  1. May 31, 2020 at 9:43 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I used some homemade cut offs from some composite plastic shims made for home building. Jacked the truck up by the frame and wedged some metal wedges in gentle to open the tips to accept the shim. Loaded the bottom of the shim for adherence with Fuzeit so the top slides on the the next leaf up as designed. Works! Still have a clunk on slow 90° turns back there thats probably bushing based but no more squeaky binding clanks (especially in cold weather season).
    Squirt your leafs with some PB Blaster and enjoy the smoov ride after doing the wedges. The Fuzeit won’t stick to PB if you spray PB before install. Do it after.
    I really want some new leafs with new shackles and bushings!
  2. May 31, 2020 at 9:45 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’d love new leafs. But deaver expo leafs are expensive.
  3. May 31, 2020 at 9:50 AM
    Fred
    Hand Protectors
    Looks different especially on the lips seal. I’m leery of any aftermarket seals now, but yours is OEM and redesigned? Haven’t studied this aspect of the truck much other than I’ve seen mucho mangling going on in this area. :rofl:
    Whats the Seal Part#?
    NUDRAT likes this.
  4. May 31, 2020 at 9:56 AM
    Fred
    Hand Protectors
    This looks like a fun little project as mine have been broken for years, but still was able to lock them with special assistance. I never use the rear windows anymore so not sure about doing them based on others saying the new cams and fitment aren’t proper on some of their reports.
    Bet you are stoked on the wind eliminations!
    Jake92[QUOTED] likes this.
  5. May 31, 2020 at 10:01 AM
    90311-47027 I think. Or that's the other side. I have both.
  6. May 31, 2020 at 10:29 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Exhaust updated:
    I had some text messages with Keith at DD's and he said it sounded like exhaust leaks which I've said before it definitely does seem like that as well. Wasn't sure how much of a difference it would make.
    Either way, I grabbed a shop vac today and taped it to my exhaust in the "blow" orientation and soapy water. I was a bit amazed at what I found......
    Exhaust Leak Locations:
    1. Weld on the cat flange leaks (magnaflow cat)
    2. Weld on the moved o2 sensor location
    3. o2 sensors (both upstream and passenger downstream)
    4. Both attachment points at the header
    5. (2) bottom rear bolts on the header to head. I feel like I can tighten these up and I had already thought this may be a spot that would leak based on my angle of tightening.
    My plan - Tighten the areas that I can and see if that helps. After that, I need an exhaust shop to fix the two welds that leak.
    I HOPE after this the exhaust will sound cleaner than it currently does. I am NOT routing anything through the side until I'm happy with the tone and then I will go from there. I may still need to add another muffler inline to tone it down some but fixing the leaks may be enough..
    Oh - I ordered some stuff. NuLens to clean up my headlights (as well as my LX470 that are a bit hazy) and a MaxOak 500wh portable power station.
    FirstGenVol, chrisb, bmf4069 and 2 others like this.
  7. May 31, 2020 at 10:41 AM
    Fred
    Hand Protectors
  8. May 31, 2020 at 10:59 AM
    Fred
    Hand Protectors
    Those are a lot of leaks.
    I can tell since doing all 4 o2 sensors that my exhaust has quieted. It wasn’t loud at all before, but it definitely sounds quieter. I think some air was getting past the rear o2 gaskets on WOT and letting off a ppffffttt sound. Now, it sounds like everything is flowing straight through to/out the tailpipe.
    Remember, I put on a new OEM muffler and it quieted a hair as was expected. Fast forward and I didn’t realize leaks around o2 Sensors would make a difference after doing them 2 months later, but it does.
  9. May 31, 2020 at 11:26 AM
    @FrenchToasty @lsaami
    Does this look flush? Can't seem to drive it in any deeper but it looks like there is still room behind it.
  10. May 31, 2020 at 11:35 AM
    Fred
    Hand Protectors
    What are you using to drive this seal in place?
