Brake Light on Dashboard Stays On
Discussion in 'General Tundra Discussion' started by weelittleman, Jun 9, 2020.
  1. Jun 9, 2020 at 7:22 AM
    weelittleman
    weelittleman [OP] New Member
    2014 Cobalt Blue Tundra TSS
    Hey Guys,
    2014 TSS with a brake light that stays on. I don't use my parking brake and I have pressed and released it, so I am not sure why this indicator light is even on.
    Anyone experience this besides me?
    Thanks!
  2. Jun 9, 2020 at 7:24 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you check the brake fluid level?
  3. Jun 9, 2020 at 7:56 AM
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    This and also actually checking the current quality of said fluid. Could be up to level BUT contaminated, meaning might have lost it's hydrophilic characteristics :monocle:
  4. Jun 9, 2020 at 11:25 AM
    1794-BlackTundra
    Sergio
    On Amazon you can get a tester; an easy way to check for contamination on several car/ truck fluids
    omgboost likes this.
  5. Jun 9, 2020 at 9:16 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    A note of caution. When you do check the fluid level, if you find it low, be careful about just topping off the Master Cylinder. Just about all modern automotive hydraulic brake systems use some type of float sensor in the MC to trigger the warning light when the fluid level gets too low. If the system doesn't have a fluid leak in a line or caliper, then that warning light is trying to tell you to check your brake pads. These systems and fluid levels are calibrated this way. Just filling the MC will turn off the warning light, but the worn brake pads will still be an issue.
    Tundyfundy and 1lowlife like this.
  6. Jun 9, 2020 at 10:33 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I may be wrong but I thought the light will stay on if you have a burnt out brake bulb
    1lowlife likes this.
  7. Jun 9, 2020 at 10:42 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I was going back and forth on that, but didn't know for sure...
    Tundyfundy[QUOTED] likes this.
  8. Jun 9, 2020 at 11:12 PM
    Tundyfundy
    Bay Area, CA
    Also if its not a bulb, before you get caught up in all the brake fluid stuff, check to see if your brake pads need replacing. Thin pads drain the reservoir of fluid but once you replace them the calipers wont extend as much and the fluid level will rise. If the pads are fine you may have a leak. as @TechWrench said
    TechWrench and NewImprovedRon like this.
  9. Jun 10, 2020 at 5:11 AM
    TechWrench
    Gary
    Hawley, PA
    I guess it is time to dig out the owners manual to check on that one.
    Tundyfundy likes this.
  10. Jun 10, 2020 at 7:23 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    It reads nothing about the brake lights..
    Brake system warning light (warning buzzer)*1
    • Low brake fluid
    • Malfunction in the brake system
    This light also comes on when the parking brake is not
    released. If the light turns off after the parking brake is
    fully released the system is operating normally.
     Immediately stop the vehicle in a safe place and contact your Toyota dealer.
    *1: Parking brake engaged warning buzzer:
    A buzzer will sound if the vehicle is driven at a speed of approximately
    3 mph (5 km/h) or more.
  11. Jun 10, 2020 at 8:48 AM
    TechWrench
    Gary
    Hawley, PA
    Well I guess that answers that question.
    Tundyfundy and 1lowlife[QUOTED] like this.
  12. Jun 13, 2020 at 4:34 AM
    TemujinNomad
    TemujinNomad New Member
    Check the wiring as well.
