What's your latest purchase?
Discussion in 'Marketplace' started by vl184009, Jul 27, 2017.
  1. Jun 5, 2020 at 4:05 PM
    #4771
    5 of these. I have the older 25 lumen version and they are great. The newer version is 40 lumens. They are rechargeable and you plug them in, turn the switch on, and they automatically come on when you lose power. Great for thunderstorms and hurricane season. They are 11.00 at HD if you can find them. Amazon wants $20- $30 each. I got them online through Ace for $13.00
    rons23, Wallygator and Tundra2 like this.
  2. Jun 5, 2020 at 6:13 PM
    #4772
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    So someone really believes that electricity can only flow one way? HA!!! You should have explained to him that with AC current, there is not much "real" flow either way, at least not nearly as much as the same number for DC current! I have no trouble educating wire pullers and others who want to argue with me on the poor man's transfer switch. I'm a licensed professional electrical engineer with a Master's in EE.
    Wallygator and BLONGTX like this.
  3. Jun 5, 2020 at 6:18 PM
    #4773
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Received this the other day. Been waiting for nice weather to install it. Thought I'd better do it today with the tropical storm moving in this weekend. Toyota could have made installation a lot easier. It requires a riveter. It had been so long since I riveted anything mine was stuck in the closed position. Instead of fighting it I just went to Lowes and bought another one for $23.
    Wallygator and Prostar 190 like this.
  4. Jun 5, 2020 at 6:20 PM
    #4774
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Does anyone know what these holes are for? They are in each corner of my bed (2 pics shown):
    aperezsh, Wallygator and Prostar 190 like this.
  5. Jun 5, 2020 at 7:24 PM
    #4775
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Just got home with more parts for the Nova
    Hammerdog, rons23, aperezsh and 6 others like this.
  6. Jun 5, 2020 at 7:57 PM
    #4776
    :yes:
    TokerJoker[QUOTED] likes this.
  7. Jun 5, 2020 at 9:50 PM
    #4777
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Will do. Thanks for the heads up. I’m sure there are a bunch out there you talking specifically the DJI one or what?
    Tundra2 likes this.
  8. Jun 6, 2020 at 6:46 AM
    #4778
    Here is the one that I am on. You will see the Mavic Air section. https://mavicpilots.com/
    Wallygator and CodyP[QUOTED] like this.
  9. Jun 6, 2020 at 12:06 PM
    #4779
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    I bought some more parts and finished my latest flying thingy this morning.
    kparrow, Wallygator and Prostar 190 like this.
  10. Jun 6, 2020 at 12:16 PM
    #4780
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Wallygator likes this.
  11. Jun 6, 2020 at 12:38 PM
    #4781
    ExcludedTim
    ExcludedTim New Member
    2015 BRM SR5 DC
    Do what?!? I just installed my Northstar today. Do I really need to be adding these types of things?
  12. Jun 6, 2020 at 12:39 PM
    #4782
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    What's the problem with the AGM?
  13. Jun 6, 2020 at 1:23 PM
    #4783
    1lowlife
    DADA
    2014 MGM DC SR5
    I bought my 24F X2 Power in January of this year.
    A month ago the voltage was down to 11.8 and barley started the truck.
    The truck had only sat for 11 hours in the driveway since the previous start/drive.
    It should have never been that low in the first place.
    It had been lagging on the start for about a week, like when you know the battery is going bad.
    Took the battery back to Batteries Plus, they gave me a loaner (for 3 days) , charged and tested the battery to see that it held a charge.
    They said it was fine, but the CCAs where a little low when I brought it in.
    CCAs were fine after they charged it..
    Had my oil changed at the dealer the day I picked the battery up and had them check the charging system.
    They said it was fine.
    So far the battery has been fine, I think the issue builds up after a month or three of improper charging.
    I'm no mechanic, but something made the voltage start dropping, yet the battery and charging system are fine.
    There is no parasitic drain, other than my alarm remote start, it has been fine for 5 years.
    Besides, everything was fine with the loaner battery and has been fine since Batteries Plus recharged the AGM battery.
    From my hours of google research, it seems my 15 minute drive to work (each way) isn't enough to maintain the AGM.
    I read that the AGM needs a higher voltage output from the alternator (than what I have now) to maintain it and it likes a long slow charge as opposed to a non-AGM battery.
    The HKB Electronics Alternator Voltage Booster (fuse/diode) bumps up the alternator output a tenth of a volt or so.
    The charger is in case the voltage drops again and I can properly recharge the battery maybe once a month or so, pretty much what Batteries Plus did.
    I probably need to have a battery charger around the house anyway.
    It was $104 on Amazon.
    https://www.amazon.com/gp/product/B000FRLO9Y/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Some recommend replacing the ALTS fuse with a GM diode to boost the voltage output, but that deletes having a fuse.
    I don't want to go without the fuse and fry out electronics of the truck.
    Thread on the subject
    https://www.tundras.com/threads/cus...ging-profile-for-odyssey-agm-batteries.58290/
    Diode upgrade
    https://www.chitown4x4.com/agm-battery-voltage-upgrade.html
    Wallygator and JMB[QUOTED] like this.
  14. Jun 6, 2020 at 1:36 PM
    #4784
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Hammerdog, kparrow, Haggis777 and 2 others like this.
