  1. May 30, 2020 at 5:12 PM
    #2821
    Just spit balling here, but what if you put the truck in the air on 4 jack stands in 4wd and put a breaker bar on the nut, resting against the ground? Would it just spin the other tire?
  2. May 30, 2020 at 5:30 PM
    #2822
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’ll spin the other. Open diff and all
    NUDRAT[OP] and bmf4069[QUOTED] like this.
  3. May 30, 2020 at 5:49 PM
    #2823
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You can also do the center cap removal with the tire on the ground, wedge the breaker bar against the ground and in 4 low GENTLY break it loose. This would be the last resort, heat if you're not careful about it could ruin the wheel bearing.
    NUDRAT[OP] and TX-TRD1stGEN like this.
  4. May 30, 2020 at 6:03 PM
    #2824
    I'm going to try the center cap trick tomorrow.
  5. May 30, 2020 at 8:33 PM
    #2825
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Good news and bad news.
    good news: axles came a day early, installed them both easy peasy in about 2 1/2 hours.
    Bad news: I still have a weird rumble/vibration over 70mph.
  6. May 31, 2020 at 4:38 AM
    #2826
    Professional Hand Model
    Fred
    Hand Protectors
    Took her on a nice drive yesterday. The truck is absolutely purring in the engine dept. She is handling street driving nicely with the warmer roads, as well.
    Since getting a somewhat firm grasp on the Parking Brake Adjustment last year, I’ve always noticed the driver rear drum is less hot after drives than the pass side when the PB is allowed to ‘self adjust’, as designed. I guess its not a perfect system with the pulleys/cables, etc.
    Even with all the Stealer axle work, they seem to get the adjustment about as good as I think it gets when I finally wrapped my head around it last year. I think I’m going to give the driver side Rear Star Adjuster 1 or 2 clicks tighter adjustment after the PB self adjusts from now on.
    Going to pull the rear drum off in the next few days and rotate the tires. Hoping this last Axle Seal fix is the final cure and I can move on and focus on other things with the truck. We’ll see soon!
    bmf4069 and TX-TRD1stGEN like this.
  7. May 31, 2020 at 8:45 AM
    #2827
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Yes, hopefully no more leaky axle. Time for you to move on to quality of life improvements
    [​IMG]long skirt or short skirt bobble? [​IMG]
  8. May 31, 2020 at 8:46 AM
    #2828
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Short....OBVIOUSLY
  9. May 31, 2020 at 8:54 AM
    #2829
    NUDRAT
    SW CT
    But he is a senior fellow on the island & probably a consul member, so....?
  10. May 31, 2020 at 8:55 AM
    #2830
    Outbound
    Aaron
    Northern Alberta
    Agreed. Short skirt, no question about it.
  11. May 31, 2020 at 8:55 AM
    #2831
    8E6903FD-5BEA-4CA4-8F0D-065C705C263A.jpg Got back yesterday from a fun trip with the oldest boy. Lots of work, but lots of memories to be made, he would not shut up about eating the fish we caught(he didn’t eat any because he partied like a rock star and slept for 12hrs!) but he caught his first fish and was super stoked about it! We saw a bear across the lake “dad shoot the bear!!” Some older boys found a snake, he held it, gave it a kiss and went on his way.
    Truck ran great; actually first road trip and speeds over 70mph, felt awesome!
    That LSD is something else, WOA I know! Coming down the mountain in 2nd OD off, it was extremely hard to break the rear end loose(even at 40psi tires)
    I will remember that in snowy or bad weather, 4wd and low gears.181BDA64-0D7E-4AC7-8D09-D82D97149E07.jpg
    Brown Bear, bmf4069, speedtre and 4 others like this.
  12. May 31, 2020 at 2:35 PM
    #2832
    empty_lord
    05 rollover special
    Hope y’all are staying safe, we’re currently getting hit with rioters. So all my stuff is shoved in the garage and the guns are loaded.
    bmf4069, CodyP, TX-TRD1stGEN and 3 others like this.
  13. May 31, 2020 at 3:24 PM
    #2833
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Guns stay loaded.
