Bilstein 5160 install woes
Discussion in 'Suspension' started by wiretwister, Jun 9, 2020.
  1. Jun 9, 2020 at 6:40 PM
    wiretwister
    wiretwister [OP] Sorta new guy
    NJ
    '22 SR5 CM
    103037259_10101686335547129_574581609998_259e43eb309c12d4fa2b3dd4ce8c91e04d22adb2.jpg 103025533_10101686335681859_442668997216_205c589aa914606b6c188e8aa294f41291bce35b.jpg I had my Bilstein 6112/5160s installed about 2 weeks ago. All seemed fine until I decided to shift the reservoirs and noticed the driver's side shock resi clamp covered in oil. Upon further inspection I saw the banjo was smashed tight up against the strut mount and the banjo seemed to have some play in it. I cleaned everything off and rechecked the banjo. Sure enough there was 2-3 drops on my finger as I wiped around the brass washer. The more I looked, I saw tons of oil sprayed back on the frame and leafs. And finally noticed pools of oil in my driveway.
    Oh yeah, the passenger side shock mount has an indentation in the steel from where the banjo smacked it on that side, too!
    I used a shop I've been to before, but they work on tons of trucks and seemed to be super familiar with this particular Bilstein setup.
    What say you guys?
    I really don't want 'rebuilt' shocks because I'm worried there could be unseen internal damage....
  2. Jun 9, 2020 at 8:41 PM
    Unless I'm missing it, a shop installed them but you later shifted them, and now they are leaking? You might be stuck with that one unfortunately.
  3. Jun 9, 2020 at 10:47 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  4. Jun 9, 2020 at 10:50 PM
    Tundyfundy
    Bay Area, CA
    I increased my angle to around 100 degrees because the hose wanted pop out towards the tires but you get the idea. Id take it back to the shop. these things are stated very clearly in the directions that come with the shocks and the pictures are very clear on the directions. Also that scrape on the inside of the shock mount is highly suspicious. they shouldn't swivel
  5. Jun 9, 2020 at 10:55 PM
    Tundyfundy
    Bay Area, CA
    Sounds like he was back there to change them but saw the damage before he did it. If he shifted them to that position hes SOL I think.
  6. Jun 10, 2020 at 3:56 AM
    I wish the Toytec resis mounted in a bracket like that. It just looks beefier like that IMO.
    Tundyfundy[QUOTED] likes this.
  7. Jun 10, 2020 at 4:18 AM
    Tundyfundy
    Bay Area, CA
    You could buy the Bilstein ones and have them powder coated! They 5160 don’t come with these they were extra. They are a different part number and they werent cheap. One of my only gripes.
  8. Jun 10, 2020 at 4:29 AM
    Yeah I'll have to see if they would fit. Nothing is cheap these days.
  9. Jun 10, 2020 at 4:59 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    I ended up buying these for my 5160s. They well built like the expensive bilstein ones w/o their fancy sticker. Plus they come with a bottle opener! :thumbsup:
    Tundyfundy likes this.
  10. Jun 10, 2020 at 5:23 AM
    wiretwister
    NJ
    '22 SR5 CM
    No. As I was shifting the reservoirs, because I wasn't happy with their location, I noticed the oil on the shock body.
    And I'm happy I did, unless I wouldn't have noticed the leak until later AND I realized that the reservoir mount screws were pretty much finger tight with no loctite or even grease on them.
  11. Jun 10, 2020 at 6:43 AM
    Gotcha. That should be on the installation shop.
  12. Jun 10, 2020 at 9:30 AM
    ckkone
    ckkone New Member
    SLC, UT
    Yikes, probably should have just installed them yourself. Just nuts and bolts very easy to do a rear shock, If you can change wheel you can change a rear shock. I feel for you but I doubt the shop will do anything.
  13. Jun 10, 2020 at 9:34 AM
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    This is why I like to do stuff myself. You can’t trust people to do a simple task the correct way. Plus this would take less than a hour to swap these out yourself. Don’t even have to get the wheel off the ground.
    JPritch and chugs like this.
  14. Jun 10, 2020 at 9:40 AM
    wiretwister
    NJ
    '22 SR5 CM
    I agree 100%. I had a bunch of other stuff done as well... Front shocks, shackles, bearing drops, etc..and I simply didn't have the time, space, tools and resources to do it myself. I was more than happy to have this local shop do it. Turnaround was quick, they were professional in speaking with me, yada yada yada...
    I'll let you know how it all works out. But now I'm worried about 'what the hell else did they $&#@ up?!'
  15. Jun 12, 2020 at 11:24 AM
    33jeep
    33jeep New Member
    Good luck with dealing with shop.
  16. Jun 12, 2020 at 1:33 PM
    glowblue
    glowblue From time to time
    VA
    Like others who DIY - you don’t have to “deal with the shop” when they screw up something. It’s a PITA to have to run your truck back to have them fix something they should’ve done right in the first place!
    JPritch, jre5490, Vr0ck and 1 other person like this.
