Bad vibrations
Discussion in '2nd Gen Tundras (2007-2013)' started by Bonehead, May 17, 2019.
  1. May 17, 2019 at 11:32 AM
    Bonehead
    Bonehead [OP] New Member
    I am getting steering wheel shake almost a thumping at different speeds different intensity sometimes 3 times a day maybe not for another week or month. it starts and gets worse as I slow down.i stop start back up it’s gone.this is the only consistent part .once 4 months ago on exit ramp I thought a tow home was coming violent shaking - pulled over then started up to get to safer place, it was totally gone didn’t happen again for a couple weeks ! It’s a 2013 rock warrior never been damaged 75000 mi. Any help out there?
  2. May 17, 2019 at 5:19 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Mine started a few months ago. Sometimes around 35-65mph then smooths out, other times all mph ranges for a few minutes. I have had it on and off with stock rims, aftermarket rims. Stock tires on aftermarket rims and new tires on aftermarket rims. Before the 3/1 level kit and after. Gonna get under this weekend and check any wear out parts. Got 52K on the clock right now.
  3. Jan 10, 2020 at 9:50 PM
    Youtube mechanic
    Youtube mechanic New Member
    Isaac
    2011 Tundra Crewmax 4X4
    Tough Country Brushgaurd, Gun magnet, LED interiors , Grenade valve caps , custom shift handle . Blacked out front grill , bug guard etc.
    You guys ever figure out what it is ? I have the same problem
  4. Jan 12, 2020 at 3:11 AM
    Alpha23
    Alpha23 New Member
    Bjorn
    Lava Tundra
    Been having the same problems
    I have changed Tires
    Rear Axle’s
    Break rotors polishes
    Brake pads to EBC
    Upper control arm bushes (Total Chaos)
    Removed spacers
    Re-connected sway bar
    Replaced. Steering rods
    Rebuilt steering rack
    Nothing seems to be solving the problem.
    But still bad vibrations on high speeds
    any other suggestions apart from buying a new Truck ? ✌
  5. Apr 20, 2020 at 12:34 PM
    STEEV11
    STEEV11 New Member
    2011 Platinum - 55k Miles
    Rev Tech lift - Bilstein 5100 - N-Fab LED mounts
    I have replaced almost every part of the front end. The only remaining items are the upper and lower ball joints and the wheel bearings. I will let you know if any of these fix the issue.
  6. May 24, 2020 at 8:20 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Check your lower A arm bushings that go to the frame , and wheel bearings . Is what the book recommends.. iv been researching this too and seems the lower A arm bushings are 90% of the culprits
  7. May 24, 2020 at 8:21 PM
    toyoboyo
    toyoboyo New Member
    Driveshaft
    STEEV11 likes this.
  8. Jun 4, 2020 at 5:03 PM
    Damaged aka warped rotors will shake too even without touching the brake pedal.
    Tundra2 likes this.
  9. Jun 15, 2020 at 5:06 PM
    STEEV11
    STEEV11 New Member
    Update - I have done the Rotors - Brakes - Lower control arm bushings --> No CHANGE
    I put back the stock rims and tires and it got better. I then replaced the rear shock with 5100's and the problem is 90% gone.
    I am going to the junkyard tomorrow to pick up a drive shaft. I will use new ball joints in case one of them is prematurely failing.
    I will update you after the weekend.
