Paint cup holder trim
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kbar691, Jun 5, 2020.
  1. Jun 8, 2020 at 6:54 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    How did you reattach after drilling out the welds?
  2. Jun 8, 2020 at 6:58 AM
    Crunch527
    Iowa
    Real or Fake, I too dont like the look. Doesn’t match anything in the cab...looks too after market for my taste. Need a more subtle design.
  3. Jun 8, 2020 at 8:04 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    I pulled it apart. If you remove it and flip it over there are a few plastic pieces that are melted to hold in place. I used my dremel and ground them down. It popped right out then. After painting I used some glue and put it back together.
  4. Jun 8, 2020 at 8:06 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    I glued it in. If the glue doesn’t holdup then I will use JB weld. I believe the glue will do just fine though.
    Crunch527[QUOTED] likes this.
  5. Jun 8, 2020 at 8:25 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    Sure. Everyone's got their own taste. Just wanted to add the tidbit of info that they are functional. If you add more of the AJT stuff, such as the climate control knobs, then it will match some.
  6. Jun 8, 2020 at 8:33 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    That is super helpful but I meant these pillars here. It looks like you painted those also.
  7. Jun 8, 2020 at 9:27 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Still hideous silver. Those are next. You have to remove the entire dashboard for that piece. I watched a video on this forums on how to do it.
    JimboSlice413[QUOTED] likes this.
  8. Jun 8, 2020 at 12:20 PM
    JimboSlice413
    Bakersfield
    Gotcha, that was my understanding also, which is a huge bummer
  9. Jun 8, 2020 at 12:28 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    There are some plastic welds underneath that you have to break off with a chisel or knife. After painting or Plastisip and it's back in place, epoxy on the welds keep it in place.
    here is my little pictoral of it as well as a few follow up posts below showing the welds and install.
    https://www.tundras.com/threads/painting-chrome-trim-bezel-around-shifter.27828/page-5#post-1520601
  10. Jun 8, 2020 at 12:51 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Yep. This is the process I used after watching your thread. With the exception I used a dremel to lightly grind those.
    TelemarkTumalo likes this.
  11. Jun 9, 2020 at 3:10 PM
    GreyGhost15
    GreyGhost15 New Member
    2015 MGM TUNDRA SR5 CREWMAX 4X4
    https://www.tundras.com/threads/big-easy-build.66540/#post-1731305
    Yes I did Paint them. I painted all the chrome and silver inside. It was not hard at all just take your time doing it.
  12. Jun 9, 2020 at 5:47 PM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    How did you handle the chrome trim rings around the vents and knobs? Can the be removed or did you tape them off?
  13. Jun 10, 2020 at 5:23 AM
    GreyGhost15
    They can be removed from the actual cash trim.
  14. Jun 10, 2020 at 9:22 AM
    Kbar691
    Kbar691 [OP] Hmmm
    Kenny
    2019 TRD Pro
    Any details on their removal is much appreciated. Are they glued or anything or do they just pop off when you pull the vent out?
  15. Jun 10, 2020 at 2:58 PM
    GreyGhost15
    they just pop off. use a trim removal tool and pop the dash piece off the left side of steering wheel, you will see what i mean.
    Kbar691[OP] likes this.
