2018 Factory Suspension Too soft?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jptshadow, Jun 8, 2020.
  1. Jun 8, 2020 at 9:09 PM
    jptshadow
    jptshadow [OP] New Member
    I feel the factory suspension is like riding on a boat.
    Any recommendation if I don't want lift and don't do much off road?
  2. Jun 8, 2020 at 9:32 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Install rear sway bar, maybe the beefed up trd sequoia front sway bar.
  3. Jun 8, 2020 at 10:51 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Rear sway bar will only help on turns.
    It has no effect on the ride going down the road.
    But it does help on turns, love mine.
    I hated the boat like ride of my 2014 DC.
    Replaced the black shocks with 6112/5160 combo.
    Now it rides stiff as f**k, even after 4 years.
    Perhaps research Bilstein 5100 adjustable fronts since you don't plan to off-road.
    Probably what I should have bought..:eek2:
  4. Jun 8, 2020 at 10:57 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ve heard the trd off road springs have a higher spring rate anyone confirm? If so maybe that would help you to if you don’t have an off road.
  5. Jun 9, 2020 at 5:21 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Air-Lift bags in the back, and 4600 series Bilstein shocks all the way around.
    What tires are you riding on?
  6. Jun 9, 2020 at 6:29 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    A lift would fix it. But if not You could try an add a leaf flat leaf in the back any spring place can cut one for you that would only lift it less than a 1/4” Bilstein 6112 at factory height would be stiffer.
  7. Jun 9, 2020 at 6:35 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I have been looking at the Eibach sport shocks once i change out the black tokico shocks. I have been reading it is better than stock but not as stiff as 4600s and you can choose no lift setting.
