Clueless to suspension upgrades - Platinum 2020
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toyota_loyal, Nov 19, 2019.
  1. Nov 19, 2019 at 6:17 AM
    Toyota_loyal
    Toyota_loyal [OP] Platinum Pro build in progress
    deb
    Denver, CO
    2020 Platinum CM
    Greetings!
    I have had my tundra for 2 weeks and have zero buyer's remorse.
    I test drove the TRD Pro and preferred the ride over the Platinum. I mostly drive on pavement and lots of highway driving.
    I intended to replace the wheels, since I hate chrome.
    I also intended to replace the shocks/struts with TRD Pro-like components.
    A local shop is trying to steer me to 18" wheels, but the wheels that I want are not available in the 18" size. This is not a deal breaker because I can paint things to achieve the look that I had in mind.
    I've read that the suspension should match the tires/wheels.
    I don't have much room for a lift and that has never been a goal. I want to be able to tow things occasionally.
    I have front and rear TRD sway bars.
    Which suspension is recommended for 20" wheels, maybe switching to 18"?
    Thanks in advance -
    Deb
    Tundra1078 likes this.
  2. Nov 19, 2019 at 7:40 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Seems like there's an easy answer but there isn't. 20s will have a harsher ride than 18s. The increased side wall on 18s provides a little more "cushion". The sway bars also make the ride a little more harsh. A bump or pot hole on one side is automatically transmitted to and felt on the other side. They do reduce body roll but, IMO, it's a truck and not a sports car. Still, maybe they're nice for a DD, I don't know.
    The shocks on the new Pro are Fox and can be installed on your truck. They're not cheap and if you're gonna spend that much, there are better alternatives IMO.
    King, Fox, ADS are the premium shocks with a premium price tag. Bilstein is, I'm guessing, is the most common upgrade with several different options. Elka's are a newer option but I know nothing about 'em.
    Best thing, if possible, is to ride in other Tundras and see what you like. Otherwise it's a shot in the dark.
    Tires have a LOT to do with ride quality. Stock tires provide a smoother ride because, for one, they're lighter weight.
    It's a very subjective question. But, if you like the ride of the Pro, you may just wanna install the Pro shocks.
    GodlessPro and Tundra1078 like this.
  3. Nov 19, 2019 at 7:59 AM
    Toyota_loyal
    deb
    Denver, CO
    2020 Platinum CM
    Thank you!
    831Tun[QUOTED] likes this.
  4. Nov 19, 2019 at 8:40 AM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Also consider long travel.
    Toyota_loyal[OP] likes this.
  5. Nov 20, 2019 at 12:17 PM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    I had the Fox on my last Tundra and was talked into getting the 6112's and I much prefer the Fox. The 6112/ 5160 do not element the bed bounce and the Fox shocks did.
  6. Nov 20, 2019 at 12:47 PM
    Toyota_loyal
    deb
    Denver, CO
    2020 Platinum CM
    Thanks for the info!
  7. Nov 20, 2019 at 12:51 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Good to know.
  8. Nov 20, 2019 at 12:52 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    FYI you can’t buy Fox pro shocks from a dealer unless you have Pro vin#. Folks do sell there pro suspension. Keep an eye out, they sell quick. Enjoy your new Tundra.
    ryanwgregg likes this.
  9. Nov 20, 2019 at 12:57 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I have a Pro and love the way it rides. One advantage you will have if you go with the Pro setup is the dealership will not be able to deny warranty work because you modified the suspension. Some dealerships have been known to do this. If you use the OEM Pro components, they won’t have a leg to stand on.
  10. Nov 20, 2019 at 1:04 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Greetings from Georgia!
    Consider lowering the rear 3.25" using kit from SOS Performance, including the Air-Lift kit.
    I did this with my 2007, and left the front suspension stock. It's a pavement pounder.
    I run two sets of 18" wheels with different tires 255/70/18 in winter, and 285/60/18 in summer.
    Check my signature link for details.
  11. Nov 20, 2019 at 1:07 PM
    Toyota_loyal
    deb
    Denver, CO
    2020 Platinum CM
    Will do - thanks!
  12. Jun 6, 2020 at 4:41 PM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    2020 Tundra Voodoo 2020 SequoiaTRD 2000 Tundra LTD (RIP)
    I'm in the same boat: 2020 Platinum and looking for a more plush ride on road and more capable off. I don't tow.
    What suspension did you end up going with?
  13. Jun 6, 2020 at 5:14 PM
    Toyota_loyal
    deb
    Denver, CO
    2020 Platinum CM
    I kept the stock wheels, so my ride could be improved with smaller wheels.
    I got the Fox 2.5, coilovers with reservoirs.
    It was kind of a mess after the install, since it got lifted. I expected it to be leveled, but that didn't work out. The installer added a 1.5" block in the back. As a female with ZERO depth perception, I had to relearn to drive the truck :). The TRD skid plate wouldn't reinstall correctly. I hated it all.
    I had the installer set to the lowest setting possible in the front and after a few days, the truck made this creaking noise when I would turn or hit the slightest bump. It was too much for my OCD. I thought that, after spending 5k on a suspension upgrade, it would ride like the TRD Pro.
    So, the front had to be raised a bit and I am now getting used to it.
    I think the upgrade is way better than stock, but not sure it was worth 5k, and like 4 days to get it right.
    The installer, a local Toyota EXPERT, did encourage me to get the 18" wheels, but the husband refused.
    I think better tires will improve the ride. I have Michelins LTX on my 2001 Sequoia and feel like they are a better tire than stock.
    TacomaLC likes this.
  14. Jun 6, 2020 at 5:40 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    18” tires ride better than 20” tires/wheels because there’s more side wall to absorb what ever the road throws at you. You can buy a taller tire that would work with this example. I’m looking for 17” wheels currently.
    Good luck, nice truck.
  15. Jun 6, 2020 at 8:07 PM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    Thanks for the update> Not sure which direction I will go.