  15. Jun 6, 2020 at 1:38 PM
    #4785
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
  16. Jun 6, 2020 at 2:38 PM
    #4786
    JMB
    Chesapeake, VA
    Thanks. I've had the Northstar since the group buy. No starting problems, but I'll check it tomorrow.
  17. Jun 6, 2020 at 3:25 PM
    #4787
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Yes sir!!!!:D fired her up this afternoon after sitting for a decade or more!!
  18. Jun 6, 2020 at 3:41 PM
    #4788
    :thumbsup:
  19. Jun 6, 2020 at 5:21 PM
    #4789
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Installed a wireless charger, phone mount today for future road trip purposes.
    https://youtu.be/95vX2McWtRY
    Thought it appropriate to represent in the video...
    Big gurll link....
    https://www.amazon.com/dp/B07PDG5FND?ref=ppx_pop_mob_ap_share
    So far I like it. It does shake very lightly when traveling as anything with some sort of articulated arm will. Does not hinder the digital map purposes.
    I have noticed that while it does wirelessly fast charge my S10+ its much slower than the cord by roughly 40 minutes. To get this number I used the phones own estimated time to full.
    During testing cord was 1hr, and 4 minutes at about 27% battery. Wireless fast charge was about 1hr, and 45 minutes.
    I don't think its the phone mounts fault, but the technology of wirelessly charging things.
  20. Jun 6, 2020 at 7:14 PM
    #4790
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
  21. Jun 6, 2020 at 7:35 PM
    #4791
    Wallygator
    I put my 27F X2 on a charger about once every month or two. I use the same charger as you have. AGM batteries take a higher charge than normal batteries do. Alternators are not chargers, all they are designed to do is maintain the battery to a certain charge voltage.
    I think I am going to get one of those HKB voltage boosters but am saving for other things right now. I read on the website it will provide about a 0.5-0.6 boost in voltage.
    The stock Tundra alternator does not charge the AGM up to it's capacity. Probably at the most to about 13.1 or so. Most AGM's like to be closer to 14. Most likely this is causing the AGM to develop sulfation upon discharge. With sulfation and not being at it's best charge, after a while the battery will become the weak point. Using a specific AGM battery charger like the one you have and using it on a regular basis will condition the battery and help it last for years. A lot of chargers have a desulfation mode also.
    Anyway I am still glad I have the AGM battery even though it takes a second or two to plug it in every once in a while. So with that revealed, is it more maintenance than a regular battery? Sure, but very minimal (I mean, plug the charger in) and it will last for many years past what a normal battery will if you do your part. And, it will power things for many hours, sometimes days, and still start the vehicle.
    Sunnier and 1lowlife[QUOTED] like this.
  22. Jun 6, 2020 at 7:39 PM
    #4792
    Wallygator
    Yeah just get a AGM charger and plug it in every once in a while to recondition it for years of use.
    JMB[QUOTED] and 1lowlife like this.
  23. Jun 6, 2020 at 8:06 PM
    #4793
    TokerJoker[QUOTED] and Tundra2 like this.
  24. Jun 6, 2020 at 8:34 PM
    #4794
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    For me to run my bag air lines to compressor mounted in swing case.
  25. Jun 6, 2020 at 10:27 PM
    #4795
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Spent today just moving stuff out of the garage, but here’s some pics.
    A0CC2591-778B-47A4-BA34-D086986DCA59.jpg 39D73B0E-5918-477F-94FB-BF10827E7E55.jpg A196B9FB-B7C9-4274-8617-7F20CC78D3DA.jpg
    This shed is a life saver so far.
    The old garage which I had to play Tetris with to get anything out.
    New garage is a two car. I am sooo happy. E5C61B17-7189-40B5-A8E3-99D0755F1EF2.jpg
    rons23, kparrow, MTRock and 7 others like this.
  26. Jun 7, 2020 at 8:11 AM
    #4796
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] bought a VEPR 12
  27. Jun 7, 2020 at 11:20 AM
    #4797
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Needed something to plug the hole that wouldn't leak. (Does Teflon tape work on fuel?) It ain't the greatest but better than nothing at all!20200607_131801.jpg
    aperezsh likes this.
  28. Jun 7, 2020 at 11:26 AM
    #4798
    Yzed608
    Yzed608 New Member
    Wisconsin
    Think I'm done spending money for a bit. After this I don't think there's anything else I want to do to the interior.
    SR black interior door handles front and back.
    4R Pro black steering wheel trim
    AJT wheel Toyota logo cover
    Also a Safe Jack starter recovery kit. It's on backorder but the stock jack was sketchy when I used it.
    Wallygator and aperezsh like this.
  29. Jun 7, 2020 at 11:31 AM
    #4799
    1lowlife
    DADA
    2014 MGM DC SR5
    No pics?
    Come on!!!
    Is the black 4Runner trim gloss or matte like the door handles?
    Any problems swapping the door handles?
    Although I've never had a flat (knock on wood), I've considered getting a better jack to keep in the truck..
  30. Jun 7, 2020 at 12:33 PM
    #4800
    Yzed608
    Yzed608 New Member
    Wisconsin
    I know better than that to not post pics ;). I only ordered them today, didn't get them in yet.
    It looks glossy, which I'm somewhat concerned about, but will see how it is when installed. Here's a pic from Roman's topic about them:
    Prostar 190 and 1lowlife like this.