  11. May 31, 2020 at 11:37 AM
    How big of a lip can you feel with your modeling nails? It looks home to me, I wouldn’t send it past flush. But you can give it a good thump and see if it moves more
  12. May 31, 2020 at 11:38 AM
    That's the East Coast bushing. I used French's specialty tool. He also loaned me a seal driver for the seal I just used.
  13. May 31, 2020 at 11:41 AM
    Yeah it's done. Won't budge. It's flush too.
    :fistbump:
  14. May 31, 2020 at 11:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    :yes: your truck just got better
    bmf4069 and NUDRAT like this.
  15. May 31, 2020 at 12:29 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    yup. It’s acceptable for it to be out just a hair due to machining tolerances per ECGS instructions. Mine hangs out just a hair.
  16. May 31, 2020 at 2:48 PM
    imDementeD
    Tightened up all bolts where leaks were present. Def made an improvement. Need to test again to verify them get the welds fixed
    Thrussn, Darkness and NUDRAT like this.
  17. May 31, 2020 at 3:45 PM
    I'm embarrassed at how long it took but I'm finally done. I never would have thought removing the needle bearing would be the easiest thing I did today. I think the slight grind @KarmaKannon did to the tool really helped.
    That ratcheting wrench made it easy.
    Very exciting video below. Grab a beer and enjoy.
    https://youtu.be/FbcJ2enO6gI
  18. May 31, 2020 at 4:23 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Got the last SR5 badges off and got the mudflaps back on. I kinda liked having them off but we will see if I take them off.
    With all the trim blacker the bed rails seem really out of place being so gray.
    Wsidr1, Thrussn, chrisb and 5 others like this.
  19. May 31, 2020 at 4:26 PM
    Fred
    Hand Protectors
    Pop them off and spray them up. They are easy to remove and reinstall. You can tape off the tail gate cap and spray it right on the truck if you use care.
  20. May 31, 2020 at 4:45 PM
    jImmegart
    Jonah
    California
    I had them off for a few days and I was thinking of spraying them. I just am not too sure how long the trim paint will last.
  21. May 31, 2020 at 4:51 PM
    Fred
    Hand Protectors
    Spray them again if they fade.
  22. May 31, 2020 at 4:52 PM
    jImmegart
    Jonah
    California
    Im more worried if they chip off. Have you sprayed yours? if so with what?
  23. May 31, 2020 at 4:58 PM
    Fred
    Hand Protectors
    Sprayed mine with Bed Liner by Rustoleum. Proper prep is key. Lightly sand and wipe with alcohol. Spray according to cans directions. Holding will with no chipping. Prior years I’ve used Rustoleum Matte finish on my trim that looks good for about 2-3 years before fading and then needs a re-do. This time I’ve given the Bed Liner a shot. Been on about a year with no fade. Time will tell.
    jImmegart[QUOTED] likes this.
  24. May 31, 2020 at 5:01 PM
    jImmegart
    Jonah
    California
    What grit sandpaper? Might try trim paint first.
  25. May 31, 2020 at 5:13 PM
    He's right. You'll want to sand them. It knocks off some of the oxidation and gives the new paint something to stick to. I painted mine and I'm really glad I did.
  26. May 31, 2020 at 5:22 PM
    jImmegart
    Jonah
    California
    I didnt sand my mudflaps, I kind of forgot about it. I have a feeling the flaps aren't going to last long. What grit should I use for rails?
  27. May 31, 2020 at 6:05 PM
    empty_lord
    05 rollover special
    since all my plans were destroyed for today, i did my cluster color change. (aka sanding)
    [​IMG] [​IMG]
  28. May 31, 2020 at 6:13 PM
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    Yes it is so nice not hearing the wind anymore. It’s a lot quieter in the cab now
  29. May 31, 2020 at 7:04 PM
    I don't remember the exact grit but it was real fine. You don't want to cut deep marks, just take the top layer off.
  30. May 31, 2020 at 7:11 PM
    empty_lord
    05 rollover special
    Came out pretty dang good
