Difference between Tundra w/Towing Pkg and Tundra/TRD towing pkg
Discussion in 'General Tundra Discussion' started by JB1950, Jun 6, 2020.
  1. Jun 6, 2020 at 6:52 PM
    JB1950
    JB1950 [OP] New Member
    2015 - 2017 Tundra - looking to buy
    Tundra 5.7L 2WD with FULL TOWING PKG - concern. Ready to buy 2017 to 2017 Tundra however need to be sure this truck can pull cross-country a travel Trailer approx 7500GVWR fully loaded. Looking for Tundra owner that has hauled suck a Travel Trlr. Appreciate any advise I can get before I buy Tundra. I'm long time owner of Toyota cars etc think they are the most reliable vehicles ....
    TUNDRA TRD trucks - OFF ROAD PACKAGE
    I see many Tundra's that say OFF ROAD PKG - does that mean it has the full Tow Pkg with add'l transmission cooler and beefed up alternator and the proper suspension for TOWING a TT of about 8600 lbs. Does the Off Road Pkg have a better advantage when towing then Tundra with just the Tow Pkg (Haul/Tow button).
    Trying to compare the TUNDRA with Tow Pkg against the Tundra TRD Off-Road Pkg and the differences.
    We are not off-road types but I do want to understand the different towing equipment between the two types of TUNDRAS. Occasionally we'd like to do some boondocking though....
    Really would appreciate your feedback...
  2. Jun 6, 2020 at 6:58 PM
    18" TRD Off Road Wheels
    Tundras only have one tow package currently. Any of them with the tow package will have the same alternator, and the external transmission cooler was removed from all the Tundras in the 2019 model year.
    The TRD Off road does not affect the tow package in any way. Here is a pic of what the TRD Off road package adds to an SR5 from the Toyota site
    Wallygator, Tundyfundy and omgboost like this.
  3. Jun 6, 2020 at 7:00 PM
    I just saw on your info that you are looking at the 2014-2017 model years, so any tow package should have the external trans cooler, and they will all have the same alternator if you are looking at the 5.7 engine. Also, the stuff in my previous post may not apply exactly the same because packages have shifted from year to year, but there is only one tow package and it won't be affected by the off road package. They are unrelated.
    Wallygator and Tundyfundy like this.
  4. Jun 6, 2020 at 7:02 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    This attachment is from the 2020 brochure. It goes by chasiss, drivetrain, and trim level, not packages.
    Wallygator likes this.
  5. Jun 6, 2020 at 7:10 PM
    T-bone Tundra 63
    T-bone Tundra 63 New Member
    2019 Tundra limited
    Backflip tri-fold bed cover Go rhino running boards
    Why did Toyota remove the external cooler on 2019? Did they feel it wasn’t necessary or beef up cooling system in anyway to compensate. Just curious.
  6. Jun 6, 2020 at 8:25 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    8600 lbs is a bit heavy for a halfton.
  7. Jun 6, 2020 at 8:36 PM
    They removed it after testing without it didn't show the trans getting out of spec on trial runs. The cooler/warmer on it keeps the trans temp within Toyota's target range on heavy pulls.
    Cpl_Punishment likes this.
  8. Jun 6, 2020 at 8:40 PM
  9. Jun 6, 2020 at 8:46 PM
    Wallygator
    ...because they knew I was going to buy a 2020 and that I would search for a solution to almost 230 degree transmission temps while NOT towing. They knew this would consume my every thought and keep me with an empty wallet fixing what should be standard equipment on a truck that is rated to tow almost 10000 pounds. :rant:
  10. Jun 6, 2020 at 8:48 PM
    :rofl::rofl::rofl:
    TILLY, Wallygator[QUOTED] and Dorks68 like this.
  11. Jun 6, 2020 at 8:54 PM
    Wallygator
    :)I'm sorry rant back on...:rant:
    So Sweers is saying Toyota based their decision to not put a trans cooler on the truck because of some route in Colorado that is 11 miles long??? WTF!? Is he serious? What about the guy that is towing in the desert mountains for 500 miles??? Well good for Toyota saving themselves prob $50 in parts on the Tundra when it's all said and done! As soon as I get the money a trans cooler is going on my 2020.
    GODZILLA[QUOTED] likes this.
  12. Jun 6, 2020 at 9:02 PM
    By that logic I should be howling at every naturally aspirated vehicle manufacturer because I live at high elevation and their sea level performance numbers are unattainable without forced induction. You can't get mad at them for saving cost when MOST buyers will not see a significant difference with or without the cooler on there.
