All of the Dash Cam discussions in one thread.....
Discussion in 'Audio & Video' started by csuviper, Jun 29, 2018.
What Dash Cam do you use that you are extremely happy with?
  1. AUBBC
    0 vote(s)
    0.0%
  2. Blackvue
    40 vote(s)
    24.5%
  3. Blueskysea
    1 vote(s)
    0.6%
  4. Cobra
    3 vote(s)
    1.8%
  5. Conbrov
    0 vote(s)
    0.0%
  6. DDPai
    5 vote(s)
    3.1%
  7. DOD
    1 vote(s)
    0.6%
  8. G90 Ambarella
    0 vote(s)
    0.0%
  9. Garmin
    45 vote(s)
    27.6%
  10. Genius
    0 vote(s)
    0.0%
  11. Goluk T3
    0 vote(s)
    0.0%
  12. Mini
    1 vote(s)
    0.6%
  13. Mobius
    1 vote(s)
    0.6%
  14. NSV
    3 vote(s)
    1.8%
  15. Street Guardian
    2 vote(s)
    1.2%
  16. Thinkware
    27 vote(s)
    16.6%
  17. Vantrue N2 Pro
    9 vote(s)
    5.5%
  18. VIOFO A119S
    21 vote(s)
    12.9%
  19. Xiaomi Mijia
    1 vote(s)
    0.6%
  20. YI
    3 vote(s)
    1.8%
  1. Feb 1, 2020 at 7:22 AM
    #121
    2chains
    2chains New Member
    Southern Ablerta
    ^^I definitely don't want to overload any circuits, thinking of a Bluesea fuse block install to power it!
  2. Feb 19, 2020 at 7:10 AM
    #122
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    This is the one I ended up buying (Viofo A129 Pro Dual). It arrived yesterday, now I'm waiting for the The Dashcam Store rear mounting bracket and hardwire kit to come in the mail tomorrow so I can start the install.
    And yes, Crewmax.
  3. Feb 19, 2020 at 7:55 AM
    #123
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Anyone using dash cam mirror w/ backup cam product similar to pic below?
  4. Feb 20, 2020 at 11:47 AM
    #124
    TxLock21
    So I bought the same set-up as you...hoping to install it all in the next day or so. How did you end up installing the hardwire kit? I'm still trying to figure out this "parking mode" thing. Basically what I want is for the camera to be powered off when it's parked until an impact (like someone hitting my truck while parked) and then have the camera turn on and start recording...not sure if that's how it works or not though. I dont want the camera to constantly run and drain the battery. Bc if that's the case, I'm going to just use the hardwire kit to be used as just a way to avoid using the cigarette lighter port and de-clutter the dash.
  5. Feb 21, 2020 at 1:39 PM
    #125
    greener
    greener New Member
    2019 TRD off-road MBM
    Parking mode can be set to off, auto event detection, low bitrate recording , or time lapse. I hardwired as I said, dome and p/outlet 2 Works fine. I’ve only used low bitrate in parking mode. Good camera so far, no issues.
    TxLock21[QUOTED] likes this.
  6. Feb 28, 2020 at 6:55 AM
    #126
    Finch
    Finch New Member
    Donnie
    Virginia
    '16 Inferno CM 5.7L TRD Off-Road
    @TxLock21 How did the install go? I'm also interested in this cam.
    TxLock21 likes this.
  7. Feb 28, 2020 at 9:23 PM
    #127
    TxLock21
    Got swamped with work and out-of-town trips...hoping to tackle it this Sunday. I’ll post up the pics after the install.
    Finch[QUOTED] likes this.
  8. Mar 23, 2020 at 7:37 PM
    #128
    TxLock21
    So I finally got around to installing my VIOFO A129 Pro Duo, along with the VIOFO hardwire kit, Dashcam Store rear mounting bracket (short, grey in color) and VIOFO polarizing lense. Here are a couple of the pics from the install. I hardwired the BATT wire to an empty fuse slot that ran contestant power and the ACC wire to an empty fuse slot that only turned on when the truck was turned on (I used a test light to figure out what slots to use), along with using Add-A-Fuse’s. I also made sure to install the fuses correctly, paying attention to which side of the fuse was the “load” side.
    I tucked the wires behind the A-Pillars and behind the airbags. For the rear cable, I ran it along the top trim, though I wanted to run it along the floor trim but the cable wasn’t long enough. So far, so good. I’m going to take it out and about tomorrow to get some footage.
    My only gripe is that the cable for the rear camera isn’t angled, so the cable goes straight up and then I had to pull back down to tuck it in. Not as clean as I would’ve liked it, but I’m not going to let it spoil my happiness haha
    Also excuse the dirtiness...it’s been raining and this damn pollen is everywhere and I’m “essential” so I don’t have the luxury of staying home to self-quarantine and wash the truck haha
    panicman, omgboost, sf319 and 2 others like this.
  9. Mar 28, 2020 at 4:19 PM
    #129
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Install looks great. How much does it standout from outside from the front of the truck.
  10. Mar 29, 2020 at 1:44 PM
    #130
    TxLock21
    Barely noticeable. I have it mounted right behind the rear view mirror so I barely know it’s there when I’m driving, but it also blends in well from the outside. Unless you’re specifically looking for it, you won’t notice it.
