  1. Jun 10, 2020 at 12:23 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Nice. Congrats. Looks good already
    FREEDOMEDIA[QUOTED] and Tundra2 like this.
  2. Jun 10, 2020 at 5:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If I had the V8, I'd be all over it.
    I did find a rust-free donor truck...20200610_070316.jpg 20200610_070335.jpg 20200610_070409.jpg 20200610_070440.jpg 20200610_070306.jpg
  3. Jun 10, 2020 at 5:49 AM
    :bananadead:
  4. Jun 10, 2020 at 5:52 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Darkness and bmf4069[QUOTED] like this.
  5. Jun 10, 2020 at 5:54 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Couple blasts of PB would bring that truck back. :D
  6. Jun 10, 2020 at 6:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Blue is somewhat of a lowered portion (when bed is right side up), and red is a lowered portion also to create a mating surface to frame.
    I do not think I could cut these out, remove old material, and weld them back in efficiently enough.
    Thoughts about just a simple flat plate?
  7. Jun 10, 2020 at 6:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Inside of the wheel wells. Hmm bed liner here?
  8. Jun 10, 2020 at 6:09 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I don’t like using Bedliner in the undercarriage because as soon as it gets a crack or chip, it will trap moisture behind it and will make things even worse.
    bmf4069 and Tundra2[QUOTED] like this.
  9. Jun 10, 2020 at 6:20 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    It’s fantastic from the outside. Underwhelming from the inside. Inside the cab the side pipe was way better. It was clearer sounding.
  10. Jun 10, 2020 at 6:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gotcha.
  11. Jun 10, 2020 at 9:11 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I tried many different LED's and was never satisfied, HID retrofit has been amazing and very worth it. I did the morimoto H1, but if I did it again, I'd go d2s and use the generic brands. Everything I've seen lately is they are just as good and so much cheaper. Southpaw does the whole thing with new housings for $350 I believe. If I ever buy a vehicle without modern lighting, that's the first thing I'll do. (And the baking thing was really easy and kind of fun, I actually did it during a work conference call during quarantine).
    I can honesty say if I had to pick between my Milwaukee impact wrench and the HID, I'd get a second job so I could get both!
  12. Jun 10, 2020 at 9:25 AM
    Fred
    Hand Protectors
    Just found out my ‘2’ button is broken on my stove and can’t program it for the magical required 240° bake temp on the headlight assys. :annoyed:
    Might just try it with 199° and then heat gun the backside of the reflector for a boost to the goo. :bananadead::yes:
    Hooptytrix, chrisb and FrenchToasty like this.
  13. Jun 10, 2020 at 9:28 AM
    rock climber
    I did 220 for 10 minutes and it wasn't enough so did it for 18 minute and that was perfect, so 199 for longer is probably safer anyway.
  14. Jun 10, 2020 at 9:39 AM
    Fred
    Hand Protectors
    Cool! Might do 199° for 30 minutes. I’ll then heat gun the reflector backside if needed.
    chrisb likes this.
  15. Jun 10, 2020 at 9:42 AM
    Your mainly wanting to heat gun the edge where they seal together, you can work your way around the headlight prying and heating as you go around. In your oven place the light on a piece of cardboard, you don’t want any metal touching the housing
    chrisb, bmf4069 and Tundra2 like this.
  16. Jun 10, 2020 at 10:03 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Better not let the Mrs catch you baking headlights or she'll be heating your backside.
  17. Jun 10, 2020 at 11:21 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I recently baked some MTB brake pads in our toaster oven. My wife is small, yet crafty and mighty...so I advised her of my plan in advance.
    I wouldn't say I'm afraid of her, but I would absolutely 100% commit to saying I respect the danger she can pose if properly motivated.
    CodyP, NUDRAT, bmf4069 and 4 others like this.
  18. Jun 10, 2020 at 11:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pressure washed the inside of the bed to fully inspect the rust. Even with the holes in the two middle ones that I can lay hands, and eyes on easily... tapping on them with a hammer still results in a metal sound instead of a crunchy, rotted mess. Not what I was expecting. Still going to see about welding in new through-tubes.
