  1. Jun 7, 2020 at 2:26 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    im trying it now, but not having a lot of luck. They fold with the switch but do not fold with the lock and unlock
    BamaMan44[QUOTED] likes this.
  2. Jun 7, 2020 at 2:27 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Same here. I talked to her and the harness connecting to the module is wired wrong. She's getting them to fix the harness and will send out the correct ones when she gets them.
  3. Jun 7, 2020 at 3:10 PM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Detailed her again now that tires/wheels and black out are done
  4. Jun 7, 2020 at 3:11 PM
    BamaMan44
    Andre
    Tucson
    Looks great!
    Double Badass likes this.
  5. Jun 7, 2020 at 3:21 PM
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    So I finally got my ajt order and like always there product is top notch!!! Also why I had everything apart I installed my Rago dash plate and I freaking love it:yay:
    Patch999, Ostrich, Fotnot and 3 others like this.
  6. Jun 7, 2020 at 3:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Did your guys stick up a bit farther than the old one?
    Mine went from 13.8v to 14.3v. Got the direction right on the first time.
  7. Jun 7, 2020 at 3:49 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Thank you.
  8. Jun 7, 2020 at 3:53 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    I ordered the 5A mini low-profile version so it fits and looks like the original
    mgm16trdpro likes this.
  9. Jun 7, 2020 at 3:53 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Right. Need the mini.
  10. Jun 7, 2020 at 6:03 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    The boys and I used it out at Auntie’s ranch...
    Finally getting a chance to repurpose some old cedar planks for mending some fence. Also, getting the trimmer ready to thresh some serious wild tall grass around it too.
    Just a quick homage stop to capture “Celestino” and Old Glory before we head down the valley and up around the mountain for work.
  11. Jun 7, 2020 at 6:09 PM
    biebs96
    PA
    Loaded up the trailer... bike trailer that is. And had quality father/son ride this morning.
    equin, mgm16trdpro, Ostrich and 9 others like this.
  12. Jun 7, 2020 at 6:10 PM
    biebs96
    PA
    Oh yea.. and my pops upgraded from his 13 year ownership of his gen1 to a 3rd gen! He’s pumped!
    I guess the past 10 years of telling me he was jealous of my 2nd gen and then 3rd gen finally got to him.
  13. Jun 7, 2020 at 6:47 PM
    Tundra_coug
    Tundra_coug New Member
    2017 inferno tundra sr5
    ARE HD canopy Autohome airlander rooftop tent dual battery systems wiht 2KWatt inverter 40gal water tank firestone airbags
    Started suspension upgrade.. Icon rxt rear end, new leafs and shocks. And its alot of work for one person but completely doable. Kept the air bags for now there in daystar cradles now just not in picture.20200607_124145.jpg
  14. Jun 7, 2020 at 7:09 PM
    Danimal86
    Daniel
    Sacramento, CA
    It fit nice and snug, it should be fine.
    AZBoatHauler likes this.
  15. Jun 7, 2020 at 7:36 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Completed stage 1 of Tech12volt installation. And also did the fold down mod for DCs
    We got kittens this weekend so I lost a lot of time. This is a very nice install as in they really make it turn key. Considering I got the amp installed and the sub, still running stock speakers, it sounds 100 times better than the stock. Stage 2 will be installing the speakers, if it adds even a marginal improvement I’ll be pleased, it’s already good enough.
    For now here are some pics of the install so far, I hope to do a little right up later. For now and I really feel stupid... There is no way the sub box will go behind the seat as there really is zero room. After wrestling it for and hour I realized my greed for not wanting to loose my storage lockers under the seat blinded me to the fact there is no room for any box no matter the size, maybe a tube with a 6”. I’m 49 years old I know damn well when the box goes in you are losing space!
    So it’s really good that I did the fold down mod, at least I can store straps. I took a pic before & after cut, I also tried to put some shrink wrap on to replace the rubber that covered the edge prior to cutting, not perfect but works.
    And I’ll throw in a pic of the kittens, Tupac & Biggie. :) After about an hour of playing they decided to nap on the wife’s legs
  16. Jun 7, 2020 at 7:36 PM
    TimberToy20
    TimberToy20 New Member
    East Texas
    2020 Super White Crewmax
    612 Old Man Emu coilovers, Old Man Emu rear shocks, 1” rear block, diff drop.
    After 10k miles I couldn’t handle the front being so low. Went old man emu all the way around with a 1” block in the back. A little more height in the front than I anticipated but now I’m smiling like a kid every time I look at it!
    Before and after:
  17. Jun 7, 2020 at 7:40 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Can't go wrong with Cement Gray!
  18. Jun 7, 2020 at 7:53 PM
    Lowgybear
    Lowgybear It takes an iron will
    Ysai
    San Antonio Texas
    2018 TSS OFF ROAD Tundra
    Very nice, is that the 218 black?
  19. Jun 7, 2020 at 7:59 PM
    Do you happen to remember the length you cut off or the length of the current hook?
  20. Jun 7, 2020 at 8:06 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    1” straight across measuring from the tip.
    Then came back did 45 degree cut eyeballing 1/8- 1/4”
    And filed it off, I’m not very good finesse.. but it works perfect.
  21. Jun 7, 2020 at 8:07 PM
    :hattip:
    Tchase[QUOTED] likes this.
  22. Jun 7, 2020 at 8:09 PM
    Lowgybear
    Ysai
    San Antonio Texas
    My black shifter finally came in
    Went down to the auto parts store and got me a bunch of LED bulbs for the cab interior too
    Oh and I forgot to post it but I put up a vinal decal on the back window a few weeks ago MVIMG_20200519_152016.jpg
    MVIMG_20200607_201508.jpg MVIMG_20200607_201526.jpg MVIMG_20200607_201539.jpg
  23. Jun 7, 2020 at 8:13 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did the cheap leather steering wheel wrap from Amazon. Took a solid 4 hours of taping, tucking and sewing... Not that kind...
    I'm overall very happy with the quality and fit, but I need to do something else with the area behind the horn/airbag/top of the steering wheel. There wasn't quite enough material to get it to sit right on one side
    WFD473, GAknight, equin and 9 others like this.
  24. Jun 7, 2020 at 8:24 PM
    Lowgybear
    Ysai
    San Antonio Texas
    Also I took care of an eyesore today.
    Had a bunch of exhaust residue on my bumper and some on the paint above the exhaust tip
    Took a little time and elbow grease but got it back to new condition
    MVIMG_20200607_183919.jpg MVIMG_20200607_183915.jpg MVIMG_20200607_200356.jpg
  25. Jun 7, 2020 at 8:29 PM
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Thank You! You are right my friend :thumbsup:
    Tundyfundy[QUOTED] likes this.
  26. Jun 7, 2020 at 9:06 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Installed new bump stops to help with towing my 34ft travel trailer. Also popped on mirror covers to match the truck.
  27. Jun 7, 2020 at 9:29 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Yes. Thank you.
  28. Jun 7, 2020 at 9:43 PM
    Lowgybear
    Ysai
    San Antonio Texas
    Where did you get the color matched grill and bulge?
    And how did you go about the TSS system?
  29. Jun 7, 2020 at 9:47 PM
    18" TRD Off Road Wheels
    Lowgybear[QUOTED] likes this.
  30. Jun 8, 2020 at 4:40 AM
    BoxersBrew
    Thomas
    Northern Virginia
    I'll look up and PM you the info. I bought the hood bulge separately, from a different supplier. I'll try to find you the discount codes I used also.
    The TSS is a easy few bolts to undue and relocate to the new grille radar cover.
