Headlight converting to Led
Discussion in 'Lighting' started by ohanapools76, Jun 13, 2020.
Best LED headlight color
  1. Bright white 6 k
    1 vote(s)
    100.0%
  2. Cool white
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Jun 13, 2020 at 8:07 AM
    ohanapools76
    ohanapools76 [OP] New Member
    2015 Toyota Tundra
    Changed out wheels and tires
    I just picked up a 2015 Toyota Tundra SR5 and I want to switch out my stock headlights to LED headlights but I noticed that the headlight are adjustable they move up and down so do I have to find a certain LED replacement to fit properly and what the best way to install them also want to change my fog lights do I need to take panels apart? Please help me make my task easier with your experience please.
  2. Jun 13, 2020 at 8:10 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
  3. Jun 13, 2020 at 8:11 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I have a 2015, and I switched headlights to the 2019 Pro LED headlights. It has the leveling motor so you can keep that adjustment if you switch out.
  4. Jun 13, 2020 at 8:14 AM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    Fog replacement can be somewhat of a pain in the ass due to the cramped area and the removal of the front portion of the wheel well liner. My 2018 had two 10mm screws inside to remove along the edge, one of those plastic push rivets on the far inside of the wheel well, and then two 10mm screws and two 12mm screws underneath.
    When you're taking the small front piece wheel well liner out, you'll have to deal with the bracket that holds it in on the outside edge. You only see the outside parts of the bracket. The majority of the bracket is on the inside of the wheel well liner. Once you take out the two 10mm screws and the four bottom screws, slip something between the bracket and the truck just enough so that you can slide the bracket out with the wheel well liner out. If you don't, you'll snap that bastard off on the inside and it'll fall to the bottom of the bumper.
    ohanapools76[OP] and Pinay like this.
  5. Jun 13, 2020 at 8:20 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    If you're looking to swap out the bulbs - get an H4 LED kit for the headlights and H11 HID kit for the fog lamps.
    Dont worry about the leveling motors, they're part of the headlamps assembly, you dont need to mess with it when changing the bulbs.
    Many members have upgraded to 2018+ LED headlamps, it will give your Tundra an updated look.
    Check out the thread of iHacker if you want to go that route - https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/
    BamaMan44, ohanapools76[OP] and Pinay like this.
  6. Jun 13, 2020 at 8:21 AM
    ohanapools76
    2015 Toyota Tundra
    Thanks for the info are the lights difficult to change out?
  7. Jun 13, 2020 at 8:25 AM
    FoghornTX
    Ft Worth, Texas
    Pinay likes this.
  8. Jun 13, 2020 at 8:27 AM
    Makoy339
    Super White TRD
    TRD parts
    ohanapools76[OP], BamaMan44 and Pinay like this.
  9. Jun 13, 2020 at 9:09 AM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    This! The 2018+ LED Headlights are the best. I have the pro headlights on my 2017 SR5.
    Pinay[QUOTED] likes this.
  10. Jun 13, 2020 at 9:11 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced the bulbs in mine with with S-V.4 LEDs, H11 and 9005
    Lightwerkz.net ... coupon code: Welcome15
  11. Jun 13, 2020 at 9:14 AM
    BamaMan44
    Andre
    Tucson
    If you are set on only replacing the bulbs, I had the Auxbeams in my headlights and Foglights and had zero issues.
    Auxbeam LED Headlight Bulbs NF-S1 Series LED Headlights with 2 Pcs of H4 9003 HB2 P43T CSP LED Headlight Conversion Kit 50W 8000lm 6000K Hi-Lo Beam - https://www.amazon.com/dp/B074GZ3S4P/ref=cm_sw_r_cp_apip_u1A3NORfajRGe
    Auxbeam H11 LED Headlight Bulb NF-S1 Series LED Headlights with 2 Pcs of High Brightness CSP Chips H11 LED Bulbs H8 H9 Conversion Kit 50W 8000lm 6000K https://www.amazon.com/dp/B074GX852M/ref=cm_sw_r_cp_apip_6Y4vTuFMVxw8G
    Metrojaybrown likes this.
  12. Jun 13, 2020 at 9:16 AM
    BamaMan44
    Andre
    Tucson
    If you are going to upgrade to the 2018+ LEDs, it can be a little more involved than just swapping the headlights. You'll need to install a harness like the one quoted above or from Headlight Revolution. It's not too bad.
    Pinay likes this.
  13. Jun 13, 2020 at 9:28 AM
    ohanapools76
    2015 Toyota Tundra
    Ok thank you
  14. Jun 15, 2020 at 1:16 PM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Juat replaced all exterior bulbs to LED's. All lights in front worked until after re assembling them noticed one of my DRL's stayed off all the time until I turned on the blinker or hazards in which case they then worked. Any recommendations on the fix? Maybe upside down? Either way it looks like I gotta take it all back apart.
