411
    arctictundra8577
    arctictundra8577 New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    put this on the pic thread already
  22. Aug 17, 2020 at 10:32 PM
    #412
    Yeng02AC
    Yeng02AC New Member
    Yeng
    2002 Green Toyota Tundra
    Are we able to use our old stock lug nuts for these 4runner rims or do we need to buy a different set of lug nuts to accommodate these rims?
  23. Aug 18, 2020 at 5:43 AM
    #413
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
  24. Aug 18, 2020 at 5:47 AM
    #414
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Thoughts on the AT3W’s? What size you go with?
  25. Aug 18, 2020 at 8:50 AM
    #415
    I believe the wheels in that picture are actually off an FJ Cruiser. I would assume you can reuse your old lug nuts but I'm not 100% sure. I've heard others say it's a good idea to replace lug nuts anyways if they are 15+ years old.
  26. Aug 18, 2020 at 9:05 AM
    #416
    Yeng02AC
    Yeng02AC New Member
    Yeng
    Got it thanks! I guess I'll look into purchasing some aftermarket lug nuts than.
  27. Aug 18, 2020 at 9:49 AM
    #417
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I’ve got first hand experience with the p285/70/17 AT3W. I’ll say this, unless you have a need for that type of tire, I would not recommend it. It looks awesome, but the tread pattern is on the extreme end of the terrain tire spectrum. Go with something like the hankook, Cooper, continental, Goodyear (not duratrac). The AT3w in that size is a power sucker. It was on my 2002 v8 anyway. You’ll be praying for a regear.
    JustJake and LaaMahTundra like this.
  28. Aug 18, 2020 at 9:57 AM
    #418
    audibahn
    audibahn New Member
    Denver, CO
    I went with 255/80/17, approx 33" tall and 10" wide. Load Range E. I have Bilstein 5100 on 2nd notch in the front and stock rear. My wheels are 17x7 with 4mm offset and I'm not running any wheel spacers.
    The tires themselves are great, ride smooth, no vibration, and at 53lbs are on the lighter side for that size tire. If I would do it again, I'd get the Wildpeaks in 265/70/17s or even 265/65/17s for several reasons:
    - I started towing a travel trailer and definitely feel the loss in power.
    - The tires rub the frame at full wheel crank. I also had to take off the front mud flaps.
    Ultimately, I need to decide on the primary purpose of my truck. Towing with light offroading vs. a more capable offroad rig.
    LaaMahTundra likes this.
  29. Aug 18, 2020 at 5:52 PM
    #419
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    LOUD. But look great.
    mcharfauros and MNtundra[QUOTED] like this.
  30. Aug 18, 2020 at 6:44 PM
    #420
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    @audibahn @Dog I am interested in the Falkens due to there snow rating (3flakes). Have either of you used them in snow?
