Sweet affordable UCA's?
Discussion in 'Suspension' started by The Juice, Feb 8, 2017.
  1. Feb 16, 2017 at 4:10 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for sharing. That's def good to know.
  2. Feb 16, 2017 at 4:16 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I think you'll be ok with the backspace 6" is closer than 5. Stock wheels are +60 offset way closer to the ucas than 0. Unless your wheels are super wide.
  3. Feb 17, 2017 at 9:30 AM
    The Juice
    The Juice [OP] THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    AHHHHHH.....now that makes some sense! Thank you for your response!
  4. Dec 3, 2017 at 1:01 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I realize that this is an old thread but I wanted to chime in here. Seems a lot of people have a negative opinion of Zone Offroad UCAs.
    I have been running them over a year without a single issue. I DO get off road quite a bit, and while I'm not crawling up or down rock walls or the like, I go over some pretty rough roads with big rocks, dips and ledges, etc. I have not had a single problem with my Zone UCAs nor have I heard about anyone else having a problem with them.
    I have read a number of instances where SPCs have failed, and one of the techs at a local 4x4 shop also mentioned that he had personally seen a few SPC failures. Granted, the difference in verifiable instances of failure between the two brands may be due to the fact that SPC has a lot more UCAs out there so we see those failures more often.
    I don't think Zone UCAs are "skimping." I'm not claiming they are TCs or Camburgs, but they're absolutely on par with SPC or JBA. They don't offer quite as much positive caster as the SPCs, but you shouldn't need more than 2° additional with a ~3" lift.
    Just my 2¢
    I am not a suspension or alignment pro by any means, but I have done a lot of reading and research about the different options out there. This opinion simply reflects what I came up with in that endeavor.
  5. Dec 3, 2017 at 2:11 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Wow.
  6. Dec 3, 2017 at 3:22 PM
    Vizsla
    Vizsla pretend2send
    I have had Tough Countryo_O, Total Chaos, and now Zone.
    Tough Country = nope.
    Total Chaos = :thumbsup:, but I hate greasable bushings, and the UCA bolt is not
    made to be loosened and torqued every time you grease...
    Literally drop in, they adjust caster and camber, and not
    too much caster(important).
    Zone = :cool:, they are going to work fine for me, but they only add caster,
    1 degree, I gained 2 degrees at 2.5” lift leaving me at 5 degrees,
    not an issue, but 3 degrees suits me better. Camber still requires
    darn near maxing out the alignment cams. They are beefy, well
    constructed with above average welds etc., but by no means TC
    quality. Full travel compression to droop with my set up, and
    liking the oe no maintenance bushings. If I could buy TC with oe
    style bushings I would right now.
    Just my opinion.
    MDHinSD likes this.
  7. Dec 3, 2017 at 3:51 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    For those looking for a ball joint UCA, JBA UCA's seem to be catching on with the Taco crowd.
    Looks like they're good for up to a 3" lift for Tundra's, and go for $540 a pair.
  8. Jun 15, 2020 at 9:02 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    @Toytec Lifts has this been your experience with TC UCA’s? I’m looking for UCA to run with factory 20’s on my 2018 with 3/1 level. 275/60 tires but next set will be 275/65 (same width)