    So far I’m enjoying the extra insurance of having it though.
    vhstejskal[QUOTED] likes this.
  11. Jun 13, 2020 at 6:13 AM
    #131
    Pikeshadow
    Pikeshadow New Member
    2019 Tundra Double Cab TRD
    @TxLock21: do you have any pics of which pieces of trim you had to remove to route the rear cable and the power wires to the fuse box?
  12. Jun 13, 2020 at 6:58 AM
    #132
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    You can try one of these to get the angled rear cable https://www.amazon.com/dp/B07MLYVMS8/ref=cm_sw_r_sms_apa_i_ASn5Eb6Q0F4NE
  13. Jun 17, 2020 at 11:26 AM
    #133
    TxLock21
    I don't have any pics but the only trim I removed to route the rear cable (and also power cable) were the A-Pillar trim pieces. Once I removed those, I made sure to route the cables behind the airbags. From there, I just tucked the cable into the weather stripping and trim along the top of the doors all the way to the rear camera.
    As far as the power to the fuse box, I used a voltmeter and found a blank fuse slot that only used power when the truck was turned on (accessory power). I did this because I have no desire to use the parking function of the camera, I just wanted a clean look with no wires hanging out of the cigarette port.
  14. Jun 17, 2020 at 11:27 AM
    #134
    TxLock21
    omgboost[QUOTED] likes this.
  15. Jun 17, 2020 at 11:43 AM
    #135
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  16. Jun 17, 2020 at 6:39 PM
    #136
    Pikeshadow
    Great! I am getting the same setup, glad to hear it’s an easy install. I wanted to just tap into 12v at the mirror, but I want to try to set it up for parking mode.
    I still need to order a rear mount and the angled usb...
  17. Jul 14, 2020 at 8:24 PM
    #137
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    I’m waiting for a longer cable in the mail so I can install the rear camera. I love the front facing camera. I was hoping to find a good tutorial on here for routing the wiring for the rear cam, but I’m still searching.
    chugs[QUOTED] likes this.
  18. Jul 14, 2020 at 8:47 PM
    #138
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I have the Akaso DL12 in my honda pilot I think it has a very good picture front and rear at night the headlights blind the rear camera the mirror shakes a bit wen driving but I’m getting used to it. Other than that 2 of my Cowerkers got it cause of me and they like it. I’m happy with it and the price was not bad at all
  19. Jul 14, 2020 at 9:07 PM
    #139
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    That’s the one I’ve got. Glad to hear it’s a good choice!
  20. Jul 14, 2020 at 11:45 PM
    #140
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Is there any dash cams that have those little domed cameras for under the side mirrors in addition to front and rear? Like a 4-channel camera system?
  21. Jul 15, 2020 at 3:24 AM
    #141
    Pikeshadow
    I ran mine around the drivers side, under the headliner (behind the airbags). Since I have a double cab I didn’t need as much of the length, so I coiled the extra cable behind the panel near the drivers side rear passenger seat belt mechanism. (I didn’t want to shove it behind the headliner)
    My only non-reversible mod was notching a 1/2” by 1/2” cut out in the headliner to accommodate the plug going into the rear camera. If I ever pull the camera I don’t think it wouldn’t be too noticeable.
    Because I don’t have the crew max roll-down rear window I didn’t need a special mounting bracket for the rear camera. It fit snug on the frame, right above the sliding window.
  22. Jul 15, 2020 at 11:36 AM
    #142
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    I was surprised to see so many of you putting it by the window. I was kinda thinking about mounting it by the bumper. Now I’m not sure!
  23. Jul 15, 2020 at 11:38 AM
    #143
    Pikeshadow
    Someone can correct me if I'm wrong, but I don't believe this camera could survive outside. It's definitely not weatherproof.
  24. Jul 15, 2020 at 11:41 AM
    #144
    TxLock21
    Well I think the majority of us (myself included) are talking about interior cameras. I think mounting one on the rear bumper (which would be pretty cool) would require a weather-proof camera.
  25. Jul 15, 2020 at 11:42 AM
    #145
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    Ah. For the Akaso DL12, the seller says it’s waterproof in the Q and A. Hmm.
  26. Jul 17, 2020 at 10:22 AM
    #146
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Can you take a picture of the fuse box slot you used?
  27. Jul 17, 2020 at 10:24 AM
    #147
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    I know this is an old thread, but thats the same one I bought. I have been happy with it so far, currently its just setup to the cigarette lighter. Did you hard wire yours to the fuse box? If so which fuse did you use?
  28. Jul 17, 2020 at 10:45 AM
    #148
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Is this what you are looking for? I have been trying to find out, but most of the ones I have found are for RV's, so the cameras are huge. 3 stars with 68 reviews is a bit low for me, but I keep looking.
    https://www.amazon.com/Panoramic-Waterproof-Universal-Recording-CarThree/dp/B07HSWKP19
  29. Jul 22, 2020 at 8:10 AM
    #149
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    So question for those of you with the Blackvue front and back set up. How did you mount your rear camera? I don't want to stick it to the window since I actually took it down and I don't want to use the sticky ok the headliner. Any thoughts?
  30. Jul 22, 2020 at 1:08 PM
    #150
    sf319
    sf319 New Member
    Utah
    Randy Morton likes this.