    I'm just outside Tampa which has a curfew in effect. I don't feel like riotting will make it here but always ready if it does.
    I'm more worried with my wife having to take my son to therapy in the morning. I might tag along in a separate vehicle just to make sure it's clear then head back home once i feel the roads are safe.
  14. May 31, 2020 at 3:52 PM
    #2834
    I'll copy the rooftop Koreans if necessary.
    speedtre, bmf4069, CodyP and 3 others like this.
  15. May 31, 2020 at 4:00 PM
    #2835
    lsaami
    lsaami Let ‘er buck
    Minnesota
    thankfully I’m about 50 miles from Minneapolis. We had a BLM rally by the lake here yesterday that consisted of 9 lesbian teenagers thinking they’re changing the world. No exaggeration.
  16. May 31, 2020 at 4:09 PM
    #2836
  17. May 31, 2020 at 4:12 PM
    #2837
    empty_lord
    05 rollover special
    im a bit away from all the commotion. but its close enough im loaded up. they were dragging people out of their cars and stealing them earlier.
    lsaami[QUOTED] and imDementeD like this.
  18. May 31, 2020 at 4:23 PM
    #2838
    Fred
    Hand Protectors
    Wurrld Peas!
    bmf4069 likes this.
  19. May 31, 2020 at 4:27 PM
    #2839
    imDementeD
    That's why I'm escorting the wife tomorrow...
    Sbr ak 75rd drum sitting shotgun and then the normal suppressed ar15 load out plate carrier etc.
    Want the loudness of the ak in case there was a crowd attacking so they know its business.
    I'm sure it won't come to that and pray it never does but can't risk my wife and child
    bmf4069 likes this.
  20. May 31, 2020 at 4:48 PM
    #2840
    I've decided 2020 is going to be the year of my first suppressor. Might as well. We got COVID, murder hornets, and now riots.
    bmf4069 and imDementeD[QUOTED] like this.
  21. May 31, 2020 at 4:51 PM
    #2841
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Im like 15 miles from Santa Ana with was pretty hectic last night. Im in a pretty residential area and far from the street so Im not to worried, But in times like these I wished I owned a gun. Stay safe
  22. May 31, 2020 at 4:51 PM
    #2842
    imDementeD
    Might as well buy two or three... they are addictive and take forever to get
  23. May 31, 2020 at 5:33 PM
    #2843
    empty_lord
    05 rollover special
    I love my suppressor
  24. May 31, 2020 at 5:34 PM
    #2844
    empty_lord
    05 rollover special
    No shit. 2 years for mine
  25. May 31, 2020 at 5:35 PM
    #2845
    imDementeD
    My first 3 were 6 months my last 2 were 18 months
  26. May 31, 2020 at 5:54 PM
    #2846
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    2F6F705B-8A11-4264-B8D4-8DF33B9FFFB9.jpg A$$holes are out in force...
    Keep your powder dry boys.
  27. May 31, 2020 at 5:58 PM
    #2847
    empty_lord
    05 rollover special
    they just offically broke into a resturant not far from me. and killed a police dog. i believe its going to be a rough night out here. I took the batteries out of the cars outside and got as many as i could into the garage.
    TX-TRD1stGEN and BestGen[QUOTED] like this.
  28. May 31, 2020 at 6:00 PM
    #2848
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Fuck fuck fuck. My truck just puffed blue smoke out of the exhaust on startup for the second time today. Shit. I hope that has nothing to do with the slightly rougher than usual idle. As soon as i was happy with the truck and the way it was running.. fuck. Hopefully its just carbon getting burnt from the techron
  29. May 31, 2020 at 6:01 PM
    #2849
    BestGen
    BestGen New Member
    Paul
    Glad I went to the market this morning. Stocked up on meat n potatoes, water, milk, eggs, meds, and bread.
  30. May 31, 2020 at 6:02 PM
    #2850
    NUDRAT
    SW CT
    whenever a storm is coming through I separate the vehicles so no 1 tree-fall can take them all out. Similar might apply to looters.
    Good Luck!