    Two apologies owed right now: First, sorry to the OP for the thread jack. Second, Sorry to Wallygator because I am having fun pushing buttons. Zero offense intended, but if you are offended, Zero F:censored:cks given. :cheers:
  13. Jun 6, 2020 at 9:16 PM
    Wallygator
    No need to apologize. It must sound like I am legit mad...nah...just annoyed with cost cutting on what I feel is an essential part. PLUS!, I'm enjoying having my buttons pushed. (not that there is anything wrong with that ;))
    An yeah I get it, I have OCD about this vehicle and most drivers could give a crap and it's most likely not needed. But it's needed on my truck. :D
  14. Jun 6, 2020 at 9:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Love this thread!..:) Has anyone up to this point had any trans problems towing with the 19+ models, or is this just speculative?
  15. Jun 6, 2020 at 9:42 PM
    Wallygator
    Most likely speculative. But I have a friend who has a 2016 so it came with a cooler and he see about 195 vs about 230 on my 2020. both empty and not towing with outside temps in the 70's-80's. So under a load those temps will go up. Also off road those temps will go up.
  16. Jun 6, 2020 at 9:55 PM
    Wallygator and gosolo like this.
  17. Jun 7, 2020 at 4:12 AM
    glowblue
    glowblue From time to time
    VA
    Looking through the specs posted by @tech1208 it shows the 2020 Tow pkg includes a “supplemental engine oil cooler” and a “supplemental transmission cooler”.
    What exactly are these?
  18. Jun 7, 2020 at 4:23 AM
    timsp8
    NY
    The oil cooler is by the filter I believe. It’s small and probably doesn’t do much. The transmission cooler that they reference is the cooler/warmer in the 2020. All 07-20 have it, but the 19-20 call it a cooler too.
    I think he gave the lawyers answer in that video. You know he wouldn’t ever say we messed up and it needed it. But like other said, no one knows how many trans have or will go bad due to lack of a cooler and towing.
    I always wonder why people say a trans cooler isn’t needed, but we have a power steering cooler when the ps boil point is like 600*. Why didn’t Toyota remove that?
  19. Jun 7, 2020 at 4:30 AM
    glowblue
    VA
    Reading information elsewhere suggests for every 20F transmission temps rise above 200F cuts the life of the transmission in half. Not sure if that’s true but heat is the worst enemy of most every engineered component.
    I don’t tow a lot so I’ve not paid much attention to the transmission temps on my 2019.
  20. Jun 7, 2020 at 4:50 AM
    I don't think that is an apples to apples comparison. It's not about the fluid boiling point. It's about the temp tolerances of the fluid in the given application. My guess is that the requirements of the power steering system might generate more heat. Also, if your power steering fluid overheats and either breaks down or fails and you lose power steering at 70 miles per hour then you are at a pretty high risk of an accident. If the transmission fluid fails you are much less likely to be in an accident as a result. Liability for the company plays a part in all decisions.
    I would guess that the biggest reason why it was deemed that a separate trans cooler isn't really needed is because these are 1/2 ton trucks that are likely going to spend far less than 50% of their time under heavy load. Toyota is not dumb. They know that people add things to vehicles. Why not save a bit of $$$ on a cooler that a high percentage of the trucks will never need, and just let those who are worried about it add one later? Nobody is selling their Tundra off because it doesn't have a trans cooler. They howl about it and either do nothing, or they add one. Agree with it or not, but it does make sense from a business perspective.
  21. Jun 7, 2020 at 6:26 AM
    timsp8
    NY
    Yes, in all these threads about it I’ve said probably 10% or less tundras actually tow. And even less actually tow something that will overheat their transmission.
    But I don’t think they said in 2019, after it was there for 12 model years (07-18), on a model that was being redesigned 3-4 years later, let’s spend some R&D money to see if it’s really needed and remove it. I think there was another reason that they aren’t saying, and won’t because of lawyers. I read it was the change in Freon in 2019 that caused the cooler to not be able to be shared with the condenser. But we will never know, just like we won’t ever know the failure rate either.
    Id also guess a trans that locks up at 70mph while towing would be just as dangerous as ps going out. My steering rack went out on my 2010 and I could still steer a little.
    GODZILLA likes this.
  22. Jun 7, 2020 at 5:00 PM
    I can agree with most of that. Though I doubt a transmission will have a single critical failure the same way PS will. It's a degradation and multiple symptoms over time type of system most of the time.
    timsp8[QUOTED] likes this.
  23. Jun 7, 2020 at 5:35 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    While not a Tow Pkg feature the additional 38 Gal tank that come with certain package would be a nice have for towing.