    I was going to cut the old ones out today...
    but I thought about it.​
    I do not know for 100% that I will have permission to use the facilities. So I elected to wait until I know for certain. I may not like it knowing its there, but at least I can still use my bed as it is right now.
    If I cut them out, and they say no I'm fucked unless I friction fit them.
    Pucks18 and theblurry1 like this.
  19. Jun 10, 2020 at 11:52 AM
    Fred
    Hand Protectors
    Success! Put the oven on 199° for about 30 minutes and then baked the assys for about 30 minutes. Turned her up to 350° for the last couple minutes for a bake down and then turned it off. Used that breaker bar with some paper towels taped up for scratch protection and pushed through the hole. Went very easy. :yes:
  20. Jun 10, 2020 at 11:57 AM
    Fred
    Hand Protectors
    Do a tension fit. You should be ok after the bolts go on because it will be holding downward pressure. Maybe use some Fuzeit to hold the tube in place (let it dry) before setting the bed. The Fuzeit will keep the metal from chattering around, too.
    Tundra2[QUOTED] likes this.
  21. Jun 10, 2020 at 12:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That does eliminate a lot of problems I have...
    Fred, I bought some El Cheap-o O-rings to go under the washer that comes with new bed bolts.
    Whats your thoughts on that? Can't hurt, right?
  22. Jun 10, 2020 at 12:31 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Keith @dirtydeeds is awesome to work with. Super helpful. I enjoy my 12 x 5 so much that I ordered the 16 x 5 for my girlfriends 06 4.7 4Runner. Should be here any day now. I noticed I regained all of my lost torque & power from the Magnaflow series 40 Delta Force. I love the way it sounds on my truck now. For anyone looking to do his "budget system", it works best if you have the factory OEM tailpipe still. I had to round one up because I did away with mine and they are not cheap. You have to cut the tailpipe off of the muffler assembly and clamp/weld it to his exhaust/muffler.
  23. Jun 10, 2020 at 1:00 PM
    rock climber
    Nice! What are you putting into the freshly baked housings?
  24. Jun 10, 2020 at 1:15 PM
    Fred
    Hand Protectors
    Not sure. I’d have to see. I can’t picture what you want.
  25. Jun 10, 2020 at 1:18 PM
    Fred
    Hand Protectors
    I like those Morimotos Bi-LED 2.0. They cost more than HID, but in the end are about the same once you add all the HID accessories.
    These 2.0 are inline with the dS2 performance per Morimoto Review. Just less wires and easier install.
    abcinv, FrenchToasty and Tundra2 like this.
  26. Jun 10, 2020 at 2:01 PM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    I just bought my first truck a few weeks ago, an 06 DC SR5 with 50K miles. I live in IL and the rust wasn't too terrible (for IL anyway), but I'm paranoid about rust so I spent the first two weeks of truck ownership with it on stands going over every inch under the truck with a needle scaler and a wire wheel. Anywhere with surface rust got treated with corroseal and painted, then I gave the frame rails a good grease rub and hit everything else with woolwax. Hopefully that will help fend off any future rust20200509_142702_HDR.jpg 20200522_124318_HDR.jpg 20200525_114902_HDR.jpg
  27. Jun 10, 2020 at 3:41 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Cleaned the outside of the ol girl today.
    I also changed my serpentine belt since the old one was starting to crack and squeak when wet. I'm certain the old one was from 2005, so I'm impressed it did as good as it did.
    PHM wouldn't be proud of my hand modeling or my engine bay cleanliness :rofl:
    Filthyphil, Darkness, kb7 and 5 others like this.
  28. Jun 10, 2020 at 4:38 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    replaced wiper blades...pretty exciting.
  29. Jun 10, 2020 at 5:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm doing the same thing right now. Looks great! I'm on day 3? Day 4?
    Day 2?
  30. Jun 10, 2020 at 5:07 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I once again walked right past it to drive the sports car.
    We'll call it, "keeping the miles down." LOLOL
